12-01-2018, 09:07 AM | #1 |
Pebble Pounder Join Date: Apr 2011 Location: Madison
| RR10 as a primary crawler?
Gents, In terms of gearing, is there any reason the Bomber couldn't be geared to crawl as effectively as say an SCX10.2? |
12-01-2018, 09:11 AM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: RR10 as a primary crawler?
Well I think you can use a 9T pinion and a 68T spur in the RR10 transmission. Plus the 2-speed option for even more gear down. Should be plenty Sent from my Pixel 2 XL using Tapatalk |
12-01-2018, 09:20 AM | #3 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
You could also gear down both axles with underdrive gears Sent from my LGMP450 using Tapatalk |
12-01-2018, 09:46 AM | #4 |
| Re: RR10 as a primary crawler? |
12-01-2018, 09:53 AM | #5 | |
| Re: RR10 as a primary crawler? Quote:
Sent from my Pixel 2 XL using Tapatalk | |
12-01-2018, 12:52 PM | #6 |
Newbie Join Date: Jul 2018 Location: San Francisco
Playing with gearing (and/or adding a 2 speed) is still on my todo list, but the advice on the forum when I was getting started was that a good sensored brushless motor would make low speed crawling a cinch running stock, and so far, that’s been true. I’m running a Tekin Roc412 HD 3100, and I can still go fast, too. I’ll occasionally turn down the max throttle on my radio, too, which gives me even more control at low speeds. |
12-01-2018, 03:44 PM | #7 |
And if you are on a budget, the Holmes Revolver sensorless outrunner has arguably the best low-speed control of any brushless motor. My Mamba X / Revolver 1800kv pairing is nigh-on perfect on either 3S or 4S, geared stock. |
12-01-2018, 04:50 PM | #8 |
My hobbywing 1080 and trailmaster Sport 550 21T is able to run at snail pace and cost basically nothing! Sent from my Pixel 2 XL using Tapatalk |
12-01-2018, 07:07 PM | #9 |
I am still deciding on the powerplant and ESC for my Bomber Nummer Zwei - I already have the HH PP 540-L 4100kv "R"-type, and a huge Mamba Monster X.... But - I may throw them in a Slash 4x4 or something and just get another setup like you mentioned instead. I do already have the HW 1080 ESC and HH TrailMaster Sport 550 21t in my Ascender '72 K10, with a FlySky radio and DS3218 servo it's the ultimate budget build. The Bomber needs (or at least deserves) a better servo (2.2" instead of 1.7" wheels & tires), but otherwise would do great with that setup, no doubt about it. It's going to be lighter than the other Bomber - or maybe not. I can build it a couple different ways - still deciding, but it will be using the Xtreme Racing Carbon-Fiber chassis rails and a Lexan shell. I may kit-bash it with the existing Bomber and re-purpose both of them slightly. (Hell, it only took me around two YEARS to gather hop-ups and build the first one...) Last edited by durok; 12-01-2018 at 07:12 PM. |
12-01-2018, 08:15 PM | #10 |
Newbie Join Date: Oct 2018 Location: Honolulu
I’ve never owned a scx10 but I love my bomber with the stock gearing. Sent from my iPhone using Tapatalk |
12-03-2018, 09:58 AM | #11 |
Quarry Creeper Join Date: May 2017 Location: Devon
The only issue with the Bomber as a dedicated crawler is the stance, it's too damn wide! As a general jack of all trades it's simply brilliant. Perfect day out rig Sent from my Pixel using Tapatalk |
12-03-2018, 10:12 AM | #12 | |
RCC Addict Join Date: Sep 2017 Location: The OC
It CAN be geared comparatively, and makes a reasonable crawler. But it's a different class of rig, bigger tires, and surely not a scale crawler. So the question then is are you going to simply bash and trail run, or are you going to attend local crawling events? Or put another way...I got 4 crawlers before opting for a Bomber. And while it's great fun, if'n I could only have one rig it would be a Ascender or SCX10ii. | |
12-03-2018, 10:33 AM | #13 |
No, I wouldn't suggest it as your primary crawler and that's mainly dependent on the terrain. If you have extreme terrain that is going to challenge a 2.2 rig than go for it. If not a 1.9 rig is a much better choice.
RR10 as a primary crawler? - Similar Threads | ||||
First time crawler... RR10 (RTR) | HOLLYWOOD33 | Axial RR10 Bomber | 20 | 04-06-2017 11:03 AM |
Johnny's Class 3 RR10 Crawler | johnnyh66 | Axial RR10 Bomber | 22 | 01-10-2017 10:16 PM |
Simple primary trans? | Rockfrog | General Scale Talk | 6 | 02-28-2010 09:23 AM |
