04-05-2019, 09:25 PM | #1 |
Newbie Join Date: Mar 2019 Location: Roseville
| Drivetrain noise
Recently I purchased my bomber kit and this is my first solid axle rc. Build went smooth but I do notice the drivetrain is noisy. Everything works smoothly with no binding but since this is a first for me I’m not sure if it’s normal or not? It doesn’t sound like grinding or anything so I’m assuming it’s normal.
04-05-2019, 09:41 PM | #2 |
Rock Stacker Join Date: Dec 2012 Location: HESPERIA, SoCAL
| Re: Drivetrain noise
Check Spur and pinion gear mesh. If the mesh is too tight, it can and will make noise. SENT from THE DARK SIDE of THE MOON |
04-06-2019, 06:01 PM | #3 |
Quarry Creeper Join Date: Feb 2018 Location: East otis
To add to the pinion and spur answer, I had a cheapo aluminium pinion set that was really noisy, probably from bad tolerances in the teeth. I ran a few packs through it, still loud. Once I figured out the size I liked I ordered a real one. Is it doing it with the motor disconnected? In reality if there's no binding it probably won't be an issue. Well hopefully anyways Sent from my SAMSUNG-SM-G920A using Tapatalk |
04-12-2019, 01:15 PM | #4 |
Pinion spur mesh is okay. Can the pinion mesh in the axles be adjusted?
04-12-2019, 01:44 PM | #5 |
You can adjust the mesh in the diff with 5mm ID shims, its not something thats included with Axial kits though.
04-16-2019, 11:57 PM | #6 |
Rock Stacker Join Date: Feb 2016 Location: Mercia, UK
I noticed the same thing and think in my case it is because the tooth pitch is not perfectly concentric to the shaft bore. If I rotated the wheels slowly I could hear the noise coming and going as the spur gear rotated the motor pinion. I think the spur gear is the main culprit and found that the Axial 56T metal spur gear was eccentric, the 64T and 56T less so. Of all my pinion/spur combinations the 13/56 is the quietest running. |
Drivetrain noise - Similar Threads | ||||
Weird clicking noise from drivetrain | limegalodon | Axial SCX-10 | 3 | 04-24-2016 09:40 PM |
Sc10 G6 drivetrain | dpcardoza | Axial SCX-10 | 3 | 01-03-2016 11:18 AM |
Drivetrain noise? | strap624 | Axial Wraith | 12 | 10-23-2011 12:30 AM |
Help with Drivetrain! | Reaper09 | Large Scale Rigs | 6 | 05-01-2011 12:31 PM |
drivetrain help | supersonic | Newbie General | 1 | 10-24-2006 06:10 PM |
