09-19-2018, 03:58 PM | #1 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
| Budget bomber build servo poll.
Building bomber kit right now. Semi budget build but may splurge a bit on servo. Motor is holmes hobbies trailmaster 550 21t Esc hobbywing 1080 Probably cc bec and run a 3s lipo. Looking for servo suggestions. May splurge on a promodeler 470, holmes hobbies servo or savox 1230 Any decent budget servos out there? Any input on any servo appreciated. Been in this hobby a long time and I know you get what you pay for but now and then some budget gear comes along that's decent. Thanks |
09-19-2018, 04:16 PM | #2 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: Budget bomber build servo poll.
Can't recommend any budget servos because I don't own any, but the ProModeler is a good choice, I have basically the same setup you do and I've never needed more power than this can give, and that's on 7.4v. Sent from my SM-G960W using Tapatalk |
09-19-2018, 04:19 PM | #3 |
Rock Stacker Join Date: Aug 2018 Location: Orlando
Pro modeler if you got the $$$, look at torque vs time specs, reliability, waterproof?, and cost. I've run a savox 1283sg loved it broke the case internally. Currently running a reefs trip 5 in my bomber now more torque than the savox but not the speed. Waterproof no complaints other than needing a radio to set end points. Sent from my SM-G965U using Tapatalk |
09-19-2018, 04:34 PM | #4 |
RCC Addict Join Date: Jun 2017 Location: Canada
My build is exactly the same as yours for electronics and I decided to go all out on the servo. I got the Holmes hobbies shv500v2 and it's a Monster. Plugged directly to 3s, no BEC to deal with, it will move the 2.2 tires like nothing, it's completely silent and I have yet to get it over ambient temperature... Pay once, cry once. You won't need to replace it and they sell rebuild kits. Sent from my Pixel 2 XL using Tapatalk |
09-19-2018, 05:12 PM | #5 |
| Re: Budget bomber build servo poll. EDIT: I'm Likely off base with my comments below regarding Promodeler, I think I have got a bad one (which I will be sending back), I also have one that functions a lot better and doesn't stall quite so easily. I'd caution against using a Promodeler, I've had issues with the 470 going limp when it gets loaded up, this happens on 3 separate 470's and one is in my Brother's Gom and he's complained about it going all soft too. Its truly a well built servo and I really want to like it but something in the programming is not working well with crawlers and especially 2.2 rigs. I've tested this with a BEC and straight off a 2S battery BTW. I've broken a handful of the SHV550 V2's (and V1's) when bashing, the center pin is still a weak point in my experience but it is rebuildable. This servo lacks no power though and If you dont plan on bashing should be great. Last edited by HumboldtEF; 09-20-2018 at 10:29 AM. |
09-19-2018, 05:48 PM | #6 |
The 1080 will do 7v.
09-19-2018, 06:13 PM | #7 |
Rock Stacker Join Date: Aug 2010 Location: outside
Budget for me meant ebay special 20k. 20$. Not the fastest nor most powerful. But it does the job 85% of the time. Running cc bec haven’t turned up voltage yet but only see things getting better until it breaks Sent from my iPhone using Tapatalk |
09-19-2018, 06:25 PM | #8 |
| Budget bomber build servo poll. Last edited by Brake Weight; 09-19-2018 at 06:28 PM. |
09-19-2018, 07:02 PM | #9 |
Love my ProModeler s . That said your looking to save a few$$, so look at the PMds360. Not as much torque or speed or $$ $50.00 http://www.promodeler.com/DS360DLHV Hang up and Drive |
09-19-2018, 07:22 PM | #10 |
I guess I'm a servo snob these days. I don't use a servo rated for less than 500 oz so budget to me would be a G13 or Holmes since they're in the $100 range. I really liked my promodler V4, it is still going strong on the rig I sold it with 2 years or so after buying it. |
09-19-2018, 07:58 PM | #11 |
Tell me what I missed on the specs. But the China one I listed has better TQ and speed than the Promodeler. The China one. |
09-19-2018, 08:07 PM | #12 |
You miss the fact that China has little quality control and might be lying on specs without any kind of possible actions from the buyer. Don't get me wrong, I buy chinesium parts from time to time, my yeti jr is decked out in GPM racing. But you have to be ready to waste money. I had 2 parts plain wrong and not fit the yeti jr specs from GPM, they gave zero ****s... Sent from my Pixel 2 XL using Tapatalk |
09-19-2018, 08:53 PM | #13 |
Quarry Creeper Join Date: Jun 2017 Location: Yavin 4
I recommend the Savox 1230. I have 4 of them and have never once had an issue. One thing to get is a metal servo mount for the axle, the plastic one won't hold up for long with a servo that has some good power. I installed the one from Vanquish along with their servo clamps. Servo Mount Servo Clamp |
09-19-2018, 09:08 PM | #14 |
RCC Addict Join Date: Dec 2014 Location: So Cal
I like the idea of 500 oz, may look into that. $100~, thats pennies compared to R and D time and $$$$ for my build. Just seems that everything I build is based off theory in my head, so I cut corners on stuff I don't/can't actually make. Can someone tangibly explain the performance benefits of the brand name vs el cheapo, if the cheap one matched it's given specs? Rebuild kits are great, but I don't expect it to break in the first place. My go fast car has (had, put it in my Bomber) had the living crap beaten out of it for a few years, with many ~40 mph violent crashes. 300 something oz. Should have bought 50 of them, it doesn't die.
09-20-2018, 06:28 AM | #15 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
Budget servos are great on 1.9 rigs that go slow. On a 2.2 rig that's going to see some higher speed impacts, the servo needs to be robust. I run the Promodeler on my Bomber and I love it. In fact, I just bought another one for my Yeti build. |
09-20-2018, 08:11 AM | #16 | |
| Re: Budget bomber build servo poll. Quote:
Axle mounted servo + no servo saver + 2.2 tires + speed = hell on servos; save the hassle of multiple replacements and buy something good to start. I run a Promodeler 470 in my Bomber. | |
09-20-2018, 09:23 AM | #17 |
Newbie Join Date: Apr 2018 Location: Modesto
Savox SC-1268SG here with a aluminum horn with two cinch screws. it's my 4th servo after upgrading to metal steering links, and oversized tires. Been working great. Should have bought this one right away instead of going through lesser upgrades.
09-20-2018, 10:34 AM | #18 |
I've edited my post above about Promodeler, I think I might have gotten a bad one. The whole cheap vs expensive argument boils down to this for me, if you end up needing to replacing a cheap item 2 or maybe 3 times you've already spent more than if you had just started with an expensive one. I do not cheap out on servos anymore and cant recommend it. |
09-20-2018, 11:39 AM | #19 | |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
09-20-2018, 11:53 AM | #20 | |
Budget bomber build servo poll. - Similar Threads | ||||
FFWF's Budget Bomber Build | F1GHTF1R3W1THF1Re. | Axial RR10 Bomber | 168 | 01-26-2021 01:28 PM |
Budget RC Bomber kit build | Jim85IROC | Axial RR10 Bomber | 55 | 03-02-2018 12:57 AM |
Re: My so far Budget Bomber. | Dr.Newb | Axial RR10 Bomber | 1 | 01-23-2018 01:04 AM |
KurseD build: the Brass Bomber Budget Bucket | KurseD | RC4WD Trail Finder 2 | 15 | 05-26-2016 04:40 AM |
