03-16-2016, 08:09 PM | #21 |
| Re: SCREAMER's IFS Bomber "Qwiksilver"
I will be using a SuperShafty Wraith trans for this build and to answer your questions, yes, yes, and yes!
03-16-2016, 08:23 PM | #22 |
Rock Stacker Join Date: Oct 2014 Location: Northern Los Angeles
I suppose the Wraith trans is similar to an SCX10? What does it take to install? Can you use the Wraith center driveshafts? I'm pretty new at this so I'm flying a little blind. It would help to know all of this before I buy my electronics and hardened trans gears.
03-16-2016, 08:35 PM | #23 |
Here's the complete front end assembled. To recap all the significant parts used here, we have VP steering rack, bell cranks, posts, caster blocks, knuckles, VVD HD shafts and EXO shock tower. As I mentioned before, the turnbuckles will be replaced with titanium links after I get the lengths dialed in. This is so much easier to do with a twist on the turnbuckle as opposed to removing one of the screws, guessing how much to turn the rod ends, reinstalling then checking again, and repeat. Also shown are the RPM lower arms and Traxxas big bore 2661 shocks with Axial Bomber stock rear springs which are 14x70mm and have a spring rate of 3.27 lbs/in IIRC. I'm using DLux's very nice upper shock balls to mount the shocks to the tower. I'm now going to get this all mounted back up to the chassis and get the steering servo installed and linkage connected. Moving right along and everything is going together beautifully!
03-16-2016, 08:47 PM | #24 | |
| Re: SCREAMER's IFS Bomber "Qwiksilver" Quote:
03-16-2016, 09:46 PM | #25 |
I was thinking of the MIP shafts but if Traxxas offers them that's ok too.....I sell both. How do I get a hold of DMG? I'm thinking that lighter, stronger, and smaller without the transfer case would be better for me. I haven't added it all up but if you include the price of a stout trans & transfer case & aluminum motor plate $200 isn't that bad.
03-16-2016, 09:55 PM | #26 | |
Rock Crawler Join Date: Jan 2012 Location: Hudsonville, MI
All of the above! Using either a Wraith or SCX10 tranny is a lot more simplified than the stock Bomber/Yeti tranny. Less moving parts, weighs less, easier to tear down and work on. Not to mention, it looks a lot cleaner than the Bomber/Yeti tranny. Sent from my iPhone using Tapatalk | |
03-16-2016, 11:32 PM | #27 |
DMG posted up in this thread on page one. Click on his name then click send a private message to DMG. Voila!
03-17-2016, 01:13 AM | #28 |
Looks like I found my stopping point for tonight. The front end is back on the chassis, steering servo is mounted and linkage is connected, and I was able to get two of the front turnbuckles dialed for toe in and replaced with Ti links. I'm really happy with how she's going together. It's very apparent to me the time and effort that went into designing this retrofit and the positioning of everything so that the entire front end works well together. Now that the IFS is pretty much done except for the two camber links, I should be able to get the rest finished up tomorrow and get some initial testing done. It looks so damn good just sitting here, I can't wait to see it in action. Much more to come. |
03-17-2016, 04:15 AM | #29 |
Rock Crawler Join Date: Nov 2013 Location: In the country
If we switch trannies will the yeti length set of drive shafts still work or do we need buy another set? thanks |
03-17-2016, 01:10 PM | #30 |
Got right to it this morning. I got the powertrain installed, driveshafts cut and installed, and rear end installed. Front driveshaft was a little tricky to get measured and cut but not too bad. The Traxxas Maxx shaft was just too big to fit in the tighter spaces up front so I went with the WBHD up front and the Maxx shaft in back. Now it's time to mount the receiver and get everything connected for a system check.
03-17-2016, 01:53 PM | #31 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Hurry up |
03-17-2016, 01:57 PM | #32 |
No words other than simply badass. Are you running an interior? Sorry if I missed that but your speedy build doesn't leave time to read. |
03-17-2016, 02:02 PM | #33 |
I'm trying to man. Life keeps throwing distractions at me. Complete builds like this always take me forever anyway because I'm so picky about every little detail like the perfect screw length or fitment issues for other components. One of the things that slowed me down this morning was the clearance of the servo horn and the motor mount plate. You guys will see what I mean when you put one of these together. When it's perfect, it's awesome but it takes some adjusting to get everything in harmony.
03-17-2016, 03:17 PM | #34 |
I typically don't run interiors due to the fact that I wrench on my rigs way too much to pull 14 screws every time I want to adjust the ESC or check the pinion or adjust the slipper. I can do all that and a lot more without having to pull a single screw or remove anything. If it got to a point where I didn't mess with one for a while because it was just perfect and stayed that way I might install an interior. Actually, they hold in heat and don't allow the motor and ESC to cool as efficiently. Never mind. |
03-17-2016, 06:55 PM | #35 |
Quarry Creeper Join Date: Dec 2013 Location: Nunnelly, TN
Screamer, I just love the look so far. Could you please take a photo of the underside? I'd like to see how that plate attaches to the skid.
03-17-2016, 07:03 PM | #36 |
I realized I wasn't going to get very far with testing if I didn't have any wheels and tires mounted so I decided that was my next step. I also wanted to get some daylight pics of Qwiksilver as a full roller and I can focus on getting her running the rest of tonight. After getting the wheels and tires mounted I immediately noticed that the front springs are too soft. I'll install the next stiffer rate I have and check the sag again. Bummer, no blue springs up front. I'm running ProLine's regular Faultline wheels in the rear and Faultline 6 lug wheels in the front for a couple reasons. First, I knew I would need an SLW wheel in front to dial in backspacing. Secondly, I wanted matching wheel faces but a touch more silver up front for aesthetic reasons. Inside the PL Flat Iron XLs I have CI deuces wild talls and they fill the tires perfectly. All of this was a breeze to assemble but tedious due to the amount of screws. I ended up settling on 350 SLW hubs in front. I wanted just enough room behind the wheel to clear everything and no more. So it looks like I'm in the home stretch. I'll get all the wires ran tonight and everything connected to the receiver. Of course I'll have to run it around the house to set steering trim, expos for throttle and steering, make sure I like where the ESC settings are dialed, that sort of thing. It looks like tomorrow will be the first good test and I'm really excited. I didn't think it would take me this long to get the first run in but, life is what happens while your busy making plans. After she's running pretty solid, I'll start worrying about getting the body panels on and window nets and other accessories installed. I'm just really trying to get this thing going so I can get some time behind the wheel. More to come. |
03-17-2016, 07:25 PM | #37 |
Here you go GLHS. This should also put an end to everyone asking, "isn't that just a Yeti?". This is no pot bellied Yeti. This is a lean mean rock bouncing machine that won't get high centered on a gum wrapper. |
03-17-2016, 07:49 PM | #38 |
RCC Addict Join Date: Jun 2006 Location: IN THE PIT !!
| Re: SCREAMER's IFS Bomber "Qwiksilver" Nice ! once you move your shocks outwards at the top, you will increase spring rate greatly ! it takes a monster spring rate to hold the front end up with the shocks leaning that far inwards. |
03-17-2016, 08:31 PM | #39 |
Do'h! That's right, I totally forgot about the upper shock plate. I'll get that installed and see how she sits. I just got her running and of course she's reversed so time to hook up the castle link and get her switched around. Everything else is working perfect. I should be fully ready to hit the dirt tomorrow.
03-17-2016, 08:38 PM | #40 |
Thanks for the picture Screamer! That actually looks cooler than I was thinking it would. Please take some video when you run it.
SCREAMER's IFS Bomber "Qwiksilver" - Similar Threads | ||||
2-shot's BGR Fabrications Bomber Build - "Bombdiggity" | 2-shot | Axial RR10 Bomber | 150 | 05-19-2020 12:10 PM |
SCREAMER's F-Bomber | SCREAMER | Axial RR10 Bomber | 238 | 03-12-2016 09:17 PM |
Mighty's IFS KOH/Ultra build. "Outcast" | Mighty1 | 1.9 Scale Rigs | 27 | 06-28-2014 07:06 PM |
