Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Notchy rear diff...
Old 03-03-2019, 08:49 AM   #1
Default Notchy rear diff...
I'm building my bomber kit and the rear diff is really tight. The problem seems to be that the axle on the ring gear side is pushing the ring gear into the pinion too hard. When I remove the rear lockout on the ring gear side everything spins smooth. As far as I can tell all the bearings are seated properly. Any suggestions?
norco kid is offline   Reply With Quote
Old 03-03-2019, 09:14 AM   #2
Default Re: Notchy rear diff...
Did you shim the pinion
Hang up and Drive
mikemcE is offline   Reply With Quote
Old 03-03-2019, 09:56 AM   #3
With the axle assembled. Chuck the pinion in a drill. Run it forward and reverse to break-in the gear mesh.
SENT from THE DARK SIDE of THE MOON
BAD RC is offline   Reply With Quote
Old 03-05-2019, 06:28 PM   #4
My first bet would be on the inner pinion bearing not being properly seated all the way into it's pocket, (can sometimes be a little plastic flash in the pocket)
pushes the pinion in a little too deep & makes the gear mesh too tight.
altd896 is offline   Reply With Quote
Notchy rear diff... - Similar Threads
Gen7 portal axle notchy, especially after upgrade... Everest10Dad Redcat Crawlers 5 04-05-2019 12:36 PM
New steel transmission gears notchy Smokin' Joe General Crawlers 7 01-02-2018 05:56 PM
Front Diff to use as Rear Open Diff ongbenghui Vaterra Twin Hammers 5 03-02-2017 12:54 PM
Locked Diff on the rear vs "Active" Diff ongbenghui Newbie General 2 11-20-2016 01:51 AM
Spider gears in rear diff (aka losing the rear locker) Sethmetal Vaterra Twin Hammers 2 02-26-2013 11:57 PM
