05-10-2017, 06:26 AM | #1 |
Rock Stacker Join Date: Dec 2016 Location: Las Vegas
| rear axle options.
Lost a rear axle. Was looking at replacements. would I benefit with a center axle under my bomber? Sock RTR, Used for crawling. Thanks in advance. |
05-10-2017, 06:45 AM | #2 |
Rock Stacker Join Date: Jun 2016 Location: Tryon, North Carolina
| Re: rear axle options.
You would want to consider keeping the driveshaft as straight as possible, to reduce U-joint stress, avoiding the sharpe angle.. Sent from my SM-N910C using Tapatalk |
05-10-2017, 06:49 AM | #3 |
05-10-2017, 07:38 AM | #4 | |
RCC Addict Join Date: Dec 2014 Location: So Cal
| Re: rear axle options. Quote:
05-10-2017, 08:05 AM | #5 |
Throphy truck & RR10 are different worlds..on the Yeti RR, SCORE, CP for sure..but why complicate the drivetrain if not a must..follow the driveline's natural course..but opinions are A-plenty.. Sent from my SM-N910C using Tapatalk |
05-10-2017, 10:08 AM | #6 |
I just got one of my projects driveable last night and it's using a centered SSD D60HD. It's a plastic housing, but it's beefier than the stock ar60 with thicker wall axle tubes and no need for lockouts. It comes with truss, shafts, 13mm pinion bearings, diff cover, carrier bearing caps, link mounts, and all necessary hardware... a steal at $29! I'm running a 3656 brushless setup on 3s, and I plan on launching this rig at the dunes, so I'll find out how durable it is soon enough, it's cheap enough to experiment with. The change in driveline angle with a centered pumpkin under a bomber would be minimal, but as already said, it is more prone to getting hung up when crawling. |
05-10-2017, 05:20 PM | #7 | |
05-10-2017, 08:16 PM | #8 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Side trap of centered rear axle in Bomber, depending on drive shafts used, can also be interference with the spur cover. Just one other thing to consider. |
rear axle options. - Similar Threads | ||||
Yeti rear axle options / advice | Chris-NL | Axial Yeti | 21 | 03-22-2017 10:14 PM |
Rear axle options and strength | P-J | Axial Yeti | 24 | 02-06-2015 06:31 PM |
Rear axle shaft options | broncoholic | EnRoute Berg | 4 | 02-24-2010 04:31 PM |
