Re: I don't fawk around. fawkin around with a "scaler" eh? did you quit drinkin too? you can put the bamf builders shaft in just about any axle. |
Re: I don't fawk around. Quote:
#BAMFA shafts can fit many axles for sure but the housing has to allow for them. Stock ar60 housings won't allow them but all VP housings will with them lathed out. |
Re: I don't fawk around. the lathe is my favorite tool. |
Re: I don't fawk around. And then this happened. http://i537.photobucket.com/albums/f...psuuhwpg1h.jpg Mamba x and an ax2 trans. Upped the pinion to a 12 and she boogies. I'd like a little bit more top end for that little bit extra to correct attitude on big jumps but for now it's a hoot. |
Re: I don't fawk around. |
Re: I don't fawk around. Needed something to keep the chassis half ass protected. http://i537.photobucket.com/albums/f...psvy1p4sor.jpg |
Re: I don't fawk around. In keeping with my not fawking around mantra I quit fawking around this evening. I've been running a 2300 roc 412 tekin motor on 4s and it has plenty of power but when I really need wheel speed its lacking top end to correct attitude in the air. I have an ax2 trans so top gear is 1.78:1 with a 60ish tooth steel HR spur and I've been walking pinion size up from 11 to 14 trying to find the sweet spot and coming up empty handed. Enter a 3300 pro4 tekin. Same 60ish tooth spur and an 11 tooth pinion, still on 4s and it's a fawking missile. Too fast to control flat out but the one time I hit the good spot on the nearest speed bump ( :lol: ) I blipped the throttle and landed on the spare tire. Success! :mrgreen: It will now wheelie in first gear, it's about as fast as a stock brushed bomber but that second gear power shift makes it disappear. :shock: http://i537.photobucket.com/albums/f...psrlqwctpz.jpg |
Re: I don't fawk around. Ya baby, "thumbsup" Now we’re talking |
Re: I don't fawk around. Tinkered with the suspension a bit and lowered it about 3/8" up front and 1/2" out back. Dropped the tire size back down to a standard 2.2 sx too. Still hauls ass but is far more stable. http://i537.photobucket.com/albums/f...psg3dodqpr.jpg |
Re: I don't fawk around. Swapped out the skid for a bomber version from the wraith skid that it had. Used a DMG adapter plate to mount the ax2 trans. Better geometry and all the screws actually get used now to mount the skid. :lol: http://i537.photobucket.com/albums/f...ps0a8hhq5b.jpg New shoes too. Gold klrs on locked up wheels. We shall see how long they stay on or not. http://i537.photobucket.com/albums/f...pslwiqvcng.jpg |
Re: I don't fawk around. Also decided to swap out the trashed old C10 for the beat up aluminum panels that the new project bomber came with. Here is the family portrait that will last until tomorrow when the U4 (left) goes to it's new home. The project bomber (right) is going away soon too. http://i537.photobucket.com/albums/f...psnpb2enp2.jpg |
Be interested to see what you think of them.... |
I've had them before on the front of a sporty. Tried everything under the sun and finally in an admittance of defeat cut the sidewalls out and put them on a pair of pins to make modern day boss claws. They rock in that use. :lol: These weren't even broke in when I got them but after a bunch of drifting in the parking lot they are getting roughed up. That is crazy to me, drifting, not traction rolling on pavement. Let that sink in for a moment... If they work offroad, which I do suspect they will be good at they will stay put for a while. But the drifting thing has me cracking up. :lmao: |
Re: I don't fawk around. Lol....but you are running 6s...my god man...that would spin the tires on any surface. I suspect if you ran them long enough, they’ll be like slicks anyway :mrgreen: |
No 6s for this rig... yet anyway :lol: Just 4s for now. I won't step it up until I run a much lower KV motor. I did step up from an 11 tooth pinion to 12 tooth and wow, it gets it on now! :mrgreen: |
Re: I don't fawk around. So I like to party... http://i537.photobucket.com/albums/f...pswsqs7ndv.jpg Picked up a spring kit & mip bypass pistons. Bought the wrong pistons :lol: but they'll still work in big bores so no biggy. Went to blue main and tender springs but I need to step up to red, the blue is too soft. http://i537.photobucket.com/albums/f...psyijxx5i8.jpg Installed HR sway bars too. Had to get creative to use the front bar with a rock jock but it sorta works. When I swap axles I have a good idea to make it better. Also swapped to xl swampers on 1.5" 6 bolts. 6" standard/hard rear and 6" single stage front. Happy so far. http://i537.photobucket.com/albums/f...psasdmuyt8.jpg |
Re: I don't fawk around. Got any good shots of the front say bar? I am debating about it. I have the Vanquish rear. Seems to work better than the Axial one that came with the kit. Sent from my Moto Z (2) using Tapatalk |
Re: I don't fawk around. I have a friend's bomber with the same bars with stock axles & mounts. I'll take pics for you this evening. |
Re: I don't fawk around. Sway bar pics as promised albeit a day or so late. http://i537.photobucket.com/albums/f...psjqm9tuzn.jpg http://i537.photobucket.com/albums/f...psxggakzx5.jpg |
Re: I don't fawk around. So my partying ways continue. Thinking I might have a new output made in 6mm with a 2.5mm pin. http://i537.photobucket.com/albums/f...psvw9robdc.jpg |
