Yeti or Bomber? I have been around here for a while, and built a few rigs, including comp rigs, SCX10s, a few Wraiths, short course, etc. I'm looking for what would essentially be a higher speed "basher". I realize I'm not dropping a 4S system in it and making it go 70 mph. Just around the yard, take on vacation, etc. Basically not crawl-specific that I can turn the kids loose with without breaking all the time. I have two brand new in the box Yeti kits sitting here, but I'm thinking the solid front axle of a Bomber may be a better option (I'm thinking durability and lack of fixing, not exactly performance). Am I wrong in thinking the Bomber would be a better option? And I know the axles inside and out, would probably truss them anyway. Thanks! |
Re: Yeti or Bomber? I doubt the bomber can be better at speed than a yeti. The bomber is made to be a versatile rig for rock racing. It can crawl / trail and handle moderate speed on limited stretches of flat land but it will never be a 40+mph rig. If you don't want to use the crawling side at all, build the yeti with vanquish upgrades and make it à speed demon. Or better yet, buy an Arrma RTR rig and bash like a pro Sent from my Nexus 6 using Tapatalk |
Re: Yeti or Bomber? Yeti if you want to go 30MPH + Bomber if you want speed and still be able to crawl. I have had both and like the bomber why more then the yeti. I also have found the bomber to more durable. |
Re: Yeti or Bomber? Quote:
The yeti and the bomber are both very versatile but between scale appearance and plastic construction you will need to spend a fair amount to get either to bashable. The yeti, with its ifs and lower CoG will probably, with some stiffer foams in the tires, spend less time on its roof with the young ones at the wheel. I've had very little breakage with my yeti, but then I don't drive it like it is virtually indestructible. |
Re: Yeti or Bomber? I wouldn't recommend the Yeti ever. Don't own one, but I've seen some in the wild and I'm not impress. The Bomber is an awesome rig, but it's not a high speed basher. What's your budget? |
Re: Yeti or Bomber? I guess the more I think about it, I'll stick with the Yetis. I have a Wraith with a DMG rear stubby cage that probably performs about the same as a Bomber would anyway. The Yeti would be a little different. Thanks! |
