04-15-2017, 07:10 PM | #1 |
| ~TSS~ Bomber Brass Knuckles! Yet another first of its kind original product from The Scale Shop. One piece brass knuckles for the AR60/ Wraith/ Bomber axles. Adds weight down low and at the end of the axles for more leverage to keep your rig planted without adding rotational mass. Features 4mm thick high steer zero ackerman arms with gussets for the ultimate in strength, steering, and clearance. 8 Degree Knuckles Paint-able for scale looks. Extremely tight tolerances for zero slop. Designed to mimic welded/fabricated full size knuckles. Help to plant your rig and make it more stable by moving the weight outward vs brass tubes, yet without the rotational mass of wheel weights. Clears just about any 1.9 and 2.2 wheel. SORRCA Legal Weight: TSS AR60 Brass Knuckles = 1.6 oz each VP knuckles = 0.3 oz each Last edited by STANG KILLA SS; 09-10-2017 at 08:02 AM. |
04-18-2017, 07:29 AM | #2 |
| Re: ~TSS~ Bomber Brass Knuckles!
No oversized wheel bearings? They've become the quickest wear item on my Bomber. When snow or sandpit bashing I'm lucky to get three or four packs through them before they are wicked loose. Can easily double that with conservative driving on slow trail runs, but that's just not as much fun to me as bombing around. How does the brass wear at the kingpin pivots compared to an aluminum knuckle? |
04-18-2017, 08:09 AM | #3 |
they wear the same and probably better due to our MUCH tighter tolerances than everyones aluminum versions.
09-10-2017, 08:03 AM | #4 |
got a few of these left
03-23-2018, 02:45 PM | #5 |
you guys begged us to bring them back, now in stock!
~TSS~ Bomber Brass Knuckles! - Similar Threads | ||||
~TSS~ AR60 / Wraith / Bomber Brass Knuckles! | STANG KILLA SS | Axles, Trannys, T-case | 13 | 05-08-2019 11:42 AM |
~TSS~ SCX10 Brass Knuckles | STANG KILLA SS | Axles, Trannys, T-case | 44 | 08-20-2017 09:18 AM |
~TSS~ AX10 Brass Knuckles | STANG KILLA SS | Axial AX-10 Scorpion | 12 | 01-18-2017 06:21 PM |
