06-24-2016, 08:44 AM | #21 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Re: Projekt "G" Build Less work more play |
06-24-2016, 08:47 AM | #22 |
06-24-2016, 08:51 AM | #23 |
So that's a wrap on last nights progress. Up next, painting the interior, panels and start the cage. Need to do some reading about lexan painting since it'll be my first experience with it. Less work more play |
06-24-2016, 09:49 AM | #24 |
Pebble Pounder Join Date: Oct 2006 Location: Montreal
| Re: Projekt "G" Build Just make sure you use proper lexan paint! I'm looking forward to seeing those wheels/tires all mounted up. The gold accents look pretty sweet!
06-24-2016, 10:08 AM | #25 |
Thanks kid, I'm really happy with how it's lookin. Almost mounted them up last night but the wheels need another coat and would've had to disassemble them today. Got paint for lexan and plastic. Originally I was going to go with one color but I'm thinking about adding some sort of flare to it. Luckily a friend is about to paint his scx2 so I'm Gna pay close attention to the process.
06-24-2016, 11:03 AM | #26 |
Thanks. Almost bought the spawn kit but glad I waited for this instead.
06-24-2016, 03:26 PM | #27 |
Quarry Creeper Join Date: Jun 2013 Location: Canada
Do the shocks in the kit come with the machined delrin pistons? I didn't see them in your pic with all the shock parts.
06-24-2016, 04:13 PM | #28 |
1st pic of post 18 bottom left side. Not sure if they're Delrin or not. I didn't have to cut them of the parts tree though so maybe. They were in a separate bag that had the shafts, o-rings, washers, pistons etc.
06-24-2016, 11:04 PM | #29 |
Pebble Pounder Join Date: Sep 2014 Location: Canada
looking good! hopefully my stuff gets here fast. I already have some of the hop ups but not the kit lol
06-25-2016, 05:02 AM | #30 |
| Re: Projekt "G" Build ok cool, that's good to know. I'm used to seeing them in white. |
06-25-2016, 07:36 AM | #31 |
Swapped out the servo arm and got started with the cage/body mock up. Less work more play |
06-25-2016, 07:40 AM | #32 |
06-25-2016, 07:45 AM | #33 |
Temp started dropping so I pulled the interior out to spray it with liquid mask and got back to the cage. Did the scx2 @ the same time. Less work more play |
06-25-2016, 07:49 AM | #34 |
Front bumper and the battery access pivot. The flip hood is a really cool feature on this rig. Less work more play |
06-25-2016, 07:51 AM | #35 |
Wasn't Gna mess with the panels but couldn't resist. Less work more play |
06-25-2016, 07:56 AM | #36 |
You now how one thing leads to another? Well I couldn't stop once the panels were on so, of course, I had to mock it up to the chassis. Found my first mistake during this too. When I assembled the shocks I put the springs on backwards, front in rear and rear in front. So had to fix that real quick. I also noticed it had a nasty stance so I changed the shock locations around from where the instructions had told me to put the pivot balls in an earlier step. Less work more play |
06-25-2016, 08:00 AM | #37 |
On to one of my favorite parts of the build so far. Gold shoes. Painted up the "bead screws" and mounted some rubber. These wheels have the vent holes, set mine up with 2 holes per wheel and the stock foams for now. Less work more play |
06-25-2016, 08:07 AM | #38 |
Obviously had to mount these things up and get some pics. Really dig the stance on this rig and the way it's come out in just 3 days. Tall enough to fit half a Hulk underneath.lol Unfortunately the paint I bought for the lexan doesn't look the way I had hoped so this is where I stopped and have to go paint shopping. So here's "Goldmember" in it's current state. Less work more play |
06-25-2016, 08:09 AM | #39 |
06-25-2016, 08:10 AM | #40 |
A simulated late night cocktail crawl. Less work more play |
Projekt "G" Build - Similar Threads | ||||
Projekt " MBRP RattleTrap " RC | proudDocker | 1.9 Scale Rigs | 82 | 12-16-2014 09:03 PM |
Jkabee's "total noob" TJ build "this should be fun!" | jkabee | Axial SCX-10 | 128 | 03-24-2013 12:10 PM |
Chaotic Crawlers "DEMON" build! aka "Kreacher" | Mac10 | EnRoute Berg | 96 | 09-26-2010 01:49 PM |
PROJEKT "PREDATOR" by MARIO POLAND | mario4x4 | Axial AX-10 Scorpion | 0 | 03-14-2008 01:24 PM |
