Go Back   RCCrawler Forums > Scale Rigs Brand Specific Tech > Axial Brand Scale Rock Crawlers > Axial RR10 Bomber
Thread: Alfie’s Bomber
Old 06-11-2019, 01:31 PM   #1
Default Alfie’s Bomber
Hi everybody! Thought I would introduce myself here after lurking a good while. This is my first rc car and was purchased off a previous owner several month ago. Have done quite a few upgrades to it since. Sourcing parts and upgrades can be moderately challenging here in the uk but the overseas vendors have been great at getting parts here quickly to be honest.
HobbyWing Max 10 esc with lcd program box
HobbyWing Ezrun 3660 3200kv brushless running on 3s
HobbyWing 10a external bec
Savox 2290 servo
MIP bomber specific front shaft
MIP yeti rear shaft
Xtraspeed alloy skid plate
Vanquish trailing arms
Vanquish Incision ss links
Vanquish brass pivot balls
SSD Diamond front axle
SSD Diamond centred rear axle
SSD knuckles
SSD c hubs
Axial sway bar
Aluminium axle shock mounts front and arm/sway rear
Axial 64t steel spur
Axial 11t 5mm pinion
HB Rover 2.2’s on unknown plastic beadlocks
Alfiesbomber is offline   Reply With Quote
Old 06-11-2019, 01:47 PM   #2
Default Re: Alfie’s Bomber
Old 06-11-2019, 02:12 PM   #3
Nice looking Bomber!
Fives is offline   Reply With Quote
Old 06-11-2019, 02:24 PM   #4
Thank you
Old 06-11-2019, 02:34 PM   #5
Nice upgrades fella
Whereabouts in the UK?
Sent from my Pixel 3 using Tapatalk
Crawler Cads is offline   Reply With Quote
Old 06-11-2019, 02:39 PM   #6
^ Thanks from Lancashire
Old 06-11-2019, 02:53 PM   #7
Splendid, see you around
Old 06-11-2019, 05:39 PM   #8
Nice rig!
Barndog Racing is offline   Reply With Quote
Old 06-12-2019, 01:35 AM   #9
Looks well sorted from the parts list.
I will say I'm not a fan of them riding quite that high but if it's working for you that's all that really matters.
My guess is those are a HPI wheel. Axial had a 2.2 8 hole bead lock similar but only in black plastic, HPI had the bling chrome.
altd896 is offline   Reply With Quote
Old 06-12-2019, 02:19 AM   #10
I've gone for lower ride height too - better for stability but the long wheelbase does snag easily. Love the modification to reduce wheelbase using the Twin Hammers trailing arms.
IntrepidMercians is offline   Reply With Quote
Alfie’s Bomber - Similar Threads
Making Crawling bomber into trail rig bomber. theTman Axial RR10 Bomber 2 06-10-2016 01:46 PM
