Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: JustinL Bomber build
Old 04-23-2019, 11:27 PM   #1
Default JustinL Bomber build
Hey everyone so this was m first crawler build and was really fun build. Not sure where I am going with it upgrade wise but I will update this build thread when I do.
JustinL7294 is offline   Reply With Quote
Old 05-03-2019, 05:08 PM   #2
Default Re: JustinL Bomber build
Was thinking about getting a 2 speed out of the three that I have able to find (axial,ssd, and hr) what would be the better choice?
Old 05-04-2019, 03:11 AM   #3
Very nice bomber mate.Unfortunatley I don't don't have a clue about the 2 speed tho.
Martin 34 is offline   Reply With Quote
Old 05-04-2019, 05:58 AM   #4
There is a lot of threads on the rccrcawler about using a brushless motor instead of the 2 speed.
cpl666k9 is offline   Reply With Quote
Old 05-04-2019, 06:33 AM   #5
Rc4wd two speed
kamilpluta is offline   Reply With Quote
Old 05-04-2019, 07:02 AM   #6
Originally Posted by kamilpluta View Post
Rc4wd two speed
Didn’t know rc4wd had one. You talking about the one for the wraith/scx10?
Old 05-04-2019, 06:32 PM   #7
I have the Axial 2-speed in both my Yeti and my Bomber, and am really happy about it. As far as comparisons go, I can't do any though. If I didn't get the Axial one, I would get the SSD, simply because they were the first to do it and some of the other brands are basically just a rip off of SSD:s design.
If you get SSD, you might want to get the lever set from Axial. It's not necessary, but might make it a bit easier to set it up.
Couple the 2-speed with a Mamba X, so that you have 100% drag brake and instant reverse in gear 1 and less drag brake (30-50% or whatever is your preference) in gear 2, and you have a very flexible rig. You will crawl like a champ, and when you go into 2nd gear and race off, you will not risk a front flip as soon as you let go of the throttle. A good sensored motor does not give you that flexibility.
Antsiranean is offline   Reply With Quote
Old 05-08-2019, 10:18 PM   #8
I used a brushlsess on mine, had the two speed prior, I like the Tekken Pro way better!
bignheavy1007 is offline   Reply With Quote
Old 05-09-2019, 12:06 AM   #9
I'm using SSD 2 speed with a ROC412 3100kv 3s.
PileDriver is offline   Reply With Quote
Old 05-09-2019, 12:36 AM   #10
Does that seem to work well?
Old 05-09-2019, 07:53 AM   #11
I went ahead and got the Hot Racing two speed installed a couple days ago and I couldn’t be happier. Right now my I’m running a stock spec Hobbywing xr10 and Eco Power slingshot 17.5 that I pulled out of my tlr 22 just get the bomber running. Next up is a better esc and motor. I’m wanting something with a little more speed.
Old 05-09-2019, 10:22 AM   #12
Moderator
JatoTheRipper's Avatar
Welcome to the site! Sweet paint job!
The best ESC for the Bomber is the Castle Mamba X. For motors I like Tekin ROC412 or Holmes Puller Pro. That's a high end setup.
Old 05-10-2019, 09:23 PM   #13
Mamba X and HH Puller Pro 3500kv on 3s in my Bomber.
cul8tr is offline   Reply With Quote
Old 05-12-2019, 09:17 AM   #14
This, and a 2-speed in mine. Awesome.
Old 05-27-2019, 07:16 PM   #15
Over the weekend I decided to paint the bead lock rings and added a cheapo led light bar.
Old 08-18-2019, 09:14 PM   #16
Had some stuff laying around from my FPV micro quads and an idea popped in my head. So I took one of the extra helmets from the kit and now some FPV crawling.
Old 08-19-2019, 06:40 AM   #17
That's actually pretty nice.
I have the same FPV AIO (Eachine TX03) on my drone and my yeti jr.
Didn't know they fit inside the bomber helmets!
Their field of view is limited, you might not see much being inside the truck but I can't wait to see footage!
Sent from my Pixel 2 XL using Tapatalk
Jboucher is offline   Reply With Quote
Old 08-19-2019, 04:41 PM   #18
Definitely not the best but could still be fun. I think a camera with the vtx separate would be better with clearance of the roof.
Old 08-19-2019, 09:31 PM   #19
It will be very good on flat ground but crawling you won't see anything
Old 08-25-2019, 12:41 PM   #20
Nice Job. I run a Mamba X and ROC412HD 3100KV. Don't see a need for the 2 speed lol.
Strgazr27 is offline   Reply With Quote
JustinL Bomber build - Similar Threads
My Bomber Build angrchair Axial RR10 Bomber 182 02-21-2021 05:10 PM
Bomber build help 541MM Axial RR10 Bomber 7 05-08-2019 01:53 AM
Need Help with Bomber Build Digs1111 Newbie General 7 09-03-2017 01:40 PM
Bomber Build bignheavy1007 Axial RR10 Bomber 4 09-28-2016 01:18 PM
My Bomber build bredmx Axial RR10 Bomber 8 12-28-2015 11:51 AM
