03-13-2019, 05:15 PM | #1 |
Newbie Join Date: Feb 2019 Location: Burke
| RR-10 Rear Upper Link Question/Problem
Hey everyone, First post here on the forum, and I recently finished my RR-10 Bomber! I had some problems with the stock body panels, so I made some new ones! I also moved the spare tire up over the gas tank, mounted a ProLine 4" light bar, and mounted two tail lights in the rear tow-plate. I ran it a couple times with no issues, and a fellow RC enthusiast pointed out that my rear differential wasn't pointing/facing the correct direction. It seemed that the differential was indeed pointing down, instead of straight, or even angled up slightly. I looked at the manual, made sure I had everything in the correct place, which I did, so I looked at how to 'push' the pumpkin/differential back up a little bit. The solution seemed to be easy, and it came via extending each end of the rear-upper-link bars. I drove it around the house a bit and it did fine like that. I took it out on Sunday to a local trail, and the rear-upper-links gave out in the first couple minutes of driving over rough terrain. They basically came apart where the set screw goes into the link and/or the rod-ends. Is there a better solution for this problem, such as longer/better rear-upper-link bars, or am I missing or overlooking something else or a different/easier solution? I'd appreciate any feedback you have! |
03-13-2019, 05:21 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: RR-10 Rear Upper Link Question/Problem
The angle you have with the rod ends fully screwed in is normal. Sure it can be improved but the stock angle won't harm anything. I have been running mine all year stock angle and it's still in perfect shape. If you insist on correcting it, you can buy JEC Racing or supershafty trailing arms. They are a couple of mm shorter than stock and help to correct the angle. Sent from my Pixel 2 XL using Tapatalk |
03-13-2019, 05:55 PM | #3 |
RCC Addict Join Date: Dec 2014 Location: So Cal
Sorry to get off topic, but I'm seeing taller side panels than stock, catching my aluminum body eye. Side shot pic? Out of curiousity, are the rear end front link mounts the same on a Bomber as the Yeti? If you have the ability to make new ones, you can change the radius/lengths of the upper which alters your pinion angle as it cycles the arc. Scratch build TT guys have done this to minimize the angle. |
03-13-2019, 06:37 PM | #4 | |
| Re: RR-10 Rear Upper Link Question/Problem Quote:
Any idea who makes longer links? | |
03-13-2019, 06:50 PM | #5 |
Longer upper links or shorter trailing arms is the same result. JEC Racing and many other vendors make both but upgraded trailing arms have many other benefits like weight and durability. The kit links are aluminum and work fine. The kit trailing arms are plastic sandwiched in 2 aluminium plates. They will still bend and twist. Sent from my Pixel 2 XL using Tapatalk |
03-13-2019, 06:53 PM | #6 | |
Quarry Creeper Join Date: Feb 2018 Location: East otis
Little edit, was typing this when jboucher responded Sent from my SAMSUNG-SM-G920A using Tapatalk | |
03-13-2019, 06:56 PM | #7 |
@ MAC FAB - Yes, they are taller, and extend further forward, and below the lower side rails. The roof panel hangs over the side rails as well. This was the first time I've ever done something like this, so they aren't pretty. They were the first draft, and I messed up the (aluminum) hood (hence I'm still running the factory hood). |
03-13-2019, 09:17 PM | #8 |
Cool, out of the norm. Tall sides rock! (Pun intended) Lower rocker part will take a real beating, so be prepared for that. Mine has the floor pan going up the rocker, which actually saves the sides from rocks.
03-14-2019, 06:52 AM | #9 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
A quick and easy way to make those upper links longer and stronger is to replace the Axial rod ends with Traxxas Jato rod ends (TRX5525). The Jato rod ends are longer than the Axial ends. You can cut them down a little bit to fine tune the length too.
03-14-2019, 10:32 AM | #10 |
Quarry Creeper Join Date: Jun 2018 Location: CRG
| Re: RR-10 Rear Upper Link Question/Problem This would be my suggestion, as well. Super cheap fix for that pinion angle.
03-14-2019, 10:17 PM | #11 |
Rock Stacker Join Date: Jul 2018 Location: Jackson
I also agree on the Jato rod ends. They work great.
Tags |
axial, bomber, suspension, upper link |
RR-10 Rear Upper Link Question/Problem - Similar Threads | ||||
Upper Rear Link Tuning ?? | cmbscx10 | Axial Yeti XL | 1 | 10-16-2015 04:42 PM |
STRC rear upper link question??!?? | molina | Axial Yeti | 3 | 04-03-2015 07:56 PM |
Dingo front upper link/hardware clearance problem (motor in the way) | professorcake | Axial SCX-10 | 7 | 07-15-2014 03:55 PM |
Lipo Rear Upper Link??? | BMFOTP | Electronics | 5 | 05-19-2009 11:00 AM |
