02-27-2016, 11:24 PM | #1 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
| Ben's Bomber Build
Guess I should put up a thread for my Bomber as modifications progress. Started with a new stock Bomber. First upgrade before even driving it a midwest grade tire. Sold all the stock electronics for about $93 here on RCC. Made some upper links while I was waiting for parts. Went with: SSD titanium steering links Vanquish C-hubs Axial Universals Holmes Hobbies BLE ESC Holmes Hobbies 2700k Trail Master Motor Vanquish SLW wheels The first time it ran I didn't drive it. A friend of mine did a lot of work towards supporting the local crawling club last year. He sold his SCX10 to race over the winter. He asked if I might have a rental for a local event. I happily let him break it in. Then I got some wheel time with it after the event. Needs wheel weights, needs swaybar in the rear, needs drag brake programmed on the esc, needs 4s 3000 mah batteries. needs a better servo, needs a customized body to set it apart from the other club Bombers. Some parts are coming further upgrades to come. |
02-28-2016, 06:17 AM | #2 |
Rock Crawler Join Date: Nov 2013 Location: In the country
| Re: Ben's Bomber Build
Awesome! J.A.W - just another wraith & a Bomber! |
02-28-2016, 07:43 AM | #3 |
Rock Stacker Join Date: Sep 2015 Location: US
Hey another Midwest buddy Sent from my XT1042 using Tapatalk |
02-28-2016, 07:14 PM | #4 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
What motor you thinking about going with?
02-28-2016, 07:35 PM | #5 |
| Re: Ben's Bomber Build Went with a 2700kv Holmes hobbies Trail master. I really like it so far I might make the jump to a Puller Pro or Revolver series. The Trail Master works very well and the motor setup is the envy of most in the club. I just find that it starts some what abruptly still looking for something just a hair more low end control. It seems to have that great brushless punch and snap I need to go rock bouncing though. I have a 1400kv Revolver on its way to me for another project. If I like it I may buy another for this truck. |
02-29-2016, 01:34 AM | #6 |
Drove it today at a event for about 80ft and the servo quit. I did numerous repairs and care to the Tower Pro servo it's only like 2 weeks old with 2 runs on it was never right to begin with. Had enough so it got the smash treatment soon to be replaced. Also installed a Axial Sway bar kit. Wasn't impressed at all. Very plastic and the fit seemed less then well engineered. Also a bit on the stiff side limits flex. Once I get the wheels weighted and take it for a crawl maybe I'll like it. Might just take the bar to the grinder to make it a hair softer. |
02-29-2016, 03:05 PM | #7 |
Newbie Join Date: Dec 2015 Location: Athens
| Ben's Bomber Build Did you get the sway bar that was made for the bomber...mine from axial looks much different than a yours...it had the rear link to axel shorter....two end links screwed together (if that makes sense)...AX31331... Last edited by WiiTardo; 02-29-2016 at 03:08 PM. |
02-29-2016, 03:32 PM | #8 |
Yeah that's the same part number. I didn't really have any instructions to go from couldn't seem to find any detail. So I just kinda winged it from pictures I found from a Yeti. Might use those little screw together links instead.
02-29-2016, 06:07 PM | #9 |
| Ben's Bomber Build http://docs.axialracing.com/Instruct...ay_Bar_Set.pdf This is what I used but left the axa180 screws loose that are in step 2 Last edited by WiiTardo; 02-29-2016 at 06:11 PM. |
03-07-2016, 02:27 AM | #10 |
Corrected the sway bar and wrapped it in digital camo blue. |
03-07-2016, 02:47 PM | #11 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
Love your wheels and Camo. Since the last topic here between you and WilTardo is in regards to swaybar. I'd like to hear your thoughts with a little more time after making the change to yours. I also was not really happy with the sway bar. I feel that something in between the "soft" factory sway bar and no sway bar would be great. The bar adds benefits; but, at a cost of being extremely tippy on off-cambered problems. I'm not sure it's worth it. |
03-08-2016, 12:46 AM | #12 | |
| Re: Ben's Bomber Build Quote:
Ben's Bomber Build - Similar Threads | ||||
Jayn Bomber Build | Jayn | Axial RR10 Bomber | 31 | 03-07-2017 07:02 PM |
Ca. Off Roader's Bomber Build up... | Ca. Off Roader | Axial RR10 Bomber | 10 | 03-27-2016 08:46 PM |
Bomber Build - DBW | dbw | Axial RR10 Bomber | 11 | 02-27-2016 08:34 AM |
My Bomber build | bredmx | Axial RR10 Bomber | 8 | 12-28-2015 11:51 AM |
Ben's Creeper Build | bimmerben | Venom Creeper | 5 | 04-27-2009 11:04 PM |
