12-13-2017, 02:34 PM | #1 |
Newbie Join Date: Dec 2017 Location: springfield
| quick questions
ok couple of questions
12-13-2017, 02:59 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: quick questions
If im not mistaken, the kit comes with HD gears. I went with beeftubes + FI Spools to make sure I wouldnt have to worry about the axles anytime soon. They also add weight down low to help the CoG. It's a very good alternative to the aluminium housings and you can spend more money on links, wheels or the electronics. Sent from my Nexus 6 using Tapatalk |
12-13-2017, 11:27 PM | #3 |
Rock Crawler Join Date: Mar 2016 Location: Zagreb, Croatia
| Re: quick questions
4. Shock brand has nothing to do with sway bars. |
12-14-2017, 04:37 AM | #4 |
| Re: quick questions
If you have the kit, it definitely comes with HD differential gears already. Plastic axles hang up less when crawling, beef tubes add strength and weight in just the right spot. Spools are a great idea, LockedUp F1's are excellent, as well as Holmes and Incision. I use the ------ (edited wrong brand) Dlux Fab plastic OCP axle housings with the upsized pinion bearing, and SSD also has a plastic housing with the larger bearing - but with a centered pumpkin and only for the rear axle. BTW - Boom Racing Kronic tubes are a cheaper alternative to the Beef Tube brand, I have a stainless steel set. With those installed, Vanquish trusses & SSD diff covers - I am not worried at all about the strength of my plastic axle housings! (lastly, for slow crawling - no swaybar is needed, some say it is even better without - but for any running at speed, install the swaybar.) Last edited by durok; 12-17-2017 at 07:20 PM. |
12-14-2017, 06:56 AM | #5 |
| Re: quick questions
Xtra Speed tubes are even cheaper (RCmart, 10$ and free shipping).
12-14-2017, 07:56 AM | #6 |
Newbie Join Date: Oct 2016 Location: Dallas
| Re: quick questions
Sway bar helped mine stop flipping over every time it turn at speed.
12-14-2017, 05:56 PM | #7 | |
| Re: quick questions Quote:
would it be smart to run beef tubes and scale brake weights or just beef tubes or just scale brake weights Last edited by Lightning Bomber; 12-14-2017 at 06:00 PM. | |
12-14-2017, 09:39 PM | #8 |
| Re: quick questions
Either brass or stainless tubes, and while BeefTubes were (I believe) the original designer, they are way overpriced for simple tubes of metal - so whatever brand is the cheapest is best, in my opinion. I paid less than $30 for a full set of front and rear stainless Boom Racing Kronik axle tubes from AsiaTees. I don't think you need to add extra weights, but one nifty trick is if you get lockers for your differentials - get the Locked Up RC F1 "Heavyweight" spool for the front axle and the standard F1 spool for the rear.
12-14-2017, 09:44 PM | #9 |
| Re: quick questions
Yeah I got brass tubes front and aluminium rear with Standard FI spools x2 and I think I will miss some weight on the back since I wont be using the spare tire. Would you guys recommend weight in the fuel cell or hub weight? Sent from my Nexus 6 using Tapatalk |
12-14-2017, 10:47 PM | #10 |
| Re: quick questions
Fuel cell is too high.
12-14-2017, 11:10 PM | #11 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: quick questions
I would get knuckle weights before I'd consider any weight that rotates. I've seen plenty of "brass knuckles" for the SCX10 II, but none for AR60 based rigs. Sent from my Nexus 5 using Tapatalk |
12-15-2017, 01:57 AM | #12 | |
Rock Crawler Join Date: Apr 2015 Location: Paola, ks
Dlux makes the best knuckles on the planet for any rig. You can get them in brass or aluminum. Slugged to add or remove weight. You can have carbon, brass, or aluminum uppers and the same for the lowers. Best of luck on your project. Sent from my SM-N920V using Tapatalk | |
12-15-2017, 04:31 AM | #13 |
| Re: quick questions
I'll back-pedal just a bit on the F1 "heavyweight" recommendation as I myself went with Holmes lockers (they're the lightest of all the aftermarket lockers/spools) but the important thing about rotating weight is that if it is kept close to the center is has much less negative effect than if it it is further away - for example, heavy hubs are better than weight on the outer rim... so if you HAVE to add it, add it to the right places. With these R/C vehicles some extra weight can make for a more realistic driving experience. Extremely light vehicles tend to bounce rather than cycle through their suspension. If you're slow-crawling the weight can also be beneficial if kept low and centralized. Some weight can allow for more tire grip. However, running fast with heavy rotating mass can quickly wear out driveline parts. A lot depends on personal preferences... I'm not running in competitions, myself. |
12-15-2017, 04:33 PM | #14 | ||
12-15-2017, 04:45 PM | #15 |
| Re: quick questions
"lockedup rc" in Google Then look for bomber and ar60 Sent from my Nexus 6 using Tapatalk |
12-17-2017, 05:04 PM | #16 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
| Re: quick questions
Twice in this thread there are mentions of LockedUp AR60 big bearing housings, (both without links) Locked Up RC - Scale Performance Parts) have heaps of great stuff, lockers included but these housings must be really well hidden on thier site cos I sure as shit can't find them. Can't help but think they really mean Dlux Fab, he's the primary one doing mod'd inner pinon bearings for AR60 housings that I've heard of |
12-17-2017, 05:58 PM | #17 |
| Re: quick questions
LOLOLOLZ....................sheesh... I be flat busted on that, my bad. Well, heck - at least I bought them! |
12-17-2017, 06:28 PM | #18 |
| Re: quick questions
Yeah lockedup rc makes a very good locker and shims for the ar60 axles. Dlux fab makes the modified housings with bigger bearing and other nice parts including à sway bar kit. Sent from my Nexus 6 using Tapatalk |
12-17-2017, 07:18 PM | #19 |
| Re: quick questions
OK, OK, OK, I got it. I have had extremely bad insomnia for 3 weeks. You can witness my postings to see that I have been up all night! To be clear - I bought those housings from Dlux Fab on 11/14/2016. I just couldn't keep it straight in my head when I made the post. Editing now... |
12-18-2017, 05:27 PM | #20 | |
I don't even look at posting time, I'm 14-16 hours ahead down here so don't even do the calc to see who's posting up late. I was sure I knew who you meant, didn't want to confuse the newer guys is all. | |
quick questions - Similar Threads | ||||
Quick questions | Silversamps85 | Large Scale Rigs | 1 | 02-04-2010 03:37 PM |
Two quick questions. | Breatholdiveri | Losi Mini-Rock Crawler | 9 | 10-18-2009 09:32 PM |
quick questions | STAT | Axial AX-10 Scorpion | 8 | 10-08-2008 04:21 AM |
quick questions | andres-tavares | Newbie General | 31 | 12-28-2006 04:58 PM |
