03-19-2019, 07:54 PM | #1 |
Pebble Pounder Join Date: Apr 2015 Location: New England
| Sealed bomber front diff?
Hi guys, wondering if there is a mod out there for a front sealed diff for the bomber? Before I try and fabricated something lol... I know about getting the diff cup and installing diff gears out of an SMT10 with some hard silicone ear hole pluggers or other stuff, but is there a solution like a silicone sealed diff cup? I'd want a stiff front diff for the ability to not flip over so easy but still to crawl good. I've been told, a front diff setup is the cats meow in terms of the bomber hauling butt lol... Thanks -Spence |
03-19-2019, 07:57 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Sealed bomber front diff?
I thought the AR60 came with a seal to use fluid inside the diff? Pretty sure you can copy the yeti front diff setup. Sent from my Pixel 2 XL using Tapatalk |
03-19-2019, 08:04 PM | #3 | |
| Re: Sealed bomber front diff? Quote:
Hmmm, its pretty cheap to try, I mean AX80002 looks like it has spots for seals on the inside Of course i'd need the smt10 gears and pins and I think the AX80002 which are stock for the bomber. And it seems the machined axial diff gears I have, have slots for seals too on the inside, wow this should be easy Last edited by Spence; 03-19-2019 at 08:13 PM. | |
03-19-2019, 08:47 PM | #4 |
Rock Crawler Join Date: Jul 2017 Location: BC, Canada
All you should need are the gears and the red o rings, there should already be a paper gasket that seals between the diff cup and the ring gear, even on rigs with stock lockers. Sent from my SM-G960W using Tapatalk |
03-19-2019, 08:50 PM | #5 |
Thanks guys
03-19-2019, 09:31 PM | #6 |
RCC Addict Join Date: May 2013 Location: Forrestfield, Western Australia
Plastic AX80002 case works, kinda, for a while. It'll pull the screws fairly rapidly & trash ya spider gears in the process. Ali diff cups tend to be stiffer, gears last longer (though not bullet proof) & you can blue loctite the screws in. hot-racing & rc4wd are about the 2 remaining options (GPM from HongKong used to but supply is hit n miss lately) Get some 7x10mm shims & 3x5mm shims to adjust the spider gears otherwise the mesh can be a bit sloppy & that breaks stuff. |
03-20-2019, 09:36 AM | #7 |
leave the front locked and run the rear unlocked that seems to handle the best for my driving style that way your front is always pulling hard
03-20-2019, 09:48 AM | #8 | |
It's always better to lock the rear and open the front to keep turning radius good and push the truck up-hill If you want the front to pull harder, I would just use rear underdrive gears which would also reduce torque twist. Sent from my Pixel 2 XL using Tapatalk | |
Sealed bomber front diff? - Similar Threads | ||||
Front Diff to use as Rear Open Diff | ongbenghui | Vaterra Twin Hammers | 5 | 03-02-2017 12:54 PM |
do you need a sealed diff to use heavy diff oil? | jebster | Newbie General | 1 | 10-10-2012 07:13 AM |
independent front suspension and front diff build | canadian scx10 | Axial SCX-10 | 1 | 02-13-2011 07:52 PM |
