03-16-2016, 09:28 PM | #1 |
Newbie Join Date: Oct 2011 Location: Roseville
| Bomber ESC/Motor
Hey all, I recently purchased a new bomber and before running upgraded it to have a Mamba Max Pro with a Castle 3800kv motor. My bomber is only going to be used for u4 and bashing which is why I went uncensored. I also upgraded the pinion only to a 14t. The thing hauls but I expected it to go a little faster on 3s. It topped out at 21mph. Is my gearing off? Also, i ran for about 35-40 mins and the motor felt pretty warm. It wasn't to the point I couldnt hold my finger against it, but it felt a little too hot to not be concerned. Thanks for any input! |
03-16-2016, 10:42 PM | #2 |
Rock Crawler Join Date: Dec 2013 Location: Sacramento
| Re: Bomber ESC/Motor
If you can hold your finger to it you're good. 14t spur with the stock 64t spur is definitely not overgeared. That is how mine is now. How long are the straights going to be? Sent from my SM-N910V using Tapatalk Last edited by DowntownScience; 03-16-2016 at 10:44 PM. |
03-16-2016, 10:48 PM | #3 |
Have you ever raced at APR? I'd guess about 100ft? the speed isnt that big of a deal, i just though 3800kv would have me moving about 30 lol
03-17-2016, 08:55 AM | #4 | |
| Re: Bomber ESC/Motor Quote:
Running a very similar setup to you. Top speed isn't super high but acceleration is pretty amazing. I think that is what you are looking for on the track. No point in gearing it for 30 mph if none of the straights are long enough to take advantage of that top end. You'll be accelerating and decelerating a greater portion. Sent from my SM-N910V using Tapatalk | |
03-17-2016, 09:08 AM | #5 | |
You aren't going to be able to distinguish what temp range you are in at those levels by touch so get a temp gauge. They are pretty cheap and your fingers will thank you. | |
03-17-2016, 11:31 AM | #6 |
Rock Stacker Join Date: Oct 2014 Location: Northern Los Angeles
From what I've observed 21mph is haulin ass with a Bomber. I hope mine moves like that when I'm done.
03-17-2016, 03:26 PM | #7 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
| Re: Bomber ESC/Motor |
03-17-2016, 04:59 PM | #8 |
20t seems like it would get really hot! 3.2 to 1 is like short course gearing! Sent from my SM-N910V using Tapatalk |
03-18-2016, 02:39 PM | #9 |
I downloaded DigiHUD for Android to see what speed my Bomber was going. Found a way to secure my phone to the Bomber with a velcro strap and ran it up and back on the street a few times. I hit 19.89 mph geared 14/64 Powered by a 13.5T (around 3300kV) Hobbywing sensored brushless motor on 2S. Sent from my SM-N910V using Tapatalk Last edited by DowntownScience; 03-18-2016 at 02:41 PM. |
03-20-2016, 08:57 AM | #10 |
Newbie Join Date: Aug 2015 Location: Somerset
is a Novak activ8 and HD8 2200kv overkill or good for rock racing? curious.....
03-20-2016, 09:57 AM | #11 |
2200kv is going to be better for crawling than rock racing unless on 3s. My .02 Sent from my SM-N910V using Tapatalk |
03-20-2016, 09:59 AM | #12 |
yes it would be on 3s, i wouldnt be crawling with it. i got my scx for crawling lol. i just want something durable and not worry about heat or anything.
03-20-2016, 10:35 AM | #13 |
03-20-2016, 12:22 PM | #14 |
Pebble Pounder Join Date: Jan 2016 Location: Worthing, England
I run a Roc 412 2300kv on 3s, geared 16/64 and it's a great speed without heat issues. Could probably go to 18/64 without issue.
09-25-2017, 02:54 PM | #15 | |
Pebble Pounder Join Date: Aug 2017 Location: Home
It crawls pretty well. In low even with that sensorless motor it felt smooth like a brushed motor but with power and wheel speed of brushless., | |
09-25-2017, 04:57 PM | #16 |
Rock Stacker Join Date: Jun 2011 Location: girard
Whats everybody opinion of the castle sidewinder 1410-3800 and gearing it down to the 11/68. I just bought a crawl master 13 and geared it at that per holmes website but with how I drive in yard with the kids (stampede and slash) I'm afraid I'm going to trash that motor. Would that brushless run ok at that gear ratio.
09-25-2017, 05:17 PM | #17 |
Newbie Join Date: Dec 2016 Location: SW Michigan
I'm currently running a Castle Sidewinder ESC with the SCT 1410-3800 motor and factory gearing, and it works fine on either 2S or 3S (depending upon your level of trigger finger control on that particular day). Eventually, I'll swap out this system for a sensored setup with a motor more in the 3000 kV range, but that's a want and not an immediate need. |
10-03-2017, 07:59 PM | #18 |
| Re: Bomber ESC/Motor I don't know what's going on with that setup or what tires you're running but I run a sidewinder 3+vanguard 3150kv motor. Since it's sensorless I put the 2spd kit on it with the .93 gearing. Wearing Proline Hyrax 2.2's it ran 27.5MPH on GPS. It's a bit more speed than I liked so I swapped the gearing to 1.08 and it still GPS'd at 24MPH. That's all on 3s with a 14t pinion and 64t spur.
Bomber ESC/Motor - Similar Threads | ||||
Yeti Motor/ESC in RR10 Bomber | sean_cj7 | Axial RR10 Bomber | 27 | 09-11-2017 02:15 PM |
Motor for the bomber | Cork | Axial RR10 Bomber | 14 | 02-19-2017 06:39 PM |
Bomber motor mount | jwall046 | Axial RR10 Bomber | 9 | 02-04-2016 08:01 PM |
Sidewinder esc and 5700 motor or Traxxas vxl 3s esc with brushless motor? | THE CRAWLER KING | Newbie General | 6 | 08-22-2010 07:10 AM |
