01-31-2017, 07:42 PM | #41 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: To those running Proline Powerstroke Rear Slashes...
Not my video, I have a dex8, but just for fun. The VRP game changers are $28 a pair on sale right now. I've tried all combos of no bladder, bladder with foam, bleeder screw in, bleeder screw out, blah blah blah. Ended up back at full bladder, no foam, screws in. I really enjoy messing with the fast 1/8 stuff, no where to really push them out here though. |
02-01-2017, 04:01 AM | #42 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
I use the slash front and rear shocks on my bomber as well. I run between 10-20wt rear and 20-35wt front. Springs are a toss up. My only problem is a bounce when landing to flat after a jump. If I can back side my jumps the truck is smooth but most of my jumps are rather small and leave little area for error. I use the MIP bypass1 pistons in my B5M and love them. I wish I could get them for the prolines but MIP has discontinued them for all shocks. Several of the fast 2wd/4wd buggy guys use the VRP pistons at my local track. They seem to really like them. I'm just too cheap to spend 15$ for a pair of pistons |
02-01-2017, 07:03 AM | #43 | |
Pebble Pounder Join Date: Dec 2016 Location: Puerto Rico
| Re: To those running Proline Powerstroke Rear Slashes... Quote:
why is the strap holding the spring with the shock base? preventing the spring from getting out of place? i have a custom truggy and use power strokes in the rear and scaler proline in the front cause the front was waaay to high and had to use smaller fronts..thought about using softer springs and lighter wt oil to get the front a little down with the big powerstokes.... | |
02-01-2017, 08:23 AM | #44 |
I use it for everything, my Wraith hasn't left the house in a year. The zip ties keep the spring cup from disappearing, the powerstroke caps are pretty tight on the rod end, but it's basically free insurance. I have a set of the scalers laying around brand new. If the powerstokes are 14mm, the scalers are like 9mm. They offer very very little dampening on a rig this big. |
02-01-2017, 08:35 AM | #45 | |
yeah a couple of weeks ago lost 2 spring cups (easy fix then!) gonna try the powerstokes in the front with light wt oil, shorter rod end and soft springs to see if i can get them to go down just enough to get a proper ride height yeah those scalers look great and everything but the dampening is not enough Last edited by Jamifra; 02-01-2017 at 08:41 AM. | |
02-01-2017, 09:16 AM | #46 |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
I have been using metal wire to save my spring cups, but I like the zip tie idea better! May try a shorter rod end as well to lower the front a bit. I think the blue on blue spring setup for the front (using a rear slash length) is what it needs for my setup. Good stuff here. Thanks!
02-01-2017, 12:12 PM | #47 |
Have you guys seen or tried these? The m2c racing delrin proline powerstroke tapered 5hole shock piston-set? https://www.amainhobbies.com/m2c-rac...2c2755/p235453 |
02-01-2017, 12:15 PM | #48 |
Until I know what holes the pl shocks have buying more pistons is just a shot in the dark. Especially at that price.
02-01-2017, 12:24 PM | #49 | |
Rock Stacker Join Date: Feb 2016 Location: Under Your Hood
02-01-2017, 12:29 PM | #50 |
| Re: To those running Proline Powerstroke Rear Slashes... |
02-01-2017, 12:37 PM | #51 | |
NIICEEE! to bad they are on back order...but definetly gonna try these as soon as they are available | |
02-01-2017, 12:47 PM | #52 |
02-01-2017, 12:50 PM | #53 |
| Re: To those running Proline Powerstroke Rear Slashes... in the item description it states this.. This is an optional M2C Racing Tapered 5-Hole Shock Piston Set, and is intended for use with any vehicle equipped with Pro-Line PowerStroke shocks. These delirin 5-hole shock pistons will provide improved turn in, faster settling after jumps and are great through rough sections of track. The pistons feature a .075 deep taper and .8 through holes. |
02-01-2017, 12:50 PM | #54 |
RCC Addict Join Date: Aug 2005 Location: Oceano, CA
i have those M2C pistons in my Powerstrokes, but haven't really had enough run time on them installed to comment on their performance. it would be easy enough to drill out the Proline pistons and even countersink one side like the M2C design...
02-01-2017, 01:05 PM | #55 | |
I mean the whole size in the stock power stroke piston, Quote:
02-01-2017, 01:10 PM | #56 |
| Re: To those running Proline Powerstroke Rear Slashes... oh sorry lol only info available from Proline :/ PowerStoke Features: True dual-stage spring rate Aluminum body and shock cap Infinite spring pre-load adjustment Beefy 3.5mm shock shafts Injection molded, super durable spring retainer and shock ends Bladder sealed shock cap Free flow molded pistons Dual O-ring seats and upper and lower shock shaft guides Pre-assembled – just add oil! Fits stock Slash or ProTrac™ Suspension Kit for Slash |
02-01-2017, 01:37 PM | #57 |
I just emailed pro-line to see if we can get an answer on the stock hole size. With that said, you can order these M2C Racing pistons directly from them for a couple bucks more than Amain. I just ordered them. |
02-01-2017, 01:39 PM | #58 |
Would be nice if they'd publish the hole size. I'd guess that prolong would say between 1-2mm I have looked at a piston drilling kit and making some blanks just to drill for my own sick curiosity but I'm not very motivated. |
02-01-2017, 02:02 PM | #59 |
One can modify the holes on a ProLine piece.. But the tighter tolerance of the OD is also perking my interest.
02-01-2017, 03:22 PM | #60 | |
checked with amain and they are already on order but dont know eta so will just order from them directly Last edited by Jamifra; 02-01-2017 at 03:32 PM. | |
To those running Proline Powerstroke Rear Slashes... - Similar Threads | ||||
Proline Powerstroke shocks | Mr Quint | Axial Wraith | 6 | 08-16-2016 04:32 PM |
ProLine Powerstroke XT set up? | turbodan13 | Axial Yeti | 5 | 07-19-2016 10:12 PM |
