03-22-2017, 02:03 PM | #21 |
Rock Stacker Join Date: Mar 2017 Location: Santa Rosa
| Re: Yota truggy |
03-22-2017, 08:19 PM | #22 |
| Yota truggy
Alright here we go, thing is built now. Took it out for a shakedown after I put the wheels together. It's an rtr, with Carter fab aluminum extended sides Carter fab front inner fenders Pro-line 85 hilux sr5 body Axial soft sway bar Crawler Innovations 6" double deuce standard inner, soft outer front, medium outer rear Pit bull rock beast 2's komp Axial beadlocks Incision 8 pc stainless steel link kit SSD yeti trailing arms Hitec servo hs-7955tg And tomorrow the axial aluminum servo horn should show up. I drilled the aluminum one that came with the hitec servo and it works ok, just a bit short. I run Venom 3s batteries It seems real capable now, and today I even made sure the motor smokes a little. HA whatever. I was crawling some real technical thing and I think it bounced into a pinch and the tires gripped all crazy under throttle. Anyway I ran it for another 30 mins after the breakdown and things seemed fine. for now. Only other problem is that the whole thing cuts out once in a while. I think it might be a bad battery, I'm testing that idea when I get the chance. Not the servo, cause it's new, and cause the throttle cuts also. Just really quick intervals though. Then it's ok. Sometimes I unplug the battery and hook it back up. And everything is fine again. Could be transmitter interference too I think. It's part of the charm of this truggy. So there you go. Hopefully the information helps some folks. I'd say an rtr with the stainless links, a swaybar, and an aluminum servo horn would be a great start with one of these rigs. Last edited by kennydoggins; 03-22-2017 at 09:57 PM. |
03-23-2017, 01:32 PM | #23 |
Quarry Creeper Join Date: Mar 2015 Location: Woodland
| Re: Yota truggy
I would almost guarantee you need a BEC to power your servo, its causing your esc to brown out temporarily. RX Bypass Adapter - Wiring & Wiring Accessories - Electronics & Wiring Castle Creations BEC 10A - BECs & Voltage Regulators - Electronics & Wiring These should be what you need I run a BEC in everything Last edited by Thechewmaster; 03-24-2017 at 03:47 PM. |
03-23-2017, 03:06 PM | #24 | |
| Re: Yota truggy Quote:
thanks for the info! Last edited by kennydoggins; 03-23-2017 at 04:20 PM. | |
03-23-2017, 04:42 PM | #25 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Re: Yota truggy
How long does it shut down for? It's not hitting the thermal is it? Love how unique this rig is
03-23-2017, 10:54 PM | #26 | |
| Yota truggy Quote:
Well it does two things. Sometimes if I'm doing donuts in loose dirt, the steering and throttle will sputter. Feels like an electrical short. Like a bad ground would be with a motorbike or something. The other thing it has done is the steering will lock to one side and nothing else works, no throttle, no steering, just locked to one side. That happened twice just at random times. But unplug the battery, plug it back in, everything is fine. So maybe full throttle and full steering (donuts, drifting) on 3s with my servo shows that I'm overloading the esc and should run a bec. I don't know a lot about this stuff, but this line of thought is making sense. Although it isn't real easy to replicate, which made me think maybe it's the battery, since I have 2 of them. And that might explain the inconsistency. I'm keeping track and maybe this weekend I can see that this only happens with one of the batteries. It's real exciting. Since I mostly am doing low speed crawling and trail driving it's not a big deal, but when I was out in the mud trying to bounce up a feature, the damn thing got too hot. Last edited by kennydoggins; 03-23-2017 at 11:05 PM. | |
03-25-2017, 02:42 PM | #27 |
| Yota truggy I put this one here just cause I was tripping out on how much the tires were hooking up. No wheel spin at all on this type of surface. Still browning out the esc or whatever is happening. It's like a bad fuse, or a bad ground wire on the way out. That's the easiest way to explain it. I'm just dealing with it, didn't like baby the thing and fool with the battery. I just picked it up if it was getting real stuck. Cause them tires will get stuck in some of the rock piles. Anyway I'm taking thechewmasters advice and ordering up the bec. I think I'm going with this one https://www.amainhobbies.com/heyok-p...nbradj/p521836 Lemme know if it sounds like something else going on to anyone. Last edited by kennydoggins; 03-25-2017 at 03:38 PM. |
03-25-2017, 04:43 PM | #28 |
Pebble Pounder Join Date: Dec 2012 Location: Delaware
| Re: Yota truggy
How do you have the body secured on the back of the cab to keep it from flipping up while driving?
03-25-2017, 06:58 PM | #29 |
| Re: Yota truggy |
03-27-2017, 05:26 PM | #30 | |||
Associated 6916 SH Screw W Hole 4-40x1 2 4 | eBay Those work great on my Wraith hood! Sweet looking Bomber and love the Yota cab! Quote: Also agree with Chewmaster, HH RX bypass harness with BEC is the way to go. Sounds like it's brown out, motor maybe a little burnt but still working. I'm assuming stock RTR motor, esc and gearing? Those tires are little taller and heavier than stockers, prolly need to gear down a little bit too. Last edited by Natedog; 03-27-2017 at 06:04 PM. | |||
03-27-2017, 07:36 PM | #31 | |
But maybe I am overthinking it. I just don't want to manhandle the wrong screw into plastic threads. I'd rather just break out the wrench when the battery is spent for now. | |
03-29-2017, 02:38 PM | #32 |
| Yota truggy
Installed the no-brainer bec in line with the servo. Went wheeling today, no electrical problems at all. Thanks for the info everybody. I just broke an end off of a trailing arm, and now I have one more spare... Good times! This wall is crazy steep. I tried a different line cause this one doesn't go all the way up, and had a crash from pretty low. Mechanical failure haha! It was a line to the left. I'll be back. Last edited by kennydoggins; 03-29-2017 at 02:40 PM. |
03-30-2017, 02:06 PM | #33 |
| Re: Yota truggy
Did you get to run it long enough to confirm the bec fixed your problem?
03-30-2017, 07:37 PM | #34 |
| Re: Yota truggy |
04-02-2017, 11:28 AM | #35 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
| Re: Yota truggy
Where are you crawling at ?
04-02-2017, 02:11 PM | #36 |
| Re: Yota truggy |
04-05-2017, 10:00 AM | #37 |
Newbie Join Date: Dec 2014 Location: Canada
| Re: Yota truggy
Hey do you think it's possible to keep most of the grill and headlights of the body intact? I would like to get this body as well but I don't want to cut the entire front end off on mine Looks awesome tho reminds me kinda of bro dozer from diesel brothers haha! |
04-05-2017, 03:41 PM | #38 |
| Re: Yota truggy
I really don't see how you could keep everything intact and still use the front bumper. If you look in my thread there is a similar picture of another truck with more of the headlights and grill, But I found the plastic tube wanted to go right through the head lights Toyota Bomber Post #7 Last edited by Thechewmaster; 04-05-2017 at 03:44 PM. |
04-06-2017, 11:19 AM | #39 |
| Re: Yota truggy I plan on doing up some headlights, but wanted to cut out all the lexan. Kinda like these 1/1 trucks. Last edited by kennydoggins; 04-06-2017 at 11:24 AM. |
04-06-2017, 11:45 AM | #40 |
| Re: Yota truggy
Why does he have IROCs in the front and Boggers in the back?
Yota truggy - Similar Threads | ||||
CC Yota truggy | dkchance74 | Duratrax Cliff Climber | 12 | 09-10-2013 09:53 PM |
**One more Yota Truggy!** | R2j | 1.9 Scale Rigs | 104 | 12-17-2010 02:52 PM |
Yet another Yota truggy | Jester666 | 2.2 Scale Rigs | 94 | 08-23-2010 03:48 PM |
