3D bomber chassis 1 Attachment(s) This is for anyone interested in 3D design who has a bomber and access to fusion 360. Which is free for students and hobbiests! I plan to use this for mocking up parts, Its not perfect but its close enough for everything I need. some of the bends were a tad complicated to measure. So far all the mounts seem good. Link to fusion 360 file Link to Thingyverse files |
Re: 3D bomber chassis 3D printing the panels or the chassis too? |
Re: 3D bomber chassis The Hood and doors are on thingyverse ready to be printed RR10 Bomber Hood RR10 Bomber Doors There are 3 different door designs if you look at my designs there also |
Re: 3D bomber chassis The Roof Might be printable as-is if you export it as a stl, but I plan on making it thicker and cutting out the bottom to wrap the cage in the future. This will make it heavier but stronger. With the bottom being so hollow you will need to use a lot of support to print the roof. Just to busy to get much done on it at the moment, but its summer and some people might have the time to enjoy to files so I shared what I have. |
Re: 3D bomber chassis I wouldn't attempt to print the Chassis, I think it would be much to fragile and take massive amounts of support. Its mostly to import into a 3D program to give you reference points on the size of parts you would like to design. Like a radiator for behind the seats, there is a section of chassis that could be removed and replaced with a new 3D Designed and printed chassis that has a radiator attached to it. I just don't have to time at the moment to design it my self so... |
Re: 3D bomber chassis Or you could edit the body panels to say remove the motor from the hood and add something else. Like that giant skull on the wraith thingyverse hood :P |
Re: 3D bomber chassis You made these? Really nice. Now all I need is a bomber.... Sent from my SAMSUNG-SM-G920A using Tapatalk |
Re: 3D bomber chassis Those door panels are really cool, and the hood is wicked ! Thanks for posting those files, I'm sure they'll get used. |
