04-28-2016, 09:23 AM | #1 |
Rock Stacker Join Date: Dec 2004 Location: Parker, CO
| Vanquish anti-rock mounted at rear of frame?
I currently have my anti-rock mounted in front of the rear axle, but I just ordered some twin hammers length trailing arms. In planning for the future, I am thinking switching the sway bar to the back of the frame would be a better position. However, I do not see how it mounts on the back. Those two mounts on the back of the frame look like they are too small for the brass sleeves that the spring slindes inside of. Can anyone show me an example of how they mounted the anti-rock in that rearward position? Thanks! |
04-28-2016, 09:45 AM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Vanquish anti-rock mounted at rear of frame?
The mounts in the rear are Wriath style, the bar goes straight through the holes. The sleeves are used to space the arms out to clear the frame.
04-28-2016, 10:02 AM | #3 |
| Re: Vanquish anti-rock mounted at rear of frame? |
04-28-2016, 10:28 AM | #4 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Your options to mount it back there are find exact bar diameter and make a long bar, or cut down brass bushings or carefully drill it out to fit the brass bushing. But its tricky since if you drill it out for brass bushing, the plastic will be super thin and possibly break. So you have to drill the hole bigger but drill it out higher so the bottom thickness stays the same (if that makes sense). But either way, you still have to drill out rear mounts to fit vp bar.
04-28-2016, 12:20 PM | #5 | |
| Re: Vanquish anti-rock mounted at rear of frame? Quote:
Vanquish anti-rock mounted at rear of frame? - Similar Threads | ||||
Wreckluse frame mounted servo | Onebdgti | 2.2 Scale Rigs | 3 | 06-21-2011 08:20 AM |
Frame mounted servo | StigAre | Axial SCX-10 | 15 | 03-21-2011 11:00 PM |
Need help frame mounted servo | gordy | Paint and Body | 2 | 12-03-2010 08:16 PM |
Frame mounted servo for MRC? | fbuonpensiero | Losi Mini-Rock Crawler | 6 | 01-11-2010 05:12 PM |
Frame mounted steering servo? | slobert | 2.2 Scale Rigs | 28 | 09-02-2008 11:45 PM |
