Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Brushed for bomber?
Old 11-27-2017, 09:43 PM   #1
Default Brushed for bomber?
Would a brushed setup running 3s provide enough for a bomber? Im not looking to turn it into a crazy jumper as i have other rc's for that and would prefer the control, price and waterproofness brushed provides. I already have HW Crawler esc but would need a motor unless a 17t would work. But will it have enough go to be fun and enough speed for large obstacles.
sportbikeco is offline   Reply With Quote
Old 11-27-2017, 11:11 PM   #2
Default Re: Brushed for bomber?
I’d have a look at some of the longer/bigger motors like the 550 and maybe the 775 Traxxas offers. The 550 12t isn’t rated for 3s but I’m not sure about the 21t.
Brake Weight is online now   Reply With Quote
Old 11-28-2017, 06:25 AM   #3
Lots of people here are using the Traxxas Titan 21T 550 or the Holmes Hobbies trailmaster sealed can.
Sent from my Nexus 6 using Tapatalk
Jboucher is offline   Reply With Quote
Old 11-28-2017, 04:48 PM   #4
I have a holmes hobbies 21t 550 and hobbywing 1080 esc in my bomber and running 3s. I think it's plenty for a bomber.
NitroDarwin is offline   Reply With Quote
Old 12-12-2017, 10:11 AM   #5
I use Titan 12T, but on 2S and it flies.
Jwalbiscut is offline   Reply With Quote
Old 12-19-2017, 02:15 PM   #6
Just whipped out my castle 3800kv motor ( to go in my yeti whilst I await a GoolRC motor to try) and in its place Ive put in a Titan 550 21T on a 15 pinion gear. Ive still got the mamba X in there so I thought I would try 4S. Only a quick blast round the garden and the road outside but its pretty impressive in 2nd gear. The mamba log shows that it produced 0.8hp at peak which isnt bad. Compare this to 1.166hp for the 3800 on 3S and 2.0hp for the 2200kv on 6S in my yeti. Quite impressive for a £20 motor.
thewildblue77 is offline   Reply With Quote
Old 12-20-2017, 11:30 PM   #7
Running a Holmes Hobbies Trail master 550 21T motor in my sons Bomber & for an under $30 upgrade it is damn fast especially with the right gearing & some weight reduction
From some of the reviews I have read it is more powerful & faster that the Traxxas Titan 21T
BOMBERINOZ is offline   Reply With Quote
Old 12-21-2017, 01:57 AM   #8
Yeah I have one of those in my scx10.2....its great...cost me £11...I may try that on 4S at some point to see how it compares....
Old 02-08-2018, 12:39 PM   #9
What have you done as far as gearing? I am looking at this setup to install in a kit.
Tundratrader is offline   Reply With Quote
Old 02-08-2018, 01:23 PM   #10
I run the same setup in my kit, still unfinished but i went with a 11T pinion to start with.
Holmes recommends 11/68 gearing for his brushed motors.
Stock bomber is 12/64
Old 02-08-2018, 02:31 PM   #11
I believe a 10 tooth is as low as you can go on the pinion with 32p.
https://rover.ebay.com/rover/0/0/0?m...2F122306127602
Edit: Nope. There’s an 8 and 7 tooth, too.
8
https://rover.ebay.com/rover/0/0/0?m...2F272991322432
7
https://rover.ebay.com/rover/0/0/0?m...2F262637475380
Old 02-08-2018, 04:18 PM   #12
Great, how is that gonna be overall for mostly a crawler? I want to have a bit of speed to get over obstacles but don’t want it to work against me going slow.
Old 02-08-2018, 04:25 PM   #13
Most reviews seemed very good. Slow crawl is nice especially with the settings from the hobbywing 1080 and it's a brushed motor so...
Being a 550 can and low turn it should have good torque and wheelspeed for a brushed motor and it's super easy to replace at 20$.
Old 02-08-2018, 04:51 PM   #14
I'm running stock gearing
Old 02-08-2018, 09:21 PM   #15
Cool, well I am excited for this project. I am just getting back into RC. My last rig was an RC10t2 when they came out. So a steep learning curve with the brushless stuff getting back in. I think going with this combo will work great to get started. See how it runs and works with this setup first.
Old 02-10-2018, 10:46 PM   #16
I was running the RC4WD 35 turn and it did great.
Barndog Racing is offline   Reply With Quote
Old 02-10-2018, 11:51 PM   #17
I used to have my Titan 550 21T with 3s Lipo on my Wraith. I would these combinations are good in performance and yet still in budget side.
Teng is offline   Reply With Quote
Brushed for bomber? - Similar Threads
Bomber motor options - brushed or brushless? Jim85IROC Axial RR10 Bomber 21 08-28-2017 10:59 AM
Gain top end with 35t brushed bomber? rngrchad Axial RR10 Bomber 13 04-05-2016 07:16 PM
Dual Brushed ESC w Single Brushed Motor Creepcreep Newbie General 3 01-22-2016 12:04 PM
