Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Bomber brushless system?
Old 09-13-2018, 11:07 PM   #21
Default Re: Bomber brushless system?
John HH I only see the 3500 in the XL version, is that correct and will be a great motor to run for crawling the Bomber.
Rumpelhardt are you running stock motor gear
Pjking is offline   Reply With Quote
Old 09-14-2018, 08:43 AM   #22
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
We are waiting for more 3500 standards, should be a week or two. The XL doesn’t have great startup, it’s designed for the yeti.
JohnRobHolmes is offline   Reply With Quote
Old 09-14-2018, 07:59 PM   #23
With the 3500 standard and Mamba X or Mamba Monster X, would stock gearing be good or would I benefit to gear down.
Old 09-15-2018, 04:45 AM   #24
Stock is fine.
Old 09-15-2018, 10:33 AM   #25
JohnHH, I've got a CC 1415 2400kv and Mamba Max speedy. I ran the maiden voyage yesterday. I have a Frankenstein build. I personally think it may need more power/brute grunt on the bottom. No drag brake, maybe that is the issue? It will also be geared way taller, so maybe the motor hasn'tbeen put to work. I'm wondering if a Momba X will bring my rig to life. Granted, I haven't programmed anything on what I already have so I don't know the performance tune, but is my setup strictly built to go fast?
EDIT/Fix: Bad clutch. Remedied that and holy cow, climbs like a goat and screams all out! MMX time and I'm golden.
MAC FAB is offline   Reply With Quote
Old 09-15-2018, 03:22 PM   #26
Thats great to hear...only thing left on my rig.
NitroBugg is offline   Reply With Quote
Old 09-15-2018, 09:13 PM   #27
What's the difference between the standard and stubby?
scithera is offline   Reply With Quote
Old 09-16-2018, 01:27 PM   #28
I'm running a Robinson Racing slipper and hardened pinion gear. I don't remember the gearing off the top of my head.
Rumpelhardt is offline   Reply With Quote
Old 09-17-2018, 02:50 AM   #29
The standard will have more torque, I'm not 100% sure but the stubby might have a tad smother startup, and size/weight.
Voodoobrew is offline   Reply With Quote
Old 09-17-2018, 05:28 PM   #30
I run the Sidewinder 8th with 2650 motor in my Yeti, crawls ok with a ton of power on demand, Bomber is getting the same set up...
Oxide80 is offline   Reply With Quote
Old 09-25-2018, 10:35 AM   #31
Any word on availability of these yet?
Old 09-26-2018, 01:01 AM   #32
I started with a mamba X and 1410 3800kv on 3S with 16/64 gearing and the axial 2 speed. It was rapid. I then changed to the higher ratio 2nd gear and changed back to 12/64. Speed was still most impressive.
I then took that out and put in a Mamba Monster X and 1515 2200KV. Changed to 15/64 and now run it on 5S. Its rapid, torquey and has superb battery life, as I rarely have to use full power.
thewildblue77 is offline   Reply With Quote
Old 09-26-2018, 07:30 AM   #33
Any day now.
Old 09-26-2018, 08:55 AM   #34
What battery are you using and how is it mounted?
Old 09-26-2018, 08:58 AM   #35
Just a 3000mah 20c from hobbyking. Can't think of the make...could be a flightmax. Fits in standard location, similar size to a 5000mah 3S venom.
Sent from my SM-G965F using Tapatalk
Old 09-26-2018, 10:44 AM   #36
Moderator
JatoTheRipper's Avatar
20C in a Bomber with a those electronics?
Old 09-26-2018, 11:19 AM   #37
20c, 3ah, 5s is over 1,100 watts.
TheLetterJ is offline   Reply With Quote
Old 09-26-2018, 11:24 AM   #38
Moderator
Ah...I missed the 5S part!
Old 09-26-2018, 02:59 PM   #39
MambaX and one of these motors...
https://www.rcjuice.com/motor-esc/br...sct-motor.html
or
https://www.rcjuice.com/motor-esc/br...ler-motor.html
I have the 2500kv Pro4 motor in my rig and it works awesome.
saddlesore is offline   Reply With Quote
Old 09-27-2018, 05:54 AM   #40
Moderator
or
I have the Mamba X and the 3000kv SCT motor for my Yeti kit that I'm currently building. Hopefully I'll have a trail report by next week.
For my Bomber I'm thinking about replacing my Castle slate can with a 40mm 1/8 scale sensored motor from RCJuice.
Jim85IROC is offline   Reply With Quote
Bomber brushless system? - Similar Threads
Best Brushless system for Axial Bomber Dawson4 Electronics 28 04-08-2017 09:20 PM
