02-15-2017, 05:59 AM | #1 |
Pebble Pounder Join Date: Feb 2014 Location: Okinawa, Japan
| My Bomber Flips A lot
I've been bombing my bomber for a week now. I'm fairly used to my yeti...which doesn't flip much, so it may be the two solid axles, but it might be that with the soft foams. It's the kit version and seems to happen when changing direction at speed. If I upgrade my foams to deuces wild, will it flip less? or is this just how they are? |
02-15-2017, 06:10 AM | #2 |
| Re: My Bomber Flips A lot
The Bomber kit has a few things going on that don't help with high speed stability; the tire foams are soft allowing the sidewall to fold over while turning, much more steering angle than a Yeti which cause the tire to want to fold over more, and a track width that is much narrower than a Yeti. Tire foams that provide more sidewall support and lowering the ride height will go a long way in adding stability. |
02-15-2017, 07:48 AM | #3 | |
| Re: My Bomber Flips A lot Quote:
02-15-2017, 11:03 AM | #4 |
Quarry Creeper Join Date: Nov 2014 Location: WA
Bomber will never handle speed better than the Yeti. That said, lower the COG and firm foams will help.
02-15-2017, 11:16 AM | #5 |
Quarry Creeper Join Date: Oct 2016 Location: Hanover
Wider wheel hubs or axles will help with cornering stability as well |
02-15-2017, 02:00 PM | #6 |
Newbie Join Date: Nov 2016 Location: Piner
I found that it handled slightly better after I put the rear swaybar on also. Helps reduce body roll.
02-15-2017, 02:41 PM | #7 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
Swaybar helps quite a bit. Lower the rig if you wish (i keep mine up higher as its more of a crawling rig) Best thing has been foams though. I went with Comp cut double duces in a 5.5in medium outer and they work well... but if i had to go it again, with the stock tires, the 5.25in medium outer comp cuts would be a better fit. |
02-15-2017, 03:19 PM | #8 |
Quarry Creeper Join Date: Feb 2011 Location: Nevada
First thing my son and I did to our Bombers was install 90mm shocks in the front. Not only did it improve the stance, in my opinion, but it lowered the COG too.
02-15-2017, 08:51 PM | #9 | |
as simple as it is, I hadn't thought yet about widening the stance, suggestions on that? | |
02-17-2017, 08:17 AM | #10 |
Quarry Creeper Join Date: Nov 2015 Location: northwest
you can get different wheels or wheel spacers for that. I bought these wheels off ebay and they widened each side by about 3/8" and they look great too! Hard to beat the price and i was impressed with the quality. I have the dw foams and had to dremmel the foams down quite a bit to get them to fit. 4Pcs 2.2" Alu Wheel Rims 1/10 Beadlock For RC Crawler Wraith off road rc car #7 | eBay you can get method wheels and buy different spacing hubs as well. I think method hubs will work with the ebay wheels too. Or you can buy spacing hexes like these http://www.ebay.com/itm/112205807444...%3AMEBIDX%3AIT be sure to use locktight with these as they have a tendancy to come loose. |
02-17-2017, 08:21 AM | #11 |
looks like the wheels i got are out of stock, but these are available. 4pcs Alloy 1/10 RC Crawler 2.2" Beadlock Wheel Rims with Hub fr Wraith #8 | eBay Again, impressed with the quality for the price. |
02-17-2017, 08:23 AM | #12 |
Also, the stock foams work ok with these wheels cause the wheels are a bit narrower. you could try that first.
02-17-2017, 08:35 AM | #13 |
Quarry Creeper Join Date: Feb 2016 Location: Salt Lake City
It has been suggested; but, do you have a sway bar yet? If not, this helps a bunch. The Axial sway bar is stiff and would be great for the driving you are describing.
02-17-2017, 10:29 AM | #14 |
If you go too wide, you will hit your differentials and other axle housing parts on obstacles much more often - so moderation is best if going that route... don't want to start destroying those unnecessarily.
02-17-2017, 09:42 PM | #15 |
yes, you can break steering and axle parts more easily too. Just a bit seems to be best.
02-17-2017, 11:59 PM | #16 | |
Thanks for the input on wheels. Those look pretty alright for $60. | |
02-18-2017, 04:29 AM | #17 |
The upper links need to be spaced further apart on the axle side it realy stiffens up the suspention on the wraith the upper link on the axle side should be the same distance apart as the lower links on the skid side or close too it that will stop a lot of body role with out limiting articulation I know the bomber is a bit different in the rear but the theory is the same I can drift with my wraith now add sway bars on top of that and you have a high speed machine google 4 link suspention geomitry there are a lot of drawings and pictures out there that explain it all way better than I ever could Oh and its a free mod you just need longer bolts for the upper links to move the links to the outside of the truss mount you can always go back to the original set up if you don't like it Last edited by ferp420; 02-18-2017 at 04:40 AM. |
02-18-2017, 11:46 AM | #18 |
Newbie Join Date: Nov 2016 Location: Kirkland
Lowering the CG will help with roll overs but the biggest issue is, as your said, 2 solid Axles. On power turning will cause a lot of bite and roll her over. Opening one of the diffs will make you faster through the turns and should eliminate your roll overs. On low bite surfaces the solid axels work great because the wheel will slip, on high bite surfaces, on power turning is just too much grip for the solid axles. When it rolls over turn your wheel all the way the left and put it in reverse the solid axles should also be an assist in standing it back up. |
My Bomber Flips A lot - Similar Threads | ||||
How to get rid of flips when cornering fast? | swissete | Vaterra Twin Hammers | 13 | 05-14-2014 03:11 PM |
Flips | Scjustin | Videos! | 2 | 08-25-2012 04:46 PM |
diff flips | vman | Venom Creeper | 2 | 09-27-2009 06:49 PM |
MRC flips real easy.. | crusher44x | Losi Mini-Rock Crawler | 18 | 03-22-2009 04:13 PM |
