12-18-2017, 09:19 AM | #21 |
Newbie Join Date: Dec 2017 Location: United States
| Re: Brushless kv choice for Bomber
I was considering the castle 2850kv as well...seeing as you can get it with the mabma x esc for just over $200 I feel its a pretty reasonable price. I plan to do a mixture of rock crawling and bashing with mine so I think this would be a good compromise. I've also been looking at the tekin pro4 hd 3000kv motor as I see its got great reviews, but its also double the price of the castle motor. any of you experienced guys care to chime in on that? edit: ill be running on 3s with an otherwise stock bomber. |
07-21-2019, 09:15 AM | #22 |
Pebble Pounder Join Date: Mar 2012 Location: Greece
I want to turn my bomber into a formula off road with padle tires.I have 3s batteries.Which motor is a better choice?A bigger 4068 2650kv or a 3660 3800kv?I will run 3s.I want the fastest I can get but I don't want problems with overheating.
07-21-2019, 07:54 PM | #23 |
Rock Stacker Join Date: Feb 2016 Location: Gorham, Maine
I'm running a mamba x with 2200kv 1515 Castle motor on 4s, way more fun than the Castle SCT 3800kv on 2s.
07-21-2019, 11:17 PM | #24 |
| Re: Brushless kv choice for Bomber |
07-22-2019, 05:13 AM | #25 | |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Brushless kv choice for Bomber Quote:
Otherwise there is the puller pro R 4100kv on 3s that is designed for races Sent from my Pixel 2 XL using Tapatalk | |
07-22-2019, 05:56 AM | #26 |
I was wondering a 3674 2650kv motor would be faster than a 3660 3800kv on 3s with suitable gearing? Στλθηκε απ το PRO 6 Plus μου χρησιμοποιντας Tapatalk |
07-24-2019, 08:15 PM | #27 |
Quarry Creeper Join Date: Nov 2009 Location: Hickory,NC
Holmes 3500xl on 3s. After breaking the front and rear axle housings in 2 days. The 3500 came out. The 2.2 Showdowns also came off. I would stay around 2500-2800kv.
07-24-2019, 09:09 PM | #28 |
2700kv on 3s is a sweet spot for the bomber IMO. I would still personally run the 3500 because I like excess wheelspeed. Or the 2700 on 4s.
07-25-2019, 05:07 PM | #29 |
Pebble Pounder Join Date: May 2016 Location: East Indiana
I went with the Holmes PP 3500 in my bomber kit this spring and am super happy with it!! I'm running just 2s now, I have no 3s yet. Man it's fast and can crawl very well too, IMO.
07-25-2019, 06:29 PM | #30 |
07-25-2019, 10:48 PM | #31 | |
Στλθηκε απ το PRO 6 Plus μου χρησιμοποιντας Tapatalk | |
07-26-2019, 01:34 PM | #32 |
Newbie Join Date: Apr 2018 Location: Modesto
1410-3800kv with 3S-45C seems to run well. With the throttle curve programmed in the Mamba Monster it crawls nicely well and bashes pretty fun (current setup hits 19.5mph) With a small 2S-30C pack it goes good at crawler speeds and still runs a long time. Not quite as fast at the top end though. My drivetrain: Castle Mamba Monster X ESC Castle 1410 3800Kv Sensored Brushless Motor HotRacing Steel Pinion 32P 16T HotRacing Steel Spur Gear 32P 68T Axial 2-speed Transmission with Hi-Speed Option |
07-26-2019, 02:27 PM | #33 | |
You put a Wraith transmission in it? Sent from my Pixel 2 XL using Tapatalk | |
07-26-2019, 03:36 PM | #34 | |
Stock transmission with the Axial 2-speed kit. | |
08-07-2019, 06:03 PM | #35 |
Newbie Join Date: Nov 2013 Location: Long Island
I'm running a Mamba X and Tekn 412HD with 11 tooth pinion on 3S and it's more then I could hope for.
08-07-2019, 06:30 PM | #36 |
08-07-2019, 10:35 PM | #37 |
11-14-2021, 06:49 PM | #38 |
Newbie Join Date: Oct 2008 Location: Sacramento
With brushless do we want sensored or uncensored? kv? I'll be running 3s but don't know enough about what to choose in brushless.
11-14-2021, 07:00 PM | #39 | |
Quarry Creeper Join Date: Feb 2018 Location: East otis
Sent from my SM-G970U using Tapatalk | |
11-14-2021, 07:01 PM | #40 |
Sensored is better for most applications unless you go for the Holmes Revolver outrunner motors - they make a lot of ESC noise, Holmes is making an ESC that quiets them down. Mine is pretty heavy because of a lot of thick stainless links and is running a Revolver 1800kv and a Mamba X, and I switch between 3S and 4S use. Works great, I don't mind the noise, but eventually I'll upgrade to the newer ESC technology for the sake of others around me! |
Brushless kv choice for Bomber - Similar Threads | ||||
Want input for hh brushless motor choice | ssdub33 | Electronics | 0 | 02-27-2014 12:58 AM |
1.9 brushless motor choice | idk | Electronics | 14 | 11-19-2013 06:27 PM |
Help with brushless motor choice | orlandocrawler | Newbie General | 16 | 01-24-2011 09:46 PM |
Brushless Choice | neillarson | Axial SCX-10 | 1 | 05-22-2010 07:46 PM |
