09-04-2017, 03:52 AM | #61 |
Pebble Pounder Join Date: Aug 2016 Location: Chattanooga
| Re: Yota truggy
09-19-2017, 11:27 PM | #62 |
Rock Stacker Join Date: Mar 2017 Location: Santa Rosa
| Re: Yota truggy Method beadlocks is a good upgrade. Also took out the overdrive front gears, gotta shim those to make em work without blowing out bearings. Still solid, little more body damage haha |
09-20-2017, 01:29 PM | #63 | |
Rock Stacker Join Date: Aug 2016 Location: Long Island
| Re: Yota truggy Quote:
You ever find away to keep the hood? Like the pic where it was hinging from the original hood spot. | |
09-22-2017, 10:46 AM | #64 |
| Re: Yota truggy Yeah, it just depends on how hard you drive your rig. You could get pretty technical if you don't abuse your truck. It ended up a bit too delicate for my taste. I have found that the more solid you keep the body, the better. Just get hairline cracks and the thing falls apart with too many body cuts. I plan on putting a scale engine in there and leaving the hood off. Alternatively, leaving the body together and using body pins on the bottom rear of the doors works pretty well too. That way you can hinge the whole body off the front like I originally had it. Also the cut out for the windshield didn't pan out for the same reasons I put above. Of course this all applies to my experience with the proline sr5 body. Other routes go other places |
09-22-2017, 12:26 PM | #65 | |
09-22-2017, 12:40 PM | #66 | |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
09-22-2017, 02:02 PM | #67 | |
I’d love a manche body on mine but I don’t know if it’d fit over the cage. I cut up a proline jk body I had and it did not work Sent from my iPhone using Tapatalk | |
09-24-2017, 02:25 PM | #68 | |
| Yota truggy Quote:
It really lines up great, windshield angle is pretty good too. Last edited by kennydoggins; 09-24-2017 at 02:29 PM. | |
09-25-2017, 08:05 AM | #69 |
| Re: Yota truggy |
10-11-2017, 01:41 PM | #70 |
| Re: Yota truggy
Ok folks I'm running a hood again. Work in progress, I've got a new body that will be together pretty soon. But I'm happy with the "hinge" situation. Just running a winch line over the top rather than something that would break. Because we run these things pretty hard. It's a good setup for me. I'll catch up with you all when I finish the body, still sr5 for sure, and until then check it out. Scale nerd points |
10-11-2017, 02:28 PM | #71 | |
pumped to see it! | |
10-11-2017, 02:50 PM | #72 |
| Re: Yota truggy Hey I tried to PM you but it didn't go through, maybe check your settings? Let's meet up sometime, we've been going to shell ridge in walnut creek, it's good.
10-12-2017, 09:53 AM | #73 |
| Re: Yota truggy
Process pics: |
10-16-2017, 12:09 AM | #74 |
| Re: Yota truggy
Shot a few photos of the new body before its maiden voyage. Stoked with the rear cab window, closed cab whatever. That took a little doin. This thing is going to get thrashed before long Probably cut the side windows out after while. I wanted to do one all broken, window glass out of the rails looking. It's pretty slick as-is though and definitely stronger with less holes in it. Everything in moderation. That's a thing they say. I like it, pretty psyched how it turned out. And I didn't make any horrible mistakes this time hahahahahahahahaaaa Last edited by kennydoggins; 10-16-2017 at 12:16 AM. |
10-17-2017, 10:06 AM | #75 | |
10-17-2017, 10:49 AM | #76 | |
I would suggest starting this whole s**t show by using the hood hinge all the way up front, leave the body all together, and anchor the back with the bolts I still use on the current setup. Earlier on in this thread there's pictures of that configuration. I just got tired of screwing and unscrewing the bolts for every battery change. There are threaded body pin setups though. Plenty of options.. sort of. Trial and error, problem-solving, failing all part of the package deal. | |
10-17-2017, 11:11 AM | #77 | |
10-17-2017, 11:52 AM | #78 | |
For the recovery strap/winch line hooked up like this in real life, there could be a few reasons. If you're out wheeling and using your winch a lot, you don't want to spool it up every time, etc. Stuff like that. | |
10-17-2017, 02:04 PM | #79 | ||
10-17-2017, 03:34 PM | #80 | |
Yota truggy - Similar Threads | ||||
CC Yota truggy | dkchance74 | Duratrax Cliff Climber | 12 | 09-10-2013 09:53 PM |
**One more Yota Truggy!** | R2j | 1.9 Scale Rigs | 104 | 12-17-2010 02:52 PM |
Yet another Yota truggy | Jester666 | 2.2 Scale Rigs | 94 | 08-23-2010 03:48 PM |
