01-15-2019, 08:58 PM | #1 |
Pebble Pounder Join Date: Jan 2011 Location: Peace and Quiet
| hot slipper plater and burning plastic
Hey guys, Just built a new rr10 with all new gear all the way down to the radio. Tekin rock 412, tekin rx4, new hi tech servo(cant remember the model) On to the issue. I programed the esc and motor with the hotwire. Bound the radio. Set the mesh and dropped a battery on it. No wheels and tires. Ran it and after about 10 seconds of full throttle up on a stand with no resistance on the drive line I started smelling plastic. loosened up the gear mesh a little more making sure not to run it too loose. Waited 5 minutes. Ran it again and touched the metal slipper plate and it was too hot to touch. Any Ideas?? |
01-15-2019, 09:03 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: hot slipper plater and burning plastic
Tighten the slipper spring completly. I guess it's slipping and heating up ? Sent from my Pixel 2 XL using Tapatalk |
01-16-2019, 05:00 AM | #3 |
Quarry Creeper Join Date: Mar 2018 Location: Indonesia
Sounds more like something is binding. If the slipper plate is getting very hot when it is slipping it indicates that it is slipping under a fair load which shouldn't be there with no wheels and tires. Check your diffs by hand to see if they turn easily. If the problem isn't in the diffs it must be in the transmission.
01-16-2019, 06:15 AM | #4 |
The slipper is definitely slipping otherwise it wouldn't heat up. If the metal plates are hot to the touch then your slipper pads are more than likely toast so pick up some new ones. Once the pads heat up, the surface glazes over and it makes the slipper more likely to slip (and Axial's slipper pad material generally sucks). Like bbrigg said, check for binding and if that is all good then it is likely the slipper just loosened up. Put on a new locknut and tighten the slipper all the way down then back it off 1/4 - 1/2 a turn for a bit of drivetrain protection. |
01-17-2019, 12:20 PM | #5 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
Ill just confirm what is said above. everything smooth with no motor? Is so, just double check slipper assenmbly is correct with stickies on the spur. Not sure what else could be. If you can provide a pic or vid we could maybe help find something. Sounds like a fun bomber build though |
01-17-2019, 09:29 PM | #6 |
Thanks for the info. But I forgot to add that I upgraded the motor mount to a Vanquish mount and I just took it apart and what I found is that there is rubbing on the inside of the Spur gear shield.
01-18-2019, 02:55 AM | #7 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Sound like you have already found the problem or Dismantle trans and axles parts and check check check again |
hot slipper plater and burning plastic - Similar Threads | ||||
Mip rear driveshaft gets burning hot. | AWraith build | Axial Yeti | 13 | 10-25-2015 06:39 AM |
Hot Racing Dual Wave Slipper | ittybitty | Axial AX-10 Scorpion | 2 | 01-14-2009 10:14 AM |
Hot Racing Steering knuckles - more steering than the original plastic ones? | Tomy | Axial AX-10 Scorpion | 1 | 11-16-2008 11:26 AM |
Back from the plater | Eritex Inc. | Chit Chat | 14 | 07-29-2008 01:29 PM |
