04-07-2016, 01:11 PM | #1 |
Newbie Join Date: Mar 2016 Location: US
| My RR10 build
Looking for a bit of help. Getting an idea of exactly what I'm wanting to purchase before buying the wrong stuff. What I'm looking to do: Mainly trails. Not building for comps by any means. Terrain will be mix of rock, mud, sand, and dirt. Midwest creeks. Loose rocky muddy hills as well. Not at all racing. Wanting about 10mph top speed for tire cleanout and steeper hills. Also wanting better crawl control as I will mostly be moving slow. My idea so far: Vanquish rockjock currie axles front and rear. Vanquish chubs and knuckles Vanquish HD axle shafts Ssd driveshafts Vanquish titanium steering and suspension links Vanquish servo armor Method 2.2 wheels Beef tubes front and rear. Deuces 2 stage foams Pitbull rock beast xor tires Savox 1230 steering servo Holmes revolver 540 1800 kv motor Mamba Max pro esc Axial 2 speed kit What I'm unsure about: Gearing Size bec Will I have any issues with all of this? Is this setup good for what I'm wanting? Any and all input is greatly appreciated. Thank you. Sent from my HTC6535LVW using Tapatalk |
04-07-2016, 01:19 PM | #2 |
| Re: My RR10 build
You won't be able to install beef tubes with Curries. RockBeast XORs will look ridiculous on VP methods so I assume you mean plastic Axial methods. I have that combo with CI foams and they are great. If you can't catch a revolver in stock then the Puller Pro 540 2100kv is a great motor which I also run. Go with stock gearing but underdrive the front and rear axles with 43/13 HD gears. That'll reduce torque twist and put you closer to the speed you want. Wait until you're done with everything else before going 2 speed. You may realize it's pointless. Just get the 10amp castle BEC for $20. Last edited by SCREAMER; 04-07-2016 at 01:22 PM. |
04-07-2016, 01:23 PM | #3 |
Rock Crawler Join Date: Nov 2013 Location: In the country
| Re: My RR10 build
Hi, I would buy stainless links instead of titanium for lcg and cost. Voodoo u4 tires instead pit-bull xor (a good tire but wider rim is recommended). Nice set of pro-line shocks Locker Was a new steering servo on the list? j.e.c racing trailing arms (bullet proof) Have fun with this. I'm still building mine, lol |
04-07-2016, 01:35 PM | #4 |
| Re: My RR10 build
Good idea on the stainless links. Are the jec trailing arms better than vanquish? Sent from my HTC6535LVW using Tapatalk |
04-07-2016, 01:36 PM | #5 |
| Re: My RR10 build
And yes on the servo. Savox 1230 unless I find better. Sent from my HTC6535LVW using Tapatalk |
04-07-2016, 01:39 PM | #6 |
| Re: My RR10 build
I already have the 2 speed. As for the beef tubes I wasn't for sure, I guess I'll have to get beef patties instead. I haven't thought much in the shock area, the stock kings work fine for right now. I really don't want to swap my tires for Voodoo. Everyone runs them and I'm not any more impressed with them over the xor for my application. Sent from my HTC6535LVW using Tapatalk |
04-07-2016, 02:07 PM | #7 |
| Re: My RR10 build
I would skip the servo armor and just get a Savox 1283 or Holmes HV500 to kill 2 birds with 1 stone.
04-07-2016, 02:12 PM | #8 |
| Re: My RR10 build
Servo armor is more just for weight. But I'll look into those servos Sent from my HTC6535LVW using Tapatalk |
04-07-2016, 02:14 PM | #9 | |
| Re: My RR10 build Quote:
J.E.C Racing ta's are stainless steel, recessed ends and some weight down low. They are unbreakable (lifetime warranty). | |
04-07-2016, 02:15 PM | #10 |
| Re: My RR10 build
I like xors as well : ) I was just told I needed gear head rims (wider) to fill out the tire better. |
04-07-2016, 02:21 PM | #11 |
| Re: My RR10 build
I might be partially biased as I ran pit bulls on my real rig. But I am fully satisfied with their all around performance. The axial 2.2 I have right now fills them fine. But I'm wanting to ditch the axial weight rings and just get aluminum wheels. Sent from my HTC6535LVW using Tapatalk |
04-07-2016, 02:27 PM | #12 | |
04-07-2016, 02:42 PM | #13 |
| Re: My RR10 build
I just checked them out. I'm actually preferring them over methods Sent from my HTC6535LVW using Tapatalk |
04-07-2016, 03:07 PM | #14 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
| Re: My RR10 build
too add on a little; i personally would skip the beef patties and go with a non rotational knuckle weight like rc bros, or blue monkey. It's better to keep "rotational mass" off the drivetrain. Makes axles/gears/shafts last longer. I initially like you thought I wanted beef patties but the good gents here on RCC steered me in the right direction. Oh and also, I thought I read somewhere that one of the Vanquish axles accepts beef tubes...right? |
04-07-2016, 03:15 PM | #15 |
| Re: My RR10 build
Yes but it was VP's version 1 OCP that is no longer being made. V2s are thicker walled and can't fit them but wouldn't need them anyway. Any quality aluminum axle housing will add weight and strength. Beef tubes are more intended to be used on the plastic AR60s. It's a good way to get less expensive strength and weight in the axle.
04-07-2016, 03:17 PM | #16 |
| Re: My RR10 build
Their site says only the version 1 housing. Not sure which one that is Sent from my HTC6535LVW using Tapatalk |
04-07-2016, 06:10 PM | #17 |
Quarry Creeper Join Date: Apr 2015 Location: Georgia
| Re: My RR10 build
You should look into the Currie f9s they're cheaper and looks great under the bomber I had some mounted under my bomber but decided it would be best to throw my Currie rock jocks under my wraith and order a set of f9s! Just my opinion but you have a great list so far |
04-07-2016, 07:39 PM | #18 |
| Re: My RR10 build
Performance wise they were the same? The rockjock looks like it could take more abuse. Sent from my HTC6535LVW using Tapatalk |
04-07-2016, 07:42 PM | #19 |
| Re: My RR10 build
Also, the blue monkey weights look like the way to go. Thanks for the input! Sent from my HTC6535LVW using Tapatalk |
04-09-2016, 12:27 PM | #20 |
| Re: My RR10 build
New! Updated my build sheet listing most prices and most parts. Once again any input is greatly appreciated. Anything I may have missed or anything that I don't need or even anything that could be replaced with a better product. Also different places to buy with better pricing. Nothing is ordered yet. Just what I've thought of so far. Some items are out of stock but this will be built over time as stuff becomes available. Thanks! Vanquish AXIAL WRAITH FRONT CURRIE AXLE BLACK ANODIZED $169.00 AXIAL WRAITH REAR CURRIE AXLE BLACK ANODIZED $140.50 VANQUISH AR60 AXLE SERVO MOUNT BLACK ANODIZED $11.99 AXIAL WRAITH / XR10 C-HUBS BLACK ANODIZED $45.00 KNUCKLE BUSHINGS (4PCS) $6.99 AXIAL WRAITH STEERING KNUCKLES BLACK ANODIZED $39.99 WRAITH VVD V1-HD $64.95 AXIAL HEAVY DUTY BEVEL GEAR SET - 43T/13T $31.50 INCISION RR10 BOMBER 1/4 STAINLESS STEEL 8PCS LINK KIT $43.99 12MM HEX BLACK ANODIZED $13.50 INCISION SPOOL/LOCKER $18.99 AXIAL AR60 AXLE SEALED BEARING KIT (SINGLE AXLE SET) $9.99 VANQUISH YETI MOTOR CAM CLEAR ANODIZED $16.99 VANQUISH YETI MOTOR PLATE CLEAR ANODIZED $26.99 CURRIE ANTIROCK YETI SWAY BAR BLACK ANODIZED $44.95 VANQUISH ALUMINUM SERVO ARMOR BLACK ANODIZED $29.99 AR60 OCP REAR AXLE SET (2PCS) AX30776 $21.00 * SSD TITANIUM STEERING LINKS FOR AXIAL AR60 AXLE * Blue Monkey RC MIP CVD Driveshaft kit for Axial RR10 Bomber*$69.99 Trailing Arms for Bomber**$49.99 Knuckle Weight System for VP Wraith Knuckles $49.99 * Gearhead RC Gear Head RC 2.2 BTR TT Beadlock Wheels (4)*$169.99 * Proline PowerStroke XT Shocks (5” Length) for Yeti Rear, Solid Axle Monster Trucks and Custom Builds $63.71 * Amazon Axial RR10 Bomber 1/10th Stainless Screw Kit $29.95 + $6.10 shipping Axial Yeti & RR10 Bomber Upgrade Parts Aluminum Spur Gear Case - 1 Pc Gray Silver $24.70 + $4.49 shipping Axial Yeti & RR10 Bomber Upgrade Parts Aluminum Spur Gear Cover Plate - 1Pc Set Titanium $16.20 + $4.49 shipping * Savox Savox SA-1230SG Monster Torque Coreless Steel Gear Digital Servo-savsa1230sg $69.99 * Homes Hobbies Holmes Hobbies Revolver 540 1800KV $134.99 Castle Creations Mamba Monster X $161.50 Castle Creations BEC 10A $21.99 * * * Sent from my HTC6535LVW using Tapatalk |
My RR10 build - Similar Threads | ||||
Yoda's RR10 Bomber Build... B1B IFS! | 84yoda | Axial RR10 Bomber | 80 | 04-03-2023 02:07 PM |
bilinvic's RR10 Bomber Build | bilinvic | Axial RR10 Bomber | 712 | 04-25-2020 08:09 AM |
nfcrockett's RR10 Bomber Build | nfcrockett | Axial RR10 Bomber | 28 | 06-27-2016 08:24 PM |
My RR10 bomber build. | mklemp2015 | General Crawlers | 2 | 04-07-2016 10:06 PM |
Forestbumpr's RR10 Bomber Build | forestbumpr | Axial RR10 Bomber | 29 | 12-28-2015 09:12 PM |
