03-27-2016, 12:53 AM | #1 |
Newbie Join Date: Jan 2016 Location: Germany
| weight of your bomber
OK, I´ve read not that much about the weights ... some Bombers might be quite heavy, some builds are lightweights. What is the weight of your bomber and what is the range of use? My RR10 has a weight of 3230g / 114oz including 3S 3200, powered by a 3800KV 550+ sized brushless. She is running mostly onroad (~ 30mph) or in a scatepark - no rocks, no dirt but a lot of fun anyway. Heavy parts: Motor + esc, beef tubes in front, drive shafts. Light parts: Tranny (AX10) |
03-27-2016, 11:35 AM | #2 |
| Re: weight of your bomber
I just weighed my IFS build last night. With battery it's 8.8lbs. It's primary use is trail machine and Rock bouncer. By comparison my dedicated crawler bomber is only 8.2lbs with battery so for me, going IFS only added roughly half a pound.
03-27-2016, 11:36 AM | #3 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
I'm working on a lightweight crawling rig - Levior* - Becher's Bomber Build. It started out as a bomber but I think I'm going to re-use my old wraith chassis for it. Nonetheless, it's nearly the same thing. I'm shooting for less than 5 lbs (~2200 g) and it's going to be dedicated crawler. The biggest weight savings is in the tires, the stock Bomber tires weight a lot. While this would help stability at speed, that's not what I'm looking for in this build. I've made some more progress on it so I'll update the thread later today.
03-27-2016, 08:37 PM | #4 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
I'm at 9 lbs with battery. Dual shocks at all 4 corners, 2-speed conversion, lots of aluminum (axles, wheels, knuckles, c's, lockouts, TAs) and titanium (links) all add to the weight. But it all works very well.
03-28-2016, 01:07 AM | #5 |
The range is from 5lbs / ~2200g up to 9lbs / ~4100g ... this is more difference that I´ve expected. My bomber is actually in the middle (7,1 lbs). Now will I try to save some weight AND add rigidity - remember, she is an onroad- and skatepark - basher! The parts which should to be beefier are: - rear axle shafts (bend easyly at highspeed-rolls, see video) - is there a bulletproofed alternative? - shocks (after stock and RC4WD King dual spring now I will check the gmade piggybacks 83/103mm). I see most potential to save weight in: - tires (actually: ProLine Prime 2.8" 10116-15) >> foamys? - motor (actually: tenshock 401, 3800KV, 270g) >> 540 sized or stubby? - ESC (actually: Turnigy 120A) >> ? (CC sidewinder, HPI vapor flux, ...?) Do you have any suggestions to get a rigid, lightweight bomber basher? https://www.youtube.com/watch?v=9xvv89HXuXw |
03-28-2016, 03:25 AM | #6 |
Pebble Pounder Join Date: Jan 2016 Location: Worthing, England
Mine sits at around 9.4lbs without the battery. Running beef tubes in both axles though.
03-28-2016, 10:42 AM | #7 | |
Quarry Creeper Join Date: Dec 2009 Location: Cape Cod
I just put mine on the scale, it is right at 8 pounds with the battery. I have added some weight: Brass beef tubes in front axle Metal steering servo Dlux 1/4" front lower links SSD Ti steering links Axial metal motor mount Traxxas Titan 21T motor (don't remember specific weight, but it was significantly heavier than the Axial 35T) Axial 2 speed trans with shift servo UCfab rear trailing arms VP rear upper links I am going to be adding weight in the form of RC4wd Rock Racer beadlocks, better tires, and beef tubes in the rear axle soon. The stock tire assembly weighs 6.9 oz, my new wheels will be 3.24 oz each and a Voodoo U4 tire with a DW foam weighs 5.1 oz. The RBII tires are listed at 5.2 oz each. Net the new tire assemblies should add 7.0 oz and the rear beef tubes 1.5 oz. This would put the weight at 8.5 pounds. I may ditch the spare tire in favor of keeping the weight down. I don't know where else I can cut while keeping the metal links for strength. I still have plastic chubs and knuckles up front and plastic lockouts in the rear. I could go to a smaller battery, but I already spent the cash on two 5000 mah 3S soft packs (12.9 oz) for the Bomber. Quote:
03-28-2016, 12:04 PM | #8 | |
| Re: weight of your bomber Quote:
The front diff is unlocked alrready and filled with 500k-Oil. I´ll check 2.500k-oil at next maintenance. The shocks work not optimal, I replace them soon with gmade piggybacks. The ProLine 2.8 tires are too grippy, is Proline offering them in a harder compound? A little drift would be funnier than a rollover | |
08-31-2017, 01:38 AM | #9 |
Rock Stacker Join Date: Sep 2014 Location: Belgium
Mine is at a staggering 4.7kg that's almost 10lbs I believe .... It's on a diet now . Swapped out my 1/8 setup for a mamba x with 1406 2850kv. Bye bye stainless steel body panels . Keeping the hot racing 2-speed but still weighs 3.9kg now ...damn |
03-08-2018, 07:59 AM | #10 |
Newbie Join Date: Jul 2017 Location: Denver
7.5 pounds here Wraith trans, dig unit with servo, 2.2 tires, stainless front links, stainless rear upper, aluminum rear lower. Vented aluminum deck instead of the plastic interior. Mamba X, 3800kv motor. |
03-08-2018, 02:15 PM | #11 |
7.1# with 5000mAh 2s battery.
03-14-2018, 05:47 PM | #12 |
Rock Stacker Join Date: Jan 2017 Location: Chicago
I just weighed mine after the winter rebuild. Scale said 10.00lbs. That is up from 8.something. I added VP Currie F9s , and stainless links. I also run a 5300mah battery. I will see what the run times look like. I may try the CC1410 motor in it again. It seems a bit sluggish off the line with the CC 1406. Sent from my Moto Z (2) using Tapatalk |
06-04-2018, 01:05 PM | #13 |
Newbie Join Date: Apr 2018 Location: Corona
8lbs/12oz without LiPo
06-04-2018, 01:45 PM | #14 | |
Quarry Creeper Join Date: Mar 2018 Location: Park Hills
My Bomber weights a tad over 10 pounds with battery also, with all VP upgrades and stainless links also. Keep bending axle shafts >.< | |
06-04-2018, 06:44 PM | #15 |
Bathroom scale says 10lbs, my accurate scale says EEEEEE... Running a holmes hobbies servo. Last edited by Voodoobrew; 06-10-2018 at 06:46 PM. |
06-05-2018, 06:54 AM | #16 |
Rock Stacker Join Date: Dec 2012 Location: HESPERIA, SoCAL
8.8 lbs and gaining with brass tubes. Already have brass knuckles installed. 3000kv SENT from THE DARK SIDE of THE MOON |
06-05-2018, 07:53 AM | #17 |
My new bomber is a bit lighter than my old one, 7.9 lbs without battery currently. I am planning over the long term to change the links from SS to titanium.
06-05-2018, 04:56 PM | #18 |
| Re: weight of your bomber What kind of axle shafts are you running?
06-05-2018, 05:50 PM | #19 |
| Re: weight of your bomber VP Currie F9s, VP Knuckles and C-Hubs, stock gears and shafts. No bending yet. However my Savox 1210 has had the gears ripped from it twice. Running a PL servo saver now and the breakage has stopped. Sent from my Moto Z (2) using Tapatalk |
06-10-2018, 02:11 PM | #20 |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
I'm sitting at about 4.8 lbs rtr. If I can ever get the damn rear axle to go together. Sent from my Pixel 2 XL using Tapatalk |
weight of your bomber - Similar Threads | ||||
wheel weight vs knuckle or axle weight vs creative weight distribution | tech712 | Axial SCX-10 | 16 | 11-04-2014 01:04 PM |
Wheel weight / axle weight advice | JeffK11 | RC4WD Bully | 6 | 03-15-2012 03:30 PM |
Wheel weight vs. chassis weight ratio OR spung/unsprung bias | solomon7 | Tires and Wheels | 15 | 08-02-2008 06:26 PM |
