03-11-2018, 03:27 PM | #21 |
Quarry Creeper Join Date: Sep 2017 Location: UK
| Re: Torque twist problem |
03-11-2018, 03:33 PM | #22 |
Quarry Creeper Join Date: Jan 2007 Location: Las Cruces, New Mexico
It’s less than 5mm taller over stock. With it this way I didn’t see the need for the sway bar at all at least for rock crawling. I don’t know how it would do if you used the truck for anything other than crawling since the chassis gives a little under stress with the shocks mounted here. With the truck being mostly stock running stock tires and even dog bones it did really good today at my comp.
03-15-2018, 10:42 AM | #23 |
Quarry Creeper Join Date: Dec 2013 Location: NoVa
Received a "Team DC" ATTS transmission last night. It seems pretty well thought out although the top shaft bearings are not tight enough in their bores. I've ordered some Loctite 641 to fix the issue. The case is just a little fatter than the standard SCX10 transmission but, not as big as a Wraith. Should be interesting to see if it holds up and eliminates the torque twist. Front output & rear output turn opposite directions which also requires one of the axle ring gears to be flipped. I'm in the middle of a Bomber scratch build so it might be a while before I'm able to report on the performance.
07-06-2018, 08:13 AM | #24 |
Newbie Join Date: Jan 2016 Location: annville
any update on this tranny , been considering one myself but can't find much feed back .
07-07-2018, 02:39 AM | #25 |
| Re: Torque twist problem I did this to my rig. Basically it makes the rear shocks twice as stiff. Also more weight in the front tires helps.
07-07-2018, 02:45 AM | #26 |
| Re: Torque twist problem That's almost the same as my idea https://www.thingiverse.com/thing:2301295 |
07-07-2018, 10:20 AM | #27 |
RCC Addict Join Date: Dec 2014 Location: So Cal
I'm guessing this is a solution to a SLOW crawling issue, right? ^^^^^^^ pic. You would accomplish the same thing by stepping up your spring rate and oil weight slightly to increase the dampening (thus making the dampening rate the same as you like it with the shocks mounted at the axle) and leave the shocks in the stock position so you don't lose articulation and suspension travel.
07-13-2018, 01:34 AM | #28 | |
| Re: Torque twist problem Quote:
07-16-2018, 12:44 PM | #29 |
Quarry Creeper Join Date: Aug 2015 Location: Worthington
Underdriven gears front and rear + axial sway bar + xtra speed axle housing = pretty much no torque twist. My bomber way barely able to lift one front tire on high grip concrete from a stop with full throttle. Running Holmes Hobbies 21t 550 can on 3s.
07-28-2018, 01:39 PM | #30 |
Just saw this topic come back up and thought I'd give an update on the Team DC transmission. The engineering was perfect, the construction tolerances & steel used in the gears was horrible. If Vanquish made this type transmission, everyone would have one. When I received the trans, I noticed there was allot of play in the output shafts so I took it apart. All the bearings were loose in there bores and the shafts were loose in the bearings. I bought some Locktite 641 which is a bearing retaining type of glue & used some shim stock to fix the bores that the bearings sit in. It worked for a while until the gears started to wear down. Since it's not like there are any replacement parts, it's trash. This was run on 3S with a Holmes TrailMaster pro Brushless. |
07-28-2018, 01:44 PM | #31 |
I'm not having any torque-twist issues on mine, but I think the 6" tall Losi Maxxis Creepy Crawlers paired with the kit sway bar are to thank for this... Standard kit gearing, Revolver 1800kv, 3S (currently - hoping to get back on 4S in the near future). |
Torque twist problem - Similar Threads | ||||
Why is Torque Twist A Problem | jdnoss | General Crawlers | 14 | 06-02-2016 03:10 PM |
ECX Temper Torque Twist Mod - Reduce torque twist | driftomaniacs | Scale Videos! | 0 | 05-14-2016 04:39 PM |
another torque twist problem | Axialfan19 | Axial AX-10 Scorpion | 22 | 07-07-2010 08:00 PM |
Solved my Torque Twist Problem | tbizzle | Axial AX-10 Scorpion | 13 | 03-22-2010 07:35 PM |
suspension problem and it isnt torque twist... | firstumustcrawl | Axial AX-10 Scorpion | 5 | 12-16-2007 02:08 PM |
