02-09-2016, 07:24 AM | #1 |
Rock Stacker Join Date: Feb 2016 Location: Under Your Hood
| Bomber gets dual shock setup Since day 1 of ownership I wanted to run a dual setup, and feeling the suspension can be improved quite a bit. Took measurements and ordered: Front Pro-Line POWERSTROKE SLASH REAR SHOCKS RC4WD 2x The Ultimate Scale Shocks 100mm Associated Silicone Shock Fluid 25wt/275cSt Rear Pro-Line PowerStroke XT Shocks 5" Yeti Rear RC4WD 2x The Ultimate Scale Shocks 100mm Associated Silicone Shock Fluid 27.5wt/313cSt The RC4WD Scale shocks, after reading bad luck others have had, I noticed good amount of flashing on the cartridges. Cleaned it up,added oil and they feel pretty good. Rear mounted ones still have the internal spring, fronts have no internal spring. First impressions...completely fell in love with the rig all over again. The amount of control, and how I can keep control on uneven terrain is incredible while keeping full articulation. |
02-10-2016, 12:20 PM | #2 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
| Re: Bomber gets dual shock setup
Do u have a pic of the front lower shock mount?
02-10-2016, 01:44 PM | #3 |
| Re: Bomber gets dual shock setup Not at the moment. I will be changing it up some. After burning a ESC last night, Im "forced" to order more parts Where I live there isnt much crawling opportunities (think urban jungle) So Im changing it up to tackle open field/park/terrain at speed. Got new hardware to change up gearing and see how a 20T motor behaves I will be adding an additional pair of ProLine shocks, the RC4WD Scale shocks seem to leak easy |
02-19-2016, 09:00 AM | #4 |
So I tried a 20 turn motor with the Yeti 60T spur on 3s and it lasted about 15 mins before it got fried ... Vanguard 3150kv and other misc items just arrived from asiatees... Will post update shortly, also installed another 2 sets of Proline shocks |
02-19-2016, 09:57 AM | #5 |
Just a preview before I start the brushless install |
02-19-2016, 10:24 AM | #6 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
With all the proline powerstroke shocks your bomber is starting to look like mine, or ours look similar. I only use 6 powerstrokes, a pair of slash rear in front, a pair slash rears, as well as pair of XTs in the back. I'd've done the same as you, but the axles I'm using don't have dual shock/link brackets.
02-19-2016, 02:38 PM | #7 |
| Re: Bomber gets dual shock setup |
02-19-2016, 02:41 PM | #8 |
Rock Crawler Join Date: Aug 2011 Location: SB
Nice rig man.
02-19-2016, 02:59 PM | #9 |
| Re: Bomber gets dual shock setup Last edited by NitritedCarbide; 03-15-2016 at 09:42 AM. |
03-17-2016, 02:22 PM | #10 |
Better pics next week, VP Methods come in on Monday On 30wt the ride was still too bouncy for my liking, changed over to 15 and couldnt be happier. Small preview of a 3ft drop https://youtu.be/q2Onb7HQ3HY |
Bomber gets dual shock setup - Similar Threads | ||||
Dual Shock Setup | VTHDAN4467 | Vaterra Twin Hammers | 5 | 01-22-2016 10:32 PM |
rc4wd dual rate shock setup? | super mud | General Scale Talk | 4 | 01-27-2010 05:43 AM |
RC4WD 90mm dual spring scale shock setup | tetracanth | 2.2 Scale Rigs | 4 | 07-24-2009 02:40 PM |
Futaba 9CHP setup for dual steering, dual esc | duartev | Electronics | 5 | 06-07-2009 08:58 AM |
Dual 3s Lipo/Dual Sidwinders/Dual 4400KV Inrunners Setup Help Needed. | TheHeadHunter | Electronics | 16 | 08-17-2008 05:21 AM |
