08-30-2017, 07:07 AM | #1 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
| Aftermarket shock caps & collars compatible with Axial shock bodies?
Are there any aftermarket shock caps & spring collars that are compatible with the stock Axial King shock bodies? I just finished putting together the shocks from my Bomber kit last night, and as great as they look, the blue is not going to look good with the orange theme that I'm planning for the truck. I'm considering stripping the anodizing off of the stock caps & collars, but I would prefer orange anodizing over bare aluminum if I can do it. Is there anything out there? |
08-30-2017, 07:16 AM | #2 |
| Re: Aftermarket shock caps & collars compatible with Axial shock bodies?
I have used the ST Racing shocks caps on other trucks, they are good quality and not too expensive. CNC Machined Alum. Shock Caps for Axial Wraith (4 pcs) Orange Haven't seen spring collars in orange though. |
08-30-2017, 08:07 AM | #3 | |
Newbie Join Date: Mar 2011 Location: Vermont
| Re: Aftermarket shock caps & collars compatible with Axial shock bodies? Quote:
WRA15603 | |
08-30-2017, 10:52 AM | #4 | |
| Re: Aftermarket shock caps & collars compatible with Axial shock bodies? Quote: | |
08-30-2017, 07:54 PM | #5 | |
See the product description below: Hot Racing Axial RR10 Bomber Aluminum 10mm Shock Upgrade Kit WRA15603 | eBay You might want to check with RC-Express and see what they have to say | |
08-31-2017, 07:53 AM | #6 |
Yeah, this definitely warrants more investigation. I think I'm going to grab some of my Traxxas shock caps and see if they thread on. If these are indeed a standard 10mm bore, then I have to imagine that they're using a thread pitch that's probably the same as somebody else. If that's the case, then it'll open up options for me. My other option, which is starting to look like the most likely solution, is to strip the anodizing off the caps & spring collars to make them bare, and dye the blue plastics black. |
Aftermarket shock caps & collars compatible with Axial shock bodies? - Similar Threads | ||||
STRC shock bodies and caps? | jimmiejump | Vaterra Ascender | 2 | 08-26-2016 01:25 AM |
*Giveaway* XR10 Shock Caps-Rod end Compatible | crazyorigin | Axial XR10 | 75 | 11-19-2010 03:59 PM |
Axial shock pistons in big bore shock bodies | Kanine38 | Newbie General | 2 | 03-11-2010 06:47 AM |
