Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Hoyt's Bomber
Old 05-30-2019, 05:58 AM   #21
Default Re: Hoyt's Bomber
Originally Posted by rockwha? View Post
Dude! You brazed tiny nuts onto the chassis for panel mounts?! What the heck? How you do that and not get crap in the threads? Braze them in the tap them again?
Lol its not that hard but can be a pain without the right tools. The solder will really only flow where the flux is and with using gravity to keep most of it going down away from hex nut it doesnít get in threads.
hoyt is offline   Reply With Quote
Old 05-30-2019, 08:23 AM   #22
MAC FAB's Avatar
Great build. What does it weigh?
MAC FAB is offline   Reply With Quote
Old 05-30-2019, 12:47 PM   #23
Thank u
The cage, panels and fuel cell (basically how its pictured is 2.2lbs. On the heavy side but to me heavier rigs look more realistic when it comes to articulation etc. that being said hopefully Iím not just digging holes goin up hill. I will weigh rig when its all together.
Old 05-30-2019, 03:18 PM   #24
Wow!! Looks great. I'm excited to see it come together.
Summitonslingrs is offline   Reply With Quote
Old 05-30-2019, 03:41 PM   #25
XXXXXXXXXXXXX
durok's Avatar
I feel the same way about heavy rigs - they may not win comps, but for scale driving and bashing it makes the rig react more realistically.
I seriously dig the way that cage came out, with those panels.
...dope, DOPE, DOPE!
durok is offline   Reply With Quote
Old 06-04-2019, 05:57 AM   #26
Thanks man
Old 06-04-2019, 06:03 AM   #27
Default Hoyt's Bomber
Alright got this thing up and running. Im pretty happy with how it turned out. I have not driven it on anything super steep and still working on my bouncer hill behind the house but it does feel planted to the ground.
When i get the chance i will post up some specs and the always present list of needed/wanted parts.
Some pics for now. Its been a fun truck to drive thus far.
Old 06-04-2019, 09:03 AM   #28
MAC FAB's Avatar
Thats awesome. Loving the grooved tires as well. And most importantly, driven like you stole it. What do you think you hit for a top speed?
Old 06-04-2019, 12:12 PM   #29
Thanks
Boy I have no idea on top speed but it's got some pep. Running HH ble with puller pro (540) 3500kv on 3s. 64t spur gear with a (I'm guessing here cause I forget) 17t pinion. No issues thus far and hey if u build a bouncer u gotta drive it like one lol.
I think u asked me about weight last time. The truck pictured (minus the battery) is 7.7lbs.
Old 06-08-2019, 08:11 PM   #30
Just some short Slow Mo vids of the bouncer bouncing. Its been running pretty good with no big hiccups. It does feel really planted and I'm actually happy with the cut Baja's for now. I do want to add a little weight up front and low (see below).
I currently only have a aluminum beef tube up front so I just ordered a brass set for the front and going to switch the aluminum to the rear. Aside from that will most likely just be fixing things as they break. Just running stock bomber trans with nut on slipper cranked all the way down.
Electronics
Holmes Hobbies BLE Pro
HH Puller Pro BL 3500Kv
Savox 1283SG Servo
CC BEC
Ucfab Sway Bar: Love this thing
Stock King shocks for now (one is sticking on me and not sure why yet)
Vanquish knuckles
Vanquish Servo Axle mount
Upgraded Titanium Steering tie rod and drag link
Tires are the stock Baja's but cut up
Rear are CI Deuce's Wild Single
Front are CI Double Deuce with soft outer
What you got here is the start of a small bouncer section on the hill behind my house. Will be adding more as I get the time.
Old 07-04-2019, 06:17 PM   #31
Looks awesome. Just curious have you thought about running cut tsl or treps like the 1:1
Lil_Chop19922 is offline   Reply With Quote
Old 07-13-2019, 06:58 PM   #32
Thanks and yes
I am a big fan of tsl's. Ran them all the time in my 1.9 trucks. When I decide on a wheel I will most likely grab some tires to.
Just picked up a brass beef tube and proline power strokes for the front. One of the front shocks is just done. Aluminum beef tube that's currently up front will go to rear. Just need to find time to install.
Old 01-31-2020, 09:04 PM   #33
So after a summer of beating on the truck i had a couple issues but not to bad. Felt like i was maybe a touch lite in the front but other then that was a lot of fun to drive and beat on.
In the end i ended up bending a lower front link, managed to break one of my welds some how, bent a front shock and killed my two 3s lipoís. The lipo,s were like 10 years old so not gonna complain there.
The holmes motor ran great and still going strong along with the savox servo.
I will be making a couple subtle changes to the cage to make it more like the krog show and hopefully some paint and panels that are similar. I had debated on going with a wraith trans but in the end decided not to. To many changes would have to be made and i would rather have this running and work on a new build.
Whats in store for the tear down and rebuild.
Gonna try some proline slash shocks and see how i like them. Bought the extra springs for adjustments.
Brass beef tube up front and aluminum to rear.
Incision lockers front and rear
Much needed new rod ends and pivot balls.
And a lil vp truss bling because why not.
Old 01-31-2020, 09:07 PM   #34
Also made a short compilation video of some of my runs.
Hoyt's Bomber - Similar Threads
Making Crawling bomber into trail rig bomber. theTman Axial RR10 Bomber 2 06-10-2016 01:46 PM
Hoyt's HoNcHo hoyt Axial SCX-10 114 02-23-2015 08:34 PM
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
