Lowering COG / stance on bomber What's have y'all done to lower the center of gravity and or stance on your bombers? So far I've only adjusted my shocks and changed the upper mount position on the shocks. I run generally at higher speeds and and looking to reduce roll. What do you think my best options for upgrades are? Sent from my ONEPLUS A6013 using Tapatalk |
Re: Lowering COG / stance on bomber my bomber is super stable at speed due to the fact that i run really low ride height, but have a vanquish sway bar on the rear. also, 40wt shock oil on all 4 corners. still flexes nice on the rocks due to softest springs available but handles speed like a beast Sent from my SM-G965U using Tapatalk |
Re: Lowering COG / stance on bomber What'd you do to lower you ride height? Sent from my ONEPLUS A6013 using Tapatalk |
Re: Lowering COG / stance on bomber Build the shocks with zero rebound Softer springs No preload Sent from my Pixel 2 XL using Tapatalk |
Re: Lowering COG / stance on bomber Moar lower. Front and rear sway bars. Wider. |
Re: Lowering COG / stance on bomber Have a look at some of the build threads such as this one: http://www.rccrawler.com/forum/axial...ber-build.html I run mine very similar to this but lower. On the front I use 85mm gmade XD shocks and 103 XD shocks on the rear. The front shock length has a compromised droop but with a rear sway bar it handle reasonably well with a 3500kv motor powered by a 4s battery. |
Re: Lowering COG / stance on bomber i think having built up aluminum axles helps keep it on its wheels too. my bomber has fully built curries and stainless links everywhere and never gives me any signs of tipping at speed. i think running high power you just need to put some weight down lowhttps://uploads.tapatalk-cdn.com/201...e5aff8807f.jpg Sent from my SM-G965U using Tapatalk |
Re: Lowering COG / stance on bomber I switched to Powerstroke shocks. 88mm in front and 102's in the rear. Currie anti-sway bar and the links are basically flat with belly pan now. |
Re: Lowering COG / stance on bomber Go to a Wraith trans. DMG has an adapter availible |
Re: Lowering COG / stance on bomber I did what others have mentioned. Powerstroke shocks with 35wt, rear sway bar, hubs and it runs pretty good now. |
Re: Lowering COG / stance on bomber Tummy tuck and Desert lizard 90mm shocks droop setup. |
Re: Lowering COG / stance on bomber Quote:
Re: Lowering COG / stance on bomber I don’t have FB oh well |
I just use FB... Sent from my Pixel 2 XL using Tapatalk |
