Piano wire diameter for bomber sway bar What's a good diameter to use for a piano wire sway bar? I read through a few threads and there are probably several right answers. I plan on making one in a U-shape and tuning the stiffness by moving the links. The car is used mainly for general bashing and a lot of high speed stuff. My son just likes to beat the tar out of these cars. |
Re: Piano wire diameter for bomber sway bar What's wrong with the kit sway bar or the VP antirock? Sent from my Pixel 2 XL using Tapatalk |
Re: Piano wire diameter for bomber sway bar The Vanquish sway bar is 2.7mm if that helps? Sent from my Pixel using Tapatalk |
Re: Piano wire diameter for bomber sway bar Quote:
Re: Piano wire diameter for bomber sway bar Thanks. Theres nothing wrong with the vanquish setup other than it's already made. I just want to tinker a bit. |
