05-22-2019, 02:26 PM | #1 |
Newbie Join Date: Nov 2018 Location: US
| Set up w/ mamba x and 3800kv motor
I'm switching over to a Mamba X ESC and castle 3800kv brushless sensored motor. Anyone else running this set up. Provided gearing chart doesn't list any axial rigs but seems to suggest I should only run with 2S lipo or risk damage (based on instructions for similar sized rigs), which seems a bit disappointing. Sent from my ONEPLUS A6013 using Tapatalk |
05-22-2019, 02:30 PM | #2 |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: Set up w/ mamba x and 3800kv motor
3S will litterally do cartwheels. I put a 3300 in my RR10 Bomber and it is stupidly fast, still crawls. Great electronics, especially the 'race/crawl' modes on the third channel. I run 2S unless I want to burn rubber. Try it out. |
05-22-2019, 02:41 PM | #3 |
Quarry Creeper Join Date: May 2017 Location: Devon
3800 castle (green) in mine with a Sidewinder 4 and it's fricking awesome 11t pinion on 3s. I absolutely love it Sent from my Pixel 3 using Tapatalk |
05-23-2019, 09:56 AM | #4 |
Newbie Join Date: Mar 2019 Location: Thousand Oaks
Same setup here and I ended up running 2s instead of 3s. 3 was just way too fast and roached my spur within about 10 mins. Running robinson steel gears now.
05-23-2019, 11:43 AM | #5 |
Oh dear! I've got my telemetry dialled in for the Sidewinder so I really have to mean it if I want to bash! Sent from my Pixel 3 using Tapatalk |
05-23-2019, 11:49 AM | #6 |
Newbie Join Date: Apr 2018 Location: Modesto
I run this in my Bomber Castle Mamba Monster X ESC Castle 1410 3800Kv Sensored Brushless Motor HotRacing Steel Pinion 32P 16T HotRacing Steel Spur Gear 32P 68T Axial 2-speed Transmission with Hi-Speed Option 3S 35C battery It's pretty fast but not crazy fast. Definitely need to slow down to corner but still very crawl capable but its lowered a bit with powersrtroke shocks and also has an anti-sway bar. 11.5 mph in low / 19.6 mph in high |
05-23-2019, 05:09 PM | #7 |
Quarry Creeper Join Date: Mar 2019 Location: Low CG
I'm running Mamba X with Castle 3800 in my X4. 45/9T. I prefer just to crawl and the setup works just fine.
05-24-2019, 09:28 PM | #8 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
I ran a mamba x with a 1410 3800kv and it was fast but I don't remember it crawling very well at all tho.
05-31-2019, 01:01 PM | #9 |
| Re: Set up w/ mamba x and 3800kv motor It was hard to crawl with my setup above, but once I adjusted the throttle curve, its easy. Instead of a 1:1 (45 degree) line, I set mine to an exponential shape so more initial throttle produced less power and made it easier to crawl
06-01-2019, 04:04 PM | #10 |
Maybe I'll try it again some day, that motor has since been installed in my short course truck. My current set up is: Mamba X and ROC412 3100kv, also running a SSD 2 speed on 11.1v (3s) |
06-01-2019, 05:08 PM | #11 |
I still haven't run it on 3S yet. I'm still waiting for a C-link so I can program an motor cutoff temp. But even on 2S it's pretty fast. Sent from my ONEPLUS A6013 using Tapatalk |
06-02-2019, 01:47 PM | #12 |
Newbie Join Date: Dec 2017 Location: Pittsburgh
Running the same set up in mine. Has plenty of her up and go, but can still crawl. I do need to adjust the throttle curve though.
06-02-2019, 07:44 PM | #13 |
Quarry Creeper Join Date: Nov 2009 Location: Hickory,NC
I was running a Mamba X and a HH puller pro 3500 xl on 3s. I pulled it after breaking the f axle and the r axle 2 days later. Going back to the HH trail master sport 21t and HW 1080 esc. It was wicked. I thought about putting my aluminium ar60 axles on it. Duratrax 2.2 showdowns were not the tire for that set up either.
06-07-2019, 03:53 PM | #14 | |
| Re: Set up w/ mamba x and 3800kv motor Quote:
06-17-2019, 09:22 PM | #15 |
2s was slow/boring. Mamba X and the 3500 is an outstanding combo but not for me in the bomber. Tune yes I could have but I have other plans for that combo. I really like the 21t in the bomber. No worries if it gets messed up it's only $20. I have the Redcat Gen8 17t motor in the bomber now. 17t just wasn't as smooth as I wanted in the trail truck. Gen8 got a 27t 550 trailmaster sport. |
Set up w/ mamba x and 3800kv motor - Similar Threads | ||||
Gearing Suggestions Mamba / Castle 1410 3800kv | Trail Rated CJ | Axial RR10 Bomber | 8 | 10-26-2017 09:04 AM |
