04-16-2016, 09:12 PM | #1 |
Rock Stacker Join Date: Mar 2016 Location: in a van down by the river
| Spare Tire mod on the cheap.
While I was charging batteries for tomorrow and trying to clean off my mess of a work bench I came across some spare G10 control arms for my 50cc 3dhs slick airplane. s Sliced off the plastic hub flush on the stock carrier with and exacto blade. Trimmed the G10 control arm and bolted to stock location. Re-used the stock hub I cut off and screw. |
04-16-2016, 09:36 PM | #2 |
Rock Crawler Join Date: Jul 2015 Location: McKinney, TX
| Re: Spare Tire mod on the cheap.
Nice. Bonus "nice" for giving me a use for all my old Intel boxes I just can't throw away.
07-23-2017, 01:16 PM | #3 | |
Newbie Join Date: Jul 2017 Location: Northern
| Re: Spare Tire mod on the cheap. Quote:
07-23-2017, 01:35 PM | #4 |
RCC Addict Join Date: Aug 2013 Location: Missoula
Curious how it holds up to some solid rolls. Mine is moved forward with 1:1 U joint cap zip tied under the frame rails in front of the stock mount. Drilled a hole through the high spot with a long bolt to hold the wheel. A screw from the inside of the fuel cell (and through the side of the cage) gives a fuel hose something to push on to |
07-23-2017, 02:29 PM | #5 |
Rock Stacker Join Date: Jan 2008 Location: New Milford
Whats the spare for? if i get a flat I can pick it up and carry it home... (I know its for scale appearance) |
07-23-2017, 02:44 PM | #6 |
It's for balance as much as scale appearance. Pull the spare off and it nose dives quick in the air. Little bit of throttle keeps the front end up with the extra weight hanging back there Bomber was designed as a go-fast evolution of the Wraith. There are a ton of concessions made for speed over crawling. |
07-23-2017, 03:44 PM | #7 |
Ah ha. I got it for crawling, speed is not important.I'm going to wait and see what Barndog does, I suggested adding a tire relocator to his fast back body panel. If not I'll hack up something.
01-20-2019, 11:14 AM | #8 |
Newbie Join Date: Feb 2013 Location: BC Canada
My cheap spare tire mod is to cut and flip the stock spare mount and then add an old scx10 mount to the fuel cell, for all you guys wanting scale points it looks like there is still room for a fuel line off the cell |
Spare Tire mod on the cheap. - Similar Threads | ||||
cheap spare tire | amped up | Tires and Wheels | 5 | 01-14-2016 07:39 AM |
Spare tire Hex carrier mod | themacguru1 | Axial Yeti XL | 3 | 09-07-2015 08:14 PM |
ORA's Hammer - battery tray/spare tire mod | offroadace | Vaterra Twin Hammers | 6 | 03-17-2013 12:23 PM |
Axial Wraith Spare Tire Mod | THEKrawlerKID4 | Axial Wraith | 25 | 01-29-2013 07:49 PM |
Wraiths spare tire mod with 4 wheel steering build - help | bikeboy | Axial Wraith | 2 | 10-08-2011 03:45 PM |
