03-13-2017, 05:56 AM | #1 |
Rock Stacker Join Date: Aug 2008 Location: Grand Rapids
| Bomber Increase speed?
Just bought a Bomber after being out of RC's for probably a decade, only ever had Nitro so electric is new. Fun to play with, but this thing needs some more speed for outdoors. At the moment i'm running a 2S Lipo the hobby shop threw in with the car, is a 3S going to make a huge difference? Would like to get into the mid-high teens with harder acceleration but still keep the crawlability it has now. I'm not too serious into RC, but while i'm unable to wheel full size i figured this might add some cheap(er) entertainment (i.e. not looking to spend $300+ on a set up). For $175-$200 (or even less if there is a good option) what's the best set up available? I'm assuming I'll need to swap to heavy duty gears after this switch as well. I'd like to see how gearing is before deciding on the overdrive, stock or underdrive gear set. It looks like I can get a Mamba Max Pro for ~$85 which would leave me $90-$115 for a motor. It looks like this is a now obsolete ESC, any reason to sway to anything else? Thanks in advance Last edited by 06yz250f; 03-13-2017 at 06:21 AM. |
03-13-2017, 06:53 AM | #2 |
RCC Addict Join Date: Aug 2008 Location: Paulina
| Re: Bomber Increase speed?
I presume you bought the RTR version so 3s will definitely wake up the stock electronics. Check out SMC lipos. They make a 3s 4300mah that should be perfect. I would give this a shot first then upgrade electronics. Nothing wrong with the Mamba Max Pro (MMP for short). This ESC will still get the job done very well. The newer model is the Mamba X and it has a fancier case, factory waterproofing, adjustable AUX wire, and a few other items. The Tekin Roc412 and Pro4HD, Holmes Puller Pro are highly recommended but may be a click more that your remaining budget. Castle makes the 1410-3800 which is a great motor in the sensorless version but not too many case studies out yet on the new sensored version. I have one just haven't tested yet either but it's under the $90 mark so it would put you on track. |
03-13-2017, 07:42 AM | #3 | |
| Re: Bomber Increase speed? Quote:
The only thing I will add is that the Castle Mamba Monster X has the added feature of an auxiliary cable that allows you to toggle the drag brake on and off on the fly from your transmitter. This is great if you plan on going fast and crawling. But with that comes extra cost. | |
03-13-2017, 07:50 AM | #4 | |
Pebble Pounder Join Date: Dec 2012 Location: Delaware
03-13-2017, 08:56 AM | #5 |
I would run 3s untill the stock electronics burn out then you will have a better idea of what you want
03-13-2017, 08:59 AM | #6 |
| Re: Bomber Increase speed? |
03-13-2017, 09:00 AM | #7 |
Rock Stacker Join Date: Jan 2017 Location: Pflugerville, TX
I never had the stock motor, but mine had a Titan 21t 550 motor in it when I bought it used. It was decently fast on 3s, and the motors are inexpensive. Crawled pretty well, too, but I don't know how one crawls out of the box.
03-13-2017, 09:23 AM | #8 |
Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
3s for sure. Grab a 3s turnigy 5000mah battery from hobbyking along with the following... ($30) 80A hobbiking X-Car sensored / sensorless brushless ESC ($29) + Hobbyking X-Car Usb dongol ($5) + a Hobbyking or turnigy Sensored Motor of your speed liking ($35) Also grab a hobbywing UBEC as the bec of the x-car esc might not be able to power the servo / receiver under hard hard acceleration. ($5) Battery + a full sensored adjustable esc motor combo is going to be right around 115 shipped. Its what i run (with a turnigy 1870kv motor) and it will do ~15 mph, and has such smooth ability to crawl. |
03-13-2017, 09:31 AM | #9 | |
Realistically, if I can get the drag brake to act how it does stock (stopping the thing pretty quick), i'm good with that and don't need anything further. I do like the stock parameters a lot, minus the top speed performance and acceleration. My big issue is I don't want to spend money on a bad set up and want to re-do it after the fact, on the other hand I don't want to plop down hundreds of dollars for something I don't need. It seems like the Castle ESC's and Holmes Puller Pro is the way to go for most, but haven't run across any popular alternative set ups either on here. | |
03-13-2017, 09:55 AM | #10 | |
You could go HobbyWing, buy the WiFi module and program it from your smartphone. | |
03-13-2017, 09:58 AM | #11 |
Don't forget the new Mamba X and MMX also have a plenty strong internal selectable BEC. That allows you to upgrade your servo later when the stock one inevitably breaks and saves you from having to buy an external BEC to power it.
03-13-2017, 10:12 AM | #12 | |
Bootcamp. | |
03-13-2017, 10:33 AM | #13 |
RCC Addict Join Date: Aug 2013 Location: Missoula
03-13-2017, 11:09 AM | #14 | |
| Re: Bomber Increase speed? I run Parallels. I used bootcamp on my old Mac and it ran poorly so on my current i went with Parallels and ran Solidworks great comparatively (which makes no sense with how parallels works compared to bootcamp). However they like to discontinue support for a product after 2 years and force you into an upgraded verson. Right about that time my computer on the windows side quit reading USB's and connecting to the internet and tech support no longer helps so I just don't use it since my need for solidworks is gone. Quote:
I just know if I spend $300 here, $300 there, it quickly turns into a $1500 car so i'm trying to be budget friendly at each stage. | |
03-13-2017, 12:37 PM | #15 |
03-13-2017, 01:02 PM | #16 |
RCC Addict Join Date: May 2009 Location: Weston
MMP and a Team Brood Vigor 550 will put you right at $200 mark. Very good setup, tons of power and very durable. Get ready to drop at least another $300 building he rest of it around the power. |
03-13-2017, 01:32 PM | #17 |
03-13-2017, 01:41 PM | #18 |
No need for a monster x in a bomber. The Mamba x is plenty and still an upgrade over the MMP.
03-13-2017, 01:47 PM | #19 |
03-13-2017, 01:53 PM | #20 | |
Mamba max pro = Mamba X. Mamba monster = Mamba Monster X. Mamba micro = Mamba Micro X. The Sidewinders are non sensored, different league all together. | |
Bomber Increase speed? - Similar Threads | ||||
LNC Seach for increase speed and good torque | YNPpro | Team Losi Comp Crawler | 28 | 03-08-2013 07:10 AM |
best way to increase wheel speed? | 2004neonsrt4 | Axial AX-10 Scorpion | 10 | 05-10-2008 02:53 PM |
