02-15-2016, 06:46 PM | #1 |
Rock Stacker Join Date: Dec 2014 Location: Toronto
| SSD diamond axle question
Assembling for my bomber and they seem to bind so tight when I get the diff cover on they won't spin. Any ideas? Also, I assume the gear goes in the same side as stock. Why would there be two ways to put it in? |
02-15-2016, 06:52 PM | #2 |
| Re: SSD diamond axle question
Sorry, bearing was t seated but direction question still stands
02-15-2016, 06:59 PM | #3 |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
So you can reverse it if you so choose.
02-16-2016, 10:19 AM | #4 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
delete
02-16-2016, 10:22 AM | #5 |
Sorry didn't see you still had a question. The ring gear runs on both sides so you have options. Always nice, for instance; my bro just bought a SSD D60 scale axle, this only has the ring gear on one side, and so does the stock SCX10 axle. He had to buy two SSD axles to get the vehicle to spin the wheels in the same direction. The stock ar-60 axle does both sides as well. You can always switch the direcion the vehicle travels with moving the ring gear to the other side, but you need to do both. So once again, options hope my ramblings help |
SSD diamond axle question - Similar Threads | ||||
SSD Diamond front axle | waka789 | Axial SCX-10 | 3 | 08-29-2016 12:36 AM |
New SSD Diamond Aluminum SCX10 Axle Housings | STANG KILLA SS | Axial SCX-10 | 27 | 08-08-2016 04:00 PM |
SSD wide diamond axle install instructions? | oosel | Axial Yeti | 4 | 11-05-2015 06:42 PM |
Ssd diamond centered wraith axle | VelineonSlash | Newbie General | 5 | 07-23-2015 08:11 PM |
