![]() | #101 | |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| ![]() Quote:
Sent from my SM-G960W using Tapatalk | |
![]() | #102 |
Rock Crawler Join Date: Dec 2014 Location: So Cal
10-12 lbs, variance with how thick of material I use for the body. Gearing, I need to do the math, 20 mph tops. What is the ticket for the multi channel radio and why one over another? Shielding may be an issue with mine (body) if there is one better than the other. ~ $250 getss me a 2200kv sensored and 25v Mamba X. ![]() ![]() |
![]() | #103 |
Waiting for electronics to be installed. Going to strip the go fast car for the go slow car. Platform to the right of the tranny is for the speedy, servo goes somewhere in the upper left, receiver wherever. Note the center shafts. Should have taken video of the "drop test", I don't have any idea why people think that is cool. I need to clearance/notch the rear arms for minor wheel rub and then its testing time!!!! It has been a 1-1/2 year ordeal to get this far along. ![]() ![]() ![]() ![]() ![]() |
![]() | #104 |
Ooh, looking good Sent from my SM-G960W using Tapatalk |
![]() | #105 |
It's alive......wierd science. There are a few gremlins to kill, the first being the steering. I drove it without steering anyhow. Linkage has to be re-thought. The diffs have a nasty gear mesh noise that needs to be addressed- gremlin. Rear shocks need oil, tighten the slipper clutch- no gremlins there. Then there is the battery box, have to remake that too, my 3s don't fit. I would say it does about 12 mph with the gearing on it now, I will go up from a 14 to a 22 on the pinion and she'll do 20 easily. CLICK IMAGES TO SEE SHORT, UNEDITED VIDEO CLIPS Note: No steering!!! ![]() ![]() ![]() I simply ran out of talent on that 12" drop!! |
![]() | #106 |
| ![]() ![]() The guts of my rig so far. Shooting to have the steering done/installed by tomorrow. No slip in the clutch, she climbs like a goat, low cg and appears to be able to "haul the mail" as well. Happy so far. Anyone run on carpet? The wheelies when on the gas and then nose wheelies when you stop. Priceless!! |
![]() | #107 |
Drove it with steering tonight! Its going to need a BIG servo, what I have in it is a gelding. Looking for something inexpensive with mega torque. Suggestions? Anyone use loc-tite on their beadlock screws? Tightening after every run run is getting old.
![]() | #108 |
RCC Addict Join Date: Jun 2017 Location: Canada
The powerHD chinese servos are cheap and seem tough, JX as well. For the beadlocks, I mounted eBay wheels with SSD scale bolts and used blue locktite on every screw. I don't want to lose them... Sent from my Pixel 2 XL using Tapatalk |
![]() | #109 | |
| ![]() Quote:
I have one of those in it now, had a flexing issue, so I it should work for now. Needs aluminum bellcranks and a double shear tab to the servo mount I made (flexes as well, and its 1/8" aluminum!!!!). Now I have broken the transmission, I think the pin on the lay shaft went bye bye, we'll see tomorrow evening when I tear it apart (hopefully). I'm really trying to get this out for a crawl test at some point this weekend, running the ~12 mph spur gear until I learn how to go slow. Put a simple flat body on it so she's not naked. I already have a roof and hood, so easy peasy. Motor stays cold, speedy hits 102 degrees. On a happy note, she blazes through the whoops, suspension doing what its supposed to, so I am a proud "daddy". | |
![]() | #110 |
I've broken that same roll pin in 2wd Traxxas transmissions a few times and have taken to just drilling the hole out a bit and pressing in a 2.5x10mm pin (wheel hex pin.) Sometimes the top gear needs a little clearancing, other times the pin presses in perfectly. Has held up to a 36x65 3100kv on 4s with a locked diff... so far!
![]() | #111 |
I stuffed an allen wrench piece into my go fast car then welded the gear to the shaft. I'll be trying the wheel pin method this time, much easier. Thanks for the idea. ![]() |
![]() | #112 |
Its torn apart, the stupid little screws on the spool came loose, so I guess I should be happy that its an easy fix. That was my gear knock, not the rear diff. :^) This thing actually comes apart pretty quickly. Reassemble time and maybe get to crawl this afternoon!!
![]() | #113 |
| ![]() ![]() ![]() ![]() ![]() Ready to test crawl next Sat. afternoon, battery installed, still needing a box for it. Knocked out a temporary body with some scotch tape "fasteners" so she's not naked and afraid. Note the hood mounts. ![]() |
![]() | #114 |
sketchiness abounds... ![]() Join Date: Jun 2016 Location: Austin
![]() | #115 |
Thanks for that info. I will need to find them in about 15 mm lengths for my body stand off mounts. I am soooo anxious to see what it will do. All the weight is down low so it seems to handle well. I'm going to the same place I "crawled" the go fast car and get some video there. Hopefully there will be a YouTube video soon after. ![]() |
![]() | #116 |
If panels haven't been installed with those coarse thread M2.6 screws, M2.5 screws work just as well and they are much easier to find in various lengths. 4-40 screws would work as well if you have access to SAE hardware, they are just a hair larger than M2.6.
![]() | #117 |
I just couldn't wait for Saturday, so I crawled this afternoon. As far as I can tell, this thing is amazing. Granted, I have nothing to compare it to, but it pretty much goes anywhere and well. Here are a few screen shots from the video I shot to prove it works. Well, I guess that needs to be video. It does need a beefier steering servo. Run time is great, 2 hrs of messing around and it still goes on the first battery. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() I put it on the roof 3 times, no so much as a scratch or dent anywhere. .040 body takes a beating. Scotch tape is the duct tape of the RC world!! |
![]() | #118 |
I love that rear suspension. How wide is it? It looks wider than stock ar60s. Sent from my SM-G960W using Tapatalk |
![]() | #119 |
![]() | #120 |
Rock Stacker Join Date: Jul 2018 Location: Jackson
Amazing looking rig! And I'm still impressed that you got the inward side of a 3" wheel, inside a 2.2" tire. ![]() Same wheels I run on my Slash 4x4. Hate those damn screws though. |
CFM drops a Bomb: Bomber Fab build and upgrades | CarterFab | Axial RR10 Bomber | 132 | 01-24-2018 09:42 PM |
Mac experts- Possible Mac firmware issues. Upgrading OS | gregrocks90046 | Chit Chat | 7 | 04-02-2013 08:13 PM |
