06-08-2016, 07:45 PM | #41 |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| Re: Levior* - Becher's Bomber Build
Very kool crawl...I'm sure it was even steeper than it looked since video never seems to capture this aspect.
06-08-2016, 07:58 PM | #42 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
Thanks Bil, one of these days I'll get the hang of taking decent video That or I'll just recruit someone to do it for me.
06-09-2016, 11:22 AM | #43 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| Re: Levior - Becher's not-a-Bomber Build
Your Bomber looks like a Comp Crawler on those rocks! That second vertical was pretty impressive. Sent from my SM-N910V using Tapatalk |
06-09-2016, 12:35 PM | #44 |
Thanks Mr. Science that was the intention for this build. I want to be able to crawl the entire length of this stream bed. There are six lines that I never could clear with my Wraith. With this rig I can clear all but two of those and countless others that were challenging are now trivial. I'm hoping that with some knuckle weight I can conquer this last section. It's been fun building this rig with the primary intention of making this run. I could have built a comp crawler and done it fairly easily but I want to see if it can be done with a class-3 legal rig and no winching. |
06-22-2016, 04:14 PM | #45 |
Rock Crawler Join Date: Dec 2013 Location: Tuxedo NY
So would you say the tummy tuck really helps crawling? In the wraith section it seemed popular for a while, but then a lot of folks seemed to go back...
06-22-2016, 04:29 PM | #46 |
It has helped my Bomber crawl better for the way I have it setup. I run it pretty low slung to keep the COG down and it still drags the skid sometimes but clears enough to just give it a bump to breakover. I have no intention of going back.
06-22-2016, 08:43 PM | #47 | |
| Re: Levior* - Becher's Bomber Build Quote:
07-02-2016, 08:41 PM | #48 |
Levior got some new shoes today - 2.2 KLR gold compound up front and silver in the rear. I reused the CI DD foams that were in the HB Rovers - 5.5" comp cut narrow with medium outers on the front and soft on the rear. My rig now weighs 5 lb 1 oz and the foams are just about right. I thought I might have to widen the wheels but they seem OK like this. My first impressions after some brief testing - awesome performance and they look a helluva lot better than the Rovers! I don't have the terrain in my backyard course to really put them to the test but it's pretty evident that they easily outperform the Rovers which were really good tires on this rig. I'm going to head out to my favorite spots just as soon as I can (if it stops raining ). I can't wait to see how these measure up to what I've been running for the last ~3 months. I might finally have the last ingredient to make a no touch run of my White Whale. Now I just need to finish the interior and it should be class-3 legal. |
07-02-2016, 10:08 PM | #49 |
I know the 1.9 KLR tires kick some serious ass, but you have to have them on correct, the driver's side tires are backwards!
07-02-2016, 10:39 PM | #50 | |
Thanks Bil! Luckily I haven't glued them up yet so flipping them was trivial Last edited by mikebecher; 07-02-2016 at 10:50 PM. | |
07-25-2016, 12:26 PM | #51 |
Quarry Creeper Join Date: Sep 2011 Location: NW
Those videos are great! The lines it can pull are amazing! I did a tummy tuck in my wraith chassis. It's amazing how much performance you gain from this type of mod. Awesome rig
07-27-2016, 08:27 PM | #52 |
I made some more short running videos today with my new GoPro knockoff: |
07-27-2016, 08:35 PM | #53 |
That's a really beautiful spot. Looks volcanic. Where are you at? Your truck is still looking good. Do you think the light weight has both positives and negatives? Looked like it had a little problem hooking up toward the beginning and slid around a bit? Sent from my SM-N910V using Tapatalk |
07-27-2016, 08:45 PM | #54 | |
| Re: Levior - Becher's not-a-Bomber Build Quote:
That climb where it slides down and to the side is the only way I've managed to complete that obstacle. It's too steep and off-camber to get over those protrusions straight-on. And it has to be super dry, any moisture at all and it's game over since there's some moss on the rock face. | |
07-29-2016, 04:27 PM | #55 |
So after about 6 months of near daily crawling, I finally had my first real breakage on this rig. It rolled off a ledge (only about 2 feet high) and squarely landed the face of the rear wheel on a rock It's endured MUCH worse falls but these things happen, oh well. I love these wheels and I'm sure Robbob can get me back up and running. |
10-17-2016, 06:59 PM | #56 |
Got a new dig servo today, it's so tiny! |
10-18-2016, 05:51 AM | #57 |
Rock Stacker Join Date: Jan 2016 Location: North East Ohio, In the Lake
Got a link to the wheels?
10-18-2016, 09:32 AM | #58 |
| Re: Levior* - Becher's Bomber Build These are comp wheels and not really intended for a heavier rig, mine sits at about 5 lbs. Rob cut a custom set for me out of 3mm CF and they've held up well, except for that one unfortunate fall. Here's the link: 2.2 Hearts |
10-18-2016, 10:31 AM | #59 |
Those tires seem to be polarizing. Do you love them or hate them?
10-18-2016, 12:05 PM | #60 | |
Here's a good shot of what they looked like a few months ago: How to increase forward bite in KLRs? | |
Levior* - Becher's Bomber Build - Similar Threads | ||||
Jayn Bomber Build | Jayn | Axial RR10 Bomber | 31 | 03-07-2017 07:02 PM |
Ca. Off Roader's Bomber Build up... | Ca. Off Roader | Axial RR10 Bomber | 10 | 03-27-2016 08:46 PM |
Bomber Build - DBW | dbw | Axial RR10 Bomber | 11 | 02-27-2016 08:34 AM |
Forestbumpr's RR10 Bomber Build | forestbumpr | Axial RR10 Bomber | 29 | 12-28-2015 09:12 PM |
My Bomber build | bredmx | Axial RR10 Bomber | 8 | 12-28-2015 11:51 AM |
