01-18-2017, 04:43 AM | #1 |
Pebble Pounder Join Date: Feb 2014 Location: Okinawa, Japan
| Gearing Suggestion; Hobbywing 3656SD 3400KV
I picked up a Hobbywing combo sensored 3656SD 3400KV motor with SCT Pro ESC. This motor has a 5mm shaft, so I will need to get a new pinion anyway. What is your suggestion for gearing? 3S Here is the combo, picked it up for $133 shipped: HobbyWing Xerun SCT Pro C3 3656SD 3400kv Sensored Brushless Combo for 1/10/th & 1/8th Scale SCT & Buggy Here is more info on the motor: https://www.hobbywingdirect.com/products/xrm3656sd Last edited by OkinawaCrawler; 01-18-2017 at 04:46 AM. |
01-18-2017, 08:19 AM | #2 |
RCC Addict Join Date: May 2009 Location: Weston
| Re: Gearing Suggestion; Hobbywing 3656SD 3400KV
Start with a 15t pinion and check temps to see what way you need to go.
01-18-2017, 08:54 AM | #3 |
RCC Addict Join Date: Aug 2008 Location: Paulina
I would stick with stock 12/64 and run there. My Puller Pro 3500kv is mighty happy at the ratio on 3s.
01-18-2017, 09:01 AM | #4 |
Too slow. I run a 16t with my 3500xl and wish I had a little more. To each their own I guess.
01-18-2017, 10:52 AM | #5 | |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
| Re: Gearing Suggestion; Hobbywing 3656SD 3400KV Quote:
I run my 1870kv motor on 3s with the trans in OD (flip the top and bottom gears inside so its 28:26 vs stock 26:28 but run the stock 12/64 and its PLENTY fast. I cant imagine needing to go any faster than stock gearing with a 3400kv motor. Hell id look at underdrive front n rear diffs at that point. Either way OP id stick with the stock 12T pinion (in a 5mm shaft). If you want a little more speed after that, do what i did and flip the internal transmission gears. | |
01-18-2017, 11:05 AM | #6 |
I ran a pro4hd 1850kv in a wraith trans a while back but that was on 4s with 16/54. Either I'm doing something wrong or you prefer a slow rig. They are racers not crawlers right?
01-18-2017, 11:12 AM | #7 |
RCC Addict Join Date: Aug 2013 Location: Missoula
I ran 13/64 3500kv on 3s for a while, bumped up to a 14t pinion with 2.2/3.0 wheels. Swapped the 2.2 back on and never changed from the 14t pinion. I can see 15t working, you're definitely into it money wise by that point. Just starting out I'd probably get like 12-15 and see what works. Pinions are cheap, probably the single cheapest thing you can buy. |
01-18-2017, 11:17 AM | #8 |
The most important thing is to check temps. Undergearing and running full throttle is just as bad as overgearing. Start with whatever you have. Check temps and run it to see if your happy with it. If you're not change the pinion and repeat.
01-18-2017, 12:21 PM | #9 |
Rock Stacker Join Date: Jan 2016 Location: North East Ohio, In the Lake
I was thinking of picking up the same setup. In for results. Actually looking at Hobbywing P/n: 81030190 SC-C1 https://www.hobbywingdirect.com/prod...10-sct-combo-1 Last edited by MD ENFORCER; 01-18-2017 at 12:49 PM. |
01-18-2017, 02:58 PM | #10 | |
I will try the stock 12T pinion. From what I read, a lot are still running stock. | |
01-18-2017, 05:41 PM | #11 |
Quarry Creeper Join Date: Jul 2013 Location: PA
I run 12/64 3500KV 4s for nasty wheelspeed, and 3s for a perfect all around rig
01-18-2017, 06:54 PM | #12 |
| Re: Gearing Suggestion; Hobbywing 3656SD 3400KV |
01-18-2017, 06:58 PM | #13 |
01-18-2017, 08:32 PM | #14 | |
They're good for 60k.... I do keep my eyes on the bearings.... most rpm I've logged "loaded" is 49k and change.... I am not suggesting this for anyone to do on their builds... and I do assume full responsibility if the motor looses a bearing. I will say under normal use, same gearing, 4s runs cooler.(from my testing). Most temp I've seen is 155 F. That was on the yeti. | |
01-18-2017, 11:18 PM | #15 |
A while back, I started running 4s in my IFS Bomber with a Holmes 3500kv Puller Pro standard. It's so nice to have that extra torque and wheelspeed on tap. I do try to drive a little less aggressively but so far there haven't been any issues. My IFS Bomber does have a Wraith trans in it though so it's a bit of apples to oranges. My gearing is 12/56. As far as OP's original question, I'd say stick with stock gearing, check temps, adjust from there. Swapping a motor, ESC, and changing gearing at the same time can do more harm than good unless you have enough experience with each of those variables to anticipate results fairly accurately. Last edited by SCREAMER; 01-18-2017 at 11:25 PM. |
01-18-2017, 11:45 PM | #16 | |
01-19-2017, 02:19 PM | #17 |
So did you get the HobbyWing combo yet? It looks like a great combo and that price is tough to pass up!
01-19-2017, 03:42 PM | #18 | |
I've had this combo in my Yeti though. The motor is 6mm longer than a standard 540 and has a ton of torque. You can't beat the price for $133 shipped with a 120a esc and programmer. I imagine there is limited stock of this combo though because hobbywing has released some new esc's and motors recently. They also have a 3652 can 3100kv that may be a roc412 equivalent for like $80. If someone does buy this combo, use fan5 at hobbypartz.com for 5% off. | |
01-19-2017, 04:01 PM | #19 |
Hey guys, here are the specs on the motor. Also, here is a link to the motor, if you look at the bottom, you can see the 3652 motor I was talking about and also a 3660 motor. both are around $80 https://www.hobbywingdirect.com/products/xrm3656sd P/N Xerun 3656 90100000 KV (no Load) 3400 Kv POLE 4 LiPo (V) 2-3S No Load Current (A) 3.80 Max. Output Power* 450W Max. Amp* 107A Diameter (mm) 35.8 Length w/o Shaft (mm) 56 Shaft dia. (mm) 5 Shaft length (mm) 18 Weight 210 |
Gearing Suggestion; Hobbywing 3656SD 3400KV - Similar Threads | ||||
Hobbywing Power | SCT Pro + 3656sd 3400kv | treys1 | Axial Wraith | 7 | 09-06-2015 05:39 AM |
HobbyWing 3400kv Sensored Xerun Gearing and settings? | OkinawaCrawler | Axial Yeti | 16 | 04-02-2015 10:54 PM |
