01-09-2019, 06:22 PM | #21 |
Newbie Join Date: Dec 2018 Location: LOST Angeles
| Re: no torque on crawling
well right now I am running a 13.5 t losi brushless with a 2s lipo.. I am sort of happy with the speed of this thing but I want it faster.. I am going to try a 3s cell and I am going to try and adjust the timing on the motor to a slight advance and monitor the heat.. Buckled down the slipper clutch and left a slight slip in it for the oh crap moments... The upgradeitis has already begun |
01-09-2019, 08:56 PM | #22 | |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: no torque on crawling Quote:
I bought the bomber kit and there isn't much of it left but the skid, cage and axles. Sent from my Pixel 2 XL using Tapatalk | |
01-10-2019, 07:58 AM | #23 | |
Which ESC are you running with that 13.5T motor? | |
01-11-2019, 02:40 PM | #24 | |
Also, I don't think the 13.5 losi will handle a 3s lipo according to the specs saying 7.8 is the voltage high on it | |
01-11-2019, 02:53 PM | #25 |
35mph and crawling there is only 1 choice: Mamba X for the AUX drag brake toggle with a good brushless motor. Puller pro 3500kv, castle 3800kv, tekin, etc. Sent from my Pixel 2 XL using Tapatalk |
01-11-2019, 03:17 PM | #26 |
RCC Addict Join Date: Sep 2017 Location: The OC
For component access, you can loosen the top front screws on the cage, remove the rear ones, and the whole top will pivot up and out of the way. Easy-peasy. I don't run a cover on my motor gears, or an interior, just for access. Worst case, there are three screws (four?) on each side, plus the radio box from the bottom, and the shocks - top or bottom, and the entire cage comes off in one piece. But I agree, it's a bone of contention for everybody. |
01-13-2019, 09:15 PM | #27 |
| Re: no torque on crawling Should I stick with 13.5t? I was looking at the holmeshobby trail master pro 540
01-13-2019, 09:24 PM | #28 |
| Re: no torque on crawling Quote: |
01-14-2019, 09:04 AM | #29 | |
What's a Bluetooth whip? | |
01-14-2019, 10:39 AM | #30 |
I'm assuming BT controlled led light whip. Maybe something like these: https://www.ebay.com/sch/i.html?_nkw...ed+whip+lights I'm more focused on the crawling aspect. |
01-15-2019, 08:28 PM | #31 | |
THIS!!! I run them on my RZR, I just figure some guys like the scale look and it would be something different.. | |
no torque on crawling - Similar Threads | ||||
Mad Torque Colpar Crawling | QueadlunnRau | Videos! | 0 | 04-28-2018 11:03 PM |
ECX Temper Torque Twist Mod - Reduce torque twist | driftomaniacs | Scale Videos! | 0 | 05-14-2016 04:39 PM |
new to mad torque and rc crawling | mspiller21 | Superclass Crawlers | 49 | 06-14-2014 10:40 AM |
JR DS8711 ULTRA TORQUE SX SERVO 403oz/in TORQUE | 51504rock | Electronics | 1 | 06-12-2007 06:07 PM |
