12-01-2018, 12:58 PM | #1 |
Newbie Join Date: Oct 2018 Location: Honolulu
| Mamba monster X and Holmes hobbie puller pro reverse faster than forward
Hi, I just installed a mamba monster X and HH puller pro when going forward it is slower than reverse. Is this a programming/calibration issue? Thanks! Sent from my iPhone using Tapatalk |
12-01-2018, 03:09 PM | #2 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
| Re: Mamba monster X and Holmes hobbie puller pro reverse faster than forward
Try calibrating your throttle, and set EPA, and then if that doesn't work advance the motor timing on the ESC by maybe 5 or 10. I had similar problems with a Mamba X and a chinesium motor. Sent from my SM-G960W using Tapatalk |
12-01-2018, 03:16 PM | #3 | |
| Re: Mamba monster X and Holmes hobbie puller pro reverse faster than forward Quote:
Sorry I’m not too familiar with the EPA, what is that? Also I am waiting for my castle link to come in, am I able to adjust motor timing without that? Thanks! Sent from my iPhone using Tapatalk | |
12-01-2018, 03:25 PM | #4 | |
Sent from my SM-G960W using Tapatalk | |
12-01-2018, 09:38 PM | #5 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
The TRX-4 needs a reversed motor. The standard motor has zero advance so it works either way. I assume that you reversed the radio channel to get it working the in the correct direction for forward and backward. The problem is that the ESC still thinks that reverse is forward and vice versa. With the Castle Link you can set the motor as reverse and that should fix the problem. Unfortunately being a sensored motor you can't just switch 2 of the leads.
12-01-2018, 10:07 PM | #6 |
Was that a "Whoops...."? This is the Bomber sub-forum, not the TRX-4 sub-forum... |
12-01-2018, 10:20 PM | #7 | |
12-01-2018, 10:37 PM | #8 |
| Re: Mamba monster X and Holmes hobbie puller pro reverse faster than forward |
12-02-2018, 09:54 AM | #9 | |
I noticed that when I pull the trigger on my transmitter to go forward the red led lights up and reverse the green light ups. So does that mean it thinks it’s spinning it backwards? Anyone know how to fix it? Sent from my iPhone using Tapatalk | |
12-02-2018, 09:54 AM | #10 |
I should mention the wheels are going in the right direction though Sent from my iPhone using Tapatalk |
12-02-2018, 11:06 AM | #11 |
In the basic tab (in the castle link software) there is a option for motor direction, it can be set to normal or reverse. You likely just need too change that.
12-02-2018, 12:40 PM | #12 | |
Ya that’s probably the issue.... I’m waiting on my castle link to come in. No way to do it with the transmitter right? Sent from my iPhone using Tapatalk | |
12-02-2018, 04:41 PM | #13 |
Rock Stacker Join Date: Jul 2018 Location: Jackson
You could always "flip your diffs"
12-02-2018, 06:15 PM | #14 | |
Actually you can manually program it, check out the manual (starting on page 29) http://dzf8vqv24eqhg.cloudfront.net/...95-0290-00.pdf | |
Mamba monster X and Holmes hobbie puller pro reverse faster than forward - Similar Threads | ||||
faster in reverse than forward | dirtymike | Electronics | 9 | 11-09-2012 07:38 PM |
reverse is faster than forward | wassaakk | Newbie General | 6 | 07-01-2010 07:22 PM |
