10-16-2018, 06:05 PM | #21 | |
Rock Crawler Join Date: Aug 2005 Location: Asia
| Re: Akumu - bomber build Quote:
Got the esc used but almost prestine condition with a sensored hw 10.5t motor. but i opened to use my 2650kv unsesored 4 pole motor, our coming comp is more of a time attack/U4 variant. Last edited by v33; 10-16-2018 at 06:10 PM. | |
10-16-2018, 06:07 PM | #22 |
finally finished the custom carbon fiber panels... thanks for viewing! |
10-22-2018, 04:36 AM | #23 |
created a custom aluminum mount for a rear light bar... https://youtu.be/jtf15B4QRfU Thanks for viewing! |
12-01-2018, 01:23 AM | #24 |
tried running the rig on a U4 style course with CI single stage closed foams and it just kept flipping over. hahahaha made changes to the foams, 2 stage hack job while i wait for the CI 2 stages foams to arrive. also finally replaced the king shocks to some slash powerstrokes dampers. will test this rig tomorrow in a G6 style trail... hope it works with these temp foams. thanks for viewing! |
12-02-2018, 04:49 PM | #25 |
Rock Stacker Join Date: Jul 2018 Location: Jackson
Nice build. Not sure if shortening the link on your sway bar would help any or not?
12-02-2018, 08:28 PM | #26 |
@NitroBugg, Thanks! i got the anti-swaybar from my 1st bomber (got it used) in this configuration, i think it is stock, I will need to double check. but i have not played around with it, my drifters when i started all had the same orientation, if i am not mistaken, and that was more than 10 years ago hehe my initial run yesterday was good, still a little bouncy but the DIY foams are brand new and a bit stiff. ordering the crawler innovation 2 stage foam, but it will wait... holiday rush here is really bad, so I will be ordering them 1st thing next year. Last edited by v33; 12-02-2018 at 08:31 PM. |
01-04-2019, 07:25 AM | #27 |
running on flat ground is not a problem with an unsensored motor/esc. the rig is so stable even in tight turns... i am loving it. would like to get it crawling one of this days but would like to replace the motor/esc to a sensored one before i do. i am mostly bashing now, 2.2mah lipo battery gets eaten up pretty quick... need to get a high mah for it. thanks for viewing! |
01-04-2019, 10:58 AM | #28 |
That's an excellent quality photograph of a very sexy Bomber, well done! Looks mean and ready to dominate it's next U4 race... |
01-11-2019, 09:47 AM | #29 |
still working on the rear section... no colored blinker lights in the rear yet, had this build on hold for weeks and have not even mounted the rad properly. thanks for viewing! |
01-13-2019, 06:24 PM | #30 |
Rock Crawler Join Date: Aug 2010 Location: Esko
Wow, that is awesome! Sent from my iPhone using Tapatalk |
02-09-2019, 02:40 AM | #31 |
geez... i missed to C3 events due to the servo running out of juice. at first i thought it was my 3S batter, i was using a 2.2mah, but it turns out that i needed to install a BEC. got me a Castle 10amp BEC and did a bypass connection that powers the servo directly... perfect! now i am ready to go all out on the next event. |
02-10-2019, 04:50 PM | #32 | |
Newbie Join Date: Dec 2018 Location: JAPAN
what was the issue with the VP motor mount? how did you fix the motor not spinning? | |
02-17-2019, 04:15 AM | #33 | |
Love this rig... Class 3 is not so popular here, but i will push to get it mainstream this coming months. | |
02-17-2019, 06:23 AM | #34 |
Rock Stacker Join Date: Aug 2010 Location: outside
What are the wheels your running? I really like em. Sent from my iPhone using Tapatalk |
02-19-2019, 02:15 AM | #35 | |
https://www.asiatees.com/display?Axi...Yeti&id=101052 | |
03-25-2019, 09:05 PM | #36 |
finally got the rear led lights painted. just did not have translucent yellow for the 2nd led on the left... i think this will do for now. https://youtu.be/N0c2oXf0vYo this is a list of what's installed currently... Axail RR10 Bomber kit version base Vanquish Stage 1 kit Vanquish servo mount Vanquish anti sway bar Vanquish motor mount Hobbywing 10BL120 w/ 10.5T motor Sanwa MT4 w/ wp reciever Sanwa high-torque wp servo Castle BEC GPM beadlock wheels Proline Swampers 2.2 Proline Powerstroke Led Lightbar - unknown manufacturer Custom full Carbon fiber panels thanks for viewing! |
03-29-2019, 09:51 AM | #37 |
Newbie Join Date: Oct 2018 Location: Castle Rock
Thanks for sharing... it's got to be one of the coolest looking bombers I've ever seen!!! |
03-29-2019, 10:26 AM | #38 |
This thing looks straight lean and mean! Nice build! |
04-05-2019, 09:29 PM | #39 |
Thanks Guys! ___________ I'm trying some new shoes, voodoo with 2 stage foams and SSD wheels (not a fan of this wheels... they are so plain looking). We are having another C3 comp on the 14th, this new setup should perform well... but still thinking if i need to put some weight on the front tire. still looking into that. thanks for looking! |
06-02-2019, 12:04 PM | #40 |
changed a few things on the bomber, not sure if you noticed the previous changes... replaced the plastic rear shock tower with Boomracing Shock Tower With Strut Bar, also replaced the lower axle link connectors. Last week I got an Aluminum Front Offset Axle Link Mount from Boomracing. Thanks for viewing! |
Akumu - bomber build - Similar Threads | ||||
My Bomber Build | angrchair | Axial RR10 Bomber | 182 | 02-21-2021 05:10 PM |
Akumu - SCX10 build | v33 | Axial SCX-10 | 31 | 10-09-2019 05:15 PM |
Akumu - SCX10 II build | v33 | Axial SCX10 II | 61 | 09-07-2019 07:01 AM |
Akumu - Ex Real build | v33 | 1.9 Scale Rigs | 7 | 10-03-2018 06:54 AM |
Akumu - Yeti build | v33 | Axial Yeti | 4 | 03-28-2018 11:54 PM |
