10-11-2016, 06:57 PM | #81 |
| Jato The Bomber
Keep plugging, you've narrowed it way down. You said in the other that you could feel a difference when unplugged. Is your timing correct? Sensor position is all that remains . Stock motor is a 3150 vanguard ? If so gear down from what you had, by 2 due to wheel speed as you did the underdrive HANG UP AND DRIVE ! |
10-11-2016, 07:51 PM | #82 | |
| Re: Jato The Bomber Quote:
Sent from my SM-N910V using Tapatalk | |
10-11-2016, 08:06 PM | #83 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
| Re: Jato The Bomber
Mind posting a picture of your setup? As I'm sure you know, you have to use the castle sensor wire, it's different then the standard sensor wire.
10-11-2016, 08:33 PM | #84 | |
I cut and pasted the description for the cable if you buy it by itself from his site below: "The Castle Mamba Micro X and Mamba Monster X use a proprietary socket that is incompatible with standard sensor wires. This sensor wire is 5.5 inches in length and comes with a Mamba Micro/Monster X-compatible plug on the ESC side and standard six-pin sensor plug on the motor side." *please note, mine is not yet installed but I have faith in HH knowing what they are doing. Should Jato be making sure he has one of these? Just trying to help a brother out... | |
10-11-2016, 08:56 PM | #85 | |
10-11-2016, 09:21 PM | #86 |
| Re: Jato The Bomber
I have the Castle "sensor harness" as they call it. I've always been using it. Bought it at the same time as the ESC. You plug a regular sensor cable into Castle's, stupid, gimmicky "sensor harness". It's a bad design. More connectors and more places to have issues. The only time I unplugged the sensor cable was for testing to see if the cogging was worse without it. It was. Sent from my SM-N910V using Tapatalk |
10-11-2016, 10:18 PM | #87 |
| Re: Jato The Bomber
I totally agree on that X series harness adapter being total bullshit. It was really cool of Holmes to make a one piece replacement to eliminate a failure point. I need to order a couple or three of those next time I send some more of my retirement his way. I really hope you get this figured out Jato. The MMX is such a great ESC and its all I use now for my brushless setups. I bet it's that inferior Tekin motor, we tried to get you to buy a Holmes. |
10-12-2016, 07:00 AM | #88 | |
Thanks! I hope so too. I've always hated Castle since my very first experience with them and I swore them off for years, but I decided to give them another shot because this ESC is waterproof and more so because of the auxiliary wire. I friggin' love the auxiliary wire. LOL well I would have gotten the Holmes had they had the 2700kV in stock at the time. In hindsight the 3500kV probably would have been fine. Tekin is sending me a new sensor board for the motor. Castle is convinced it's not the ESC. Before doing any of this I'm going to try a different sensored motor on the MMX ESC. My LHS didn't have 6.5mm bullets so I ordred them from Tower last night. Now I wait... | |
10-12-2016, 08:09 AM | #89 |
| Re: Jato The Bomber
The 3500 would have been perfect....
10-12-2016, 08:39 AM | #90 |
| Re: Jato The Bomber |
10-12-2016, 09:33 AM | #91 | |
Don't forget which motor is in my bomber. | |
10-12-2016, 09:38 AM | #92 | |
Which motor are you using? I was looking at photos of my Bomber and noticed that I installed the diffs backwards. No harm, no foul I guess. The Axial logo on the diff cover is upside down, but it's not like you can see it. To me it looks better the way I have it, but I don't think that's "scale". Does anybody see this causing any issues? I don't think it will, but I'm just wondering if I'm missing something. Last edited by JatoTheRipper; 10-12-2016 at 09:40 AM. | |
10-12-2016, 11:07 AM | #93 |
| Re: Jato The Bomber
That's the side guys are flipping the ring gear to for the purpose of minimizing torque twist. You may have made a beneficial mistake but in any case it won't hurt anything at all. Stock Wraiths used to come with the ring gear on the right side.
10-12-2016, 11:30 AM | #94 |
| Re: Jato The Bomber Interesting! Thank you. Maybe that's why I haven't felt the need to tighten down my sway bar yet...
10-13-2016, 01:35 AM | #95 | |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Also, you have it plugged in the correct way into esc? White wire goes on right side. I remember reading someone installed it backwards and had cogging issues. | |
10-13-2016, 05:25 AM | #96 |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: Jato The Bomber
There's a 68t spur you can use or just go down on the pinion. Down to a 9t is available.
10-13-2016, 06:57 AM | #97 | |
Yes, I did double check the sensor wire was installed correctly. I might go up to the 68T spur if I decide I want more low-speed controllability, but I shouldn't have to do this to get rid of cogging. | |
10-13-2016, 10:36 AM | #98 | |
Quarry Creeper Join Date: Jul 2013 Location: PA
By the way, I totally dig the red! | |
10-13-2016, 11:24 AM | #99 | |
Thank you! | |
10-14-2016, 06:39 PM | #100 |
| Re: Jato The Bomber
I tried another sensored motor with my MMX. I'm still getting cogging at low throttle under load. What do you guys think of it? https://youtu.be/pO3w2rn5jrE Sent from my SM-N910V using Tapatalk |
Jato The Bomber - Similar Threads | ||||
Making Crawling bomber into trail rig bomber. | theTman | Axial RR10 Bomber | 2 | 06-10-2016 01:46 PM |
