07-21-2017, 02:49 PM | #1 |
Newbie Join Date: Jul 2017 Location: Nor-Cal
| 1st Bomber Build
Looking for suggestions on shock oil weight and yeti raptor body fitment tips. Bye bye stock rtr and hello to my first build. Vp currie rockjock 70 axles fr and rear Vp wraith stage one kit Insicion locker fr and rear Locked up rear axle shafts Vp knuckle weights Vp rear lower links Insicion ss 1/4" link kit Insicion motor mount and cam Axial hd gears 38/13 fr and rear MM X esc with sensor wire adaptor Tekin roc 412 hd 3100kv HR 110mm limiter straps Axial King shock caps Vp 2.2 kmc wheels Vp XD series hub caps Vp wheel adapters .475 fr and rear Pitbull tires Ci foams Proline Raptor body Thank you, Steve Last edited by Braaap42; 07-21-2017 at 04:19 PM. |
07-21-2017, 03:34 PM | #2 |
Rock Stacker Join Date: Jan 2008 Location: New Milford
| Re: 1st Bomber Build
Like to see how the Raptor body fits after you get it mounted.
07-21-2017, 03:39 PM | #3 |
I seen pics on the net and really liked the look. I know it's been done by folks on here and that's why I asked for tips to do it. I don't want to trash it right out of the gate. Thank you, Steve Last edited by Braaap42; 07-21-2017 at 04:31 PM. |
07-21-2017, 04:27 PM | #4 |
Figured the pic posting out . Picked this all up from rpp yesterday and when I got home from work I packed for my trip today and got the rear axle built and the rear links on. 1 Week of my daighter racing bmx world championship and I can get back to this
07-31-2017, 05:46 PM | #5 |
| Re: 1st Bomber Build / esc help ?
Got everything built and installed. Took it out for some testing and it works great except when I let off it dam near flips over forward. Mamba X with Tekin roc 412 hd 3100kv. I have castle link and set esc to 50% brake and 30% drag brake, how can I stop this or have a little coast? Got frustrated with esc so I paintrd and mounted the raptor body. Flat exterior with some ghosted bmx sponsors of mine and seperation stripe with normal shine from lexan |
07-31-2017, 08:14 PM | #6 |
Can someone help with my esc question? The truck stop way to hard when I let off and ot hit neutral point. Acts like it has full brake instantly? I am lost Thank you in advance, |
07-31-2017, 08:43 PM | #7 |
I wanna be Dave Join Date: Apr 2015 Location: Roseville, Ca
Thats the drag brake. Go into castle link, switch reverse type to with reverse, then go to aux setting and last choice is rock racer/crawler mode and click that. Leave the brake and drag brake settings the same, click update and your done. Then make sure the aux wire off the esc is plugged into your 3rd channel and you can switch between rock racer mode and crawler mode. Rock racer mode is with reverse and no drag brake, and crawler mode is crawler reverse and 30% drag brake. Last edited by 84yoda; 07-31-2017 at 08:45 PM. |
07-31-2017, 09:26 PM | #8 |
I will try that now. Thank you |
07-31-2017, 10:25 PM | #9 |
Thank you 84yoda. Works like I wanted it too now 👍👍 |
07-31-2017, 11:11 PM | #10 |
No problem, glad I could help. |
08-01-2017, 05:17 AM | #11 | |
Quarry Creeper Join Date: Aug 2016 Location: Christiansburg
| Re: 1st Bomber Build Quote:
Also, be sure your firmware is updated from Castle if you haven't already! Really nice looking Bomber you've got there!!! | |
08-01-2017, 08:17 AM | #12 |
So you can set the drag brake different for each mode? I don't know much about mamba esc and appreciate the help and advice. And thank for compliment slowmethinks |
08-01-2017, 10:22 AM | #13 |
Pebble Pounder Join Date: Jan 2017 Location: @scaleobsession on instagram
Off topic but what class does your daughter race? I raced back in the aba/Nbl days, and still follow a bit.
08-01-2017, 11:45 AM | #14 |
Expert
08-01-2017, 02:42 PM | #15 |
| Re: 1st Bomber Build |
08-01-2017, 07:24 PM | #16 | |
Mamba Firmware V2.02 | |
08-01-2017, 10:16 PM | #17 |
| Re: 1st Bomber Build Depending on what remote your using, you can go up in percents when your in crawler mode. But say a stock bomber remote, can only do on/off.
08-01-2017, 10:42 PM | #18 |
I have a spektrum dx4s . My confusion was that I was thinking when I hit the switch from race to crawl I could have the drag change also and it is something you setup with castle link
08-01-2017, 11:05 PM | #19 |
Yes, you can. If you set up a certain switch on your remote (nothing in castle link), the drag brake will go up/down percents. I dont have a dx4s so I cant help with that.
08-06-2017, 05:25 PM | #20 |
Got to run the bomber some and so far everything is good. I think I need some longer rear top link rod ends to better the drive shaft alignment
1st Bomber Build - Similar Threads | ||||
1st post - 1st build - total noob | Sebhb | Axial SCX10 II | 48 | 05-28-2017 03:18 PM |
Tamiya Bronco Kit Build; 1st Build | Boxcarcustoms | 1.9 Scale Rigs | 2 | 07-29-2013 07:37 PM |
my 1st build-ever! | Reaper09 | HPI Wheely King | 2 | 02-02-2010 08:23 AM |
need some help on my 1st build | Troublemaker | Chit Chat | 5 | 02-06-2008 10:28 PM |
help my 1st build | tlt | Newbie General | 7 | 01-21-2007 09:54 PM |
