02-11-2018, 04:23 PM | #21 |
Pebble Pounder Join Date: Nov 2014 Location: Camby
| Re: Another one bites the dust...servo
True it's less than the 500oz boys but even at 7.4v this servo turns the tires with ease even on thick carpet. I don't know how heavy some people's rigs are but at some point higher oz's are just bragging rights. Who needs over 20lbs worth of turning grunt on a 1/10 scale anyway. |
02-11-2018, 06:56 PM | #22 | |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
| Re: Another one bites the dust...servo Quote:
02-11-2018, 11:39 PM | #23 | |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
02-12-2018, 04:05 AM | #24 |
I can see that. The Savox servo mentioned earlier looks beast! Huge gears with that extra bracing looks bomb proof.
02-18-2018, 12:52 PM | #25 |
Quarry Creeper Join Date: Sep 2017 Location: UK
Well my JX5932 died on me today on its 2nd trip out. Think it took a knock. So is the Savox 1283 the one to get...knock resilient ? Can it be run at 7.4v for more poke or is it just a 6 volter. The bomber seems to be servo hungry....
02-18-2018, 01:59 PM | #26 |
ProModeler 470 or Holmes SHV500 Hang up and Drive |
02-19-2018, 12:26 AM | #27 |
Looks like both of those are in the states. I need something from the UK...thinking now about the Savox SB2290SG....
02-19-2018, 04:40 AM | #28 |
Yup both US based. The 2290 is a beast! Hang up and Drive |
02-19-2018, 04:43 AM | #29 |
It'll take a while to arrive - but no matter, the build still isn't ready - I ordered a backup servo for my Bomber build(s) as an experiment... The best JX available, JX BLS 12V7146 46KG : Motor: brushless motor Operating Speed (11.1V): 0.12sec/60° Operating Speed (14V): 0.10sec/60° Stall Torque (11.1V): 38kg.cm Stall Torque (14V): 47kg.cm - High-precision Taiwan-made steel gears with hard anodizing - Full CNC aluminium Shell structure - Dual ball bearings - Waterproof With a coupon code got it coming for around $55, shipped. I have a ProModeler for one Bomber build, and a Holmes SHV500 for the other - the SHV is from the very first batch, so I'm just a little bit worried that it may end up with a bent pin... It's going in the heavy-duty much-upgraded build, and may require service after running it around as is. If so, I can swap in the JX, while waiting for the upgrade to the newest revision of the SHV. The JX also will run directly off of 12V, we'll see if I can report good results. Not worried about the ProModeler, and the build it's going in will be relatively lightweight. |
02-19-2018, 05:11 AM | #30 |
Ive ordered the 2290...got it for £99.99 hopefully pick it up tomorrow. Thought may as well go for the monster. It will be run from a MMX so hopefully the BEC on that should be man enough.
02-21-2018, 04:17 AM | #31 |
Finally got servo installed, USPS delayed it then I needed the free time to install. Got it done and can't wait to try it out. Hopefully this will be the last I have to replace the servo. |
02-21-2018, 02:13 PM | #32 | |
02-21-2018, 02:31 PM | #33 |
Any tips on a source for Promodeler servos? I'm used to being able to find almost anything on RPP or Amain's site. I see the Promodeler's site has them up for sale. I have a few other items on my list, is there any other sources that might have crawler parts too?
02-21-2018, 03:31 PM | #34 | |
02-21-2018, 06:22 PM | #35 | |
His wife handles the paperwork, he handles the product design. If you do purchase from them it's really like stepping back in time! Go through the lengthy threads on ProModeler... they make for some interesting reading. I got what I think was the first "surprise" ProModeler drink koozie after first ordering a servo, and then writing back to ask for some stickers because I was so impressed by them. People ask about it all the time because I walk around my work with my Monster Import energy drink inside it. | |
02-21-2018, 06:45 PM | #36 | |
John and Lynn Beach..... great folks and great servo. Yep the koozie and stickers rock, the servo is even better. Mil spec quality. That’s OPIE as seen in his ads Hang up and Drive | |
11-03-2018, 08:17 AM | #37 |
I predict an upgrade to my bomber in the future, after the plastic knuckles and c-hubs are aluminium.
11-03-2018, 09:15 AM | #38 | |
When you get that jx servo take it apart and make sure the pc board isent touching anything mine shorted out the first time i pluged it in the pc board was touching the case the little foam piece was in the wrong spot and dident hold the board in place it fried my momba so it ended up costing 2 times th3 cost of a quality servo i did salvedge what was left and made a winch out of it it will lift 20lbs on 6v so whatever i just need a new servo and a new momba now lol sometimes being cheap cost more | |
11-06-2018, 07:14 AM | #39 |
Rock Stacker Join Date: Sep 2018 Location: Pierce
I have had about 5 different servos in mine and the savox SB2274SG has been in there the longest. I just install the proline servo saver to see if that helps out.
02-14-2019, 02:10 PM | #40 |
Newbie Join Date: Aug 2016 Location: Orlando
The Savox is a good servo. So is the Holmes. Mine isn't bad either. One thing I believe you guys should all consider is using a sacrificial part. If possible, I recommend folks run our heavy duty plastic servo arms (some rigs like an X-MAXX require a special servo arm). Anyway, they're only a buck each, but a bag of 25 gets the price down to 68¢ (and splitting a bag of 100 with some pals gets it down to 50¢ each). The idea is, when it breaks (not if), you're only out the few minutes it takes to replace it (plus some small change). The alternative is being out of contention (if you're competing), plus the cost of the damaged or destroyed servo (mine or my competitors). Then there's the time required to remove and replace the servo, which is longer than it takes to R&R an arm. And don't forget the time waiting on repair/replacement if you don't have one on hand (plus postage costs). Anyway, I'll never get rich off these servo arms - but they can definitely save you some dough. By the way, in mechanical engineering the concept of sacrificial parts is at least as old as the concept of the fuse in electronics. Applying it to your rig can save you more than money because a lot of you can only get out to the trails occasionally and spoiling this time because of a broken servo (which can happen just minutes into the run) absolutely stinks! ProModeler single-horn HD servo arm: https://www.promodeler.com/PDRS101 |
Another one bites the dust...servo - Similar Threads | ||||
Another one bites the dust! 8th motor and counting..HELP!!!! | hiluxscaler | Electronics | 18 | 02-19-2012 10:20 AM |
From Dust | Duuuuuuuude | Chit Chat | 12 | 08-07-2011 08:30 PM |
Another one bites the dust! | camel_rc | Electronics | 2 | 02-28-2008 12:21 PM |
Eel bites off guys thumb, then he replaces it with a toe!! | Brandon | Chit Chat | 2 | 03-13-2007 01:46 PM |
Another 945mg bites the dust! | BENDER | Electronics | 22 | 02-27-2005 02:49 AM |
