04-12-2016, 06:50 AM | #1 |
Rock Crawler Join Date: Feb 2010 Location: Central/SE Ohio
| Bomber/Yeti motor mount ?
They both share the same transmission so I assume Yeti aluminum-machined motor mounts work in the RR10 as well? Strc, Gpm, vanquish, hot racing and axial all make yeti machined aluminum motor mounts and cam. Does any one of these stand out in Performance and functionality. I'm just looking for a more solid attachment to help alleviate any flexing under torque. |
04-12-2016, 06:56 AM | #2 |
Rock Crawler Join Date: Nov 2013 Location: In the country
| Re: Bomber/Yeti motor mount ?
Pretty sure they all work well. Some are better priced. I have strc. J.A.W - just another wraith & a Bomber! |
04-12-2016, 07:55 AM | #3 |
Yes they are the same front half of the transmission. The only difference is the transfer cases. Make sure whichever one you choose actually comes with the motor mount plate. Hot Racing for instance does not. I run the Axial one and it's very nice.
04-12-2016, 08:08 AM | #4 | |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Bomber/Yeti motor mount ? Quote:
04-12-2016, 08:17 AM | #5 |
RCC Addict Join Date: May 2009 Location: Weston
| Re: Bomber/Yeti motor mount ? The VP one looks pretty nice too. I bought the STRC one and had to sand down the sides to get it tight enough to hold the included motor mount so it wouldn't spin. .
04-12-2016, 08:38 AM | #6 | |
I have 2 STRC mounts, both have moved on me while driving. They will both be getting filed before they are run again. | |
04-12-2016, 10:48 AM | #7 |
Quarry Creeper Join Date: Dec 2014 Location: Sacramento
2 out of 3 of my STRC mounts move. Something to watch out for.
04-12-2016, 11:08 AM | #8 |
Pebble Pounder Join Date: Feb 2014 Location: tucson
Not sure if it makes a difference for this application. But the Axial motor mount and motor plate are hard anodized. So the surface will be a little harder than bare aluminum and harder than standard anodized parts. Just something to consider.
04-12-2016, 11:11 AM | #9 |
Pebble Pounder Join Date: Jan 2016 Location: Worthing, England
I use the GPM one it's solid and never moved on me.
04-12-2016, 11:16 AM | #10 |
Geeze, I guess STRC isn't that good then. Having the mount move on you like that could really cause some damage. I'll edit my first post. I really like my Axial mount. You can pick one up for right at $40 shipped on eBay and mine hasn't budged since the first install and I check my gear mesh often. Maslin, maybe get the VP motor plate next time you make an order? Cool that they offer them separately from the trans mount.
04-12-2016, 11:18 AM | #11 |
Rock Crawler Join Date: Jan 2014 Location: Frog Lake AB, Canada
I used the axial version on my bomber. For the same reason listed above the anodizing is slightly stronger.
04-12-2016, 11:30 AM | #12 | |
But for $16 it's on the way Just when I say I don't have that many VP parts I order like 5 more | |
04-12-2016, 11:38 AM | #13 |
Quarry Creeper Join Date: Nov 2014 Location: WA
Interesting hear about the STRC. I never had problems with mine in the Yeti, and a have tons of power there (MMX/540XL). Was even planning in get the vanquish for the Yeti and move the STRC for the bomber when I get the MMX/540 for it. |
04-12-2016, 11:47 AM | #14 |
| Re: Bomber/Yeti motor mount ? My bad, I didn't see that. I'm glad you did. I wonder what is different about the plate that wouldn't let it fit the stock or other clamps. We'll soon find out...
04-12-2016, 12:06 PM | #15 |
Newbie Join Date: Jul 2015 Location: Lenoir City, TN
I have the strc one, using with no issues at all. Used on my yeti before I got a bomber.
04-12-2016, 01:35 PM | #16 |
When you guys mention the motor mount plate; your talking about the "cam" type oval that bolts to the motor or are you talking about a shim plate that also bolts to the motor behind the cam? The stock plastic setup has a motor shim plate then the cam. So it's a 3 piece design. say wanted to order the Vanquish motor mount I'd also need to order a cam and a plate. Correct?
04-12-2016, 01:44 PM | #17 |
I didn't know there was a shim. Yes, there's a motor mount plate and the cam plate. I didn't use a shim when I bolted up my Holmes brushless motor to the Axial mount. You'll just need the two main pieces. If the motor is too deep or shallow simply turn the pinion around to line up with the spur better.
Bomber/Yeti motor mount ? - Similar Threads | ||||
Yeti Motor/ESC in RR10 Bomber | sean_cj7 | Axial RR10 Bomber | 27 | 09-11-2017 02:15 PM |
Bomber motor mount | jwall046 | Axial RR10 Bomber | 9 | 02-04-2016 08:01 PM |
Axial Yeti Hard Annodized Motor Mount? | ratrod63 | Axial Yeti | 11 | 01-31-2015 09:27 PM |
