Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: To get or mot to get
Old 05-08-2018, 11:04 AM   #41
Default Re: To get or mot to get
Originally Posted by MickSz View Post
If you lengthen your top links slightly you can adjust the pinion angle. Just unthread them a couple turns.
Maybe ill try that when i get home tonight. Does anyone lnow if the incison links are longer? Will the incision yeti rear links work?
Sent from my Moto Z (2) using Tapatalk
wcdfmt510 is offline   Reply With Quote
Old 05-08-2018, 11:06 AM   #42
The bomber has a wraith front end and a yeti rear end.
So the kit is already yeti lenght rear arms and uppers.
Sent from my Nexus 6 using Tapatalk
Jboucher is offline   Reply With Quote
Old 05-08-2018, 11:08 AM   #43
The incison rear yeti links are 124mm without the rod ends and the stock axial aluminum links are 101mm without rod ends
Old 05-08-2018, 03:19 PM   #44
There are tricks as MickSz mentioned to correct the pinion angle - for example, JEC Racing/SuperShafty trailing arms are approximately 3mm shorter than stock arms which raises the rear pinion angle for better clearance over terrain - they mention it in their advertising. Even tiny adjustments can make a difference.
durok is offline   Reply With Quote
Old 05-19-2018, 10:46 PM   #45
I just used my incision ss yeti rear links. They are about 2-3mm longer definitely helped
Old 05-19-2018, 11:22 PM   #46
How is this servo
Old 10-22-2018, 10:51 AM   #47
How's this one coming? You get it running?
I'm just building my kit...was browsing Bomber threads.
Browneye is offline   Reply With Quote
Old 10-22-2018, 10:52 AM   #48
Reach the bottom of your pockets only once, get a HH SHV500v2!
Sent from my Pixel 2 XL using Tapatalk
Old 10-22-2018, 06:55 PM   #49
Originally Posted by wcdfmt510 View Post
How is this servo
Theyre decent easy to waterproof but...... Loud as hell buzzzzzzzzzzzzzzzzing power hungry servo get very annoying very fast
Sent from my LG-M703 using Tapatalk
jokersinsanity is offline   Reply With Quote
